Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th May 2013, 16:34   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Donít be fooled by Laptop CPUs
Laptop CPUs have names with big numbers that sound just like their desktop counterparts, but don't be fooled...
http://www.bit-tech.net/blog/2013/05...y-laptop-cpus/
Meanmotion is offline   Reply With Quote
Old 25th May 2013, 17:47   #2
GoodBytes
How many wifi's does it have?
GoodBytes's Avatar
GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.GoodBytes is definitely a rep cheat.
Yup, laptop processors (GPU and CPU) are far behind the performance of a desktop version. The model name just says the architecture. Although, sometimes (mostly GPUs) they are exceptions in that you get a previous generation architecture with the name of the current desktop architecture.
The big reason for the slow down, is the requirement that is needed to be done on the CPU to consume drastically less power, and reduce heat.
Another effect, is the OEM butchering, specially on the GPU side.
Many time OEMs uses older memory (DDR2 instead of DDR3 for example), and/or much slower memory than what the GPU is suppose to have. And also, many times they slow down the GPU.
They do this for a several reason: Keep cost down by using memory chips they already have, so that they don't get thrown away, and as for the GPU down-clock, reduce heat, or increase battery life, without actually upgrading the battery to something better, to again reduce cost (or maximize profit).
It is critical to check reviews on laptop, making sure you get what you are suppose to get.
__________________
Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB
GoodBytes is offline   Reply With Quote
Old 25th May 2013, 18:01   #3
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
I am interested in benchmarking my Laptop against my PC... What benchmark suite would you recommend to not only test the CPU, but the GPU and then the whole system together? PCMark 8?
__________________
SchizoFrog is offline   Reply With Quote
Old 25th May 2013, 18:30   #4
AiA
Multimodder
AiA has yet to learn the way of the Dremel
well custompc have there own that you can use
i think it does quiet a few things
and then you can use something like x3: demo for the graphics side
i think this is an old benchmark
http://www.bit-tech.net/blog/2009/10...nchmarks-here/
so they might have updated it since then
AiA is offline   Reply With Quote
Old 25th May 2013, 18:43   #5
SchizoFrog
I *am* a Dremel
I sure hope it's been updated, that download is dated 2007. lol
Thanks any way for the info, I'll wait to see what B-T suggest.
__________________
Old 25th May 2013, 18:43   #6
mystvearn
any-may
mystvearn's Avatar
mystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremel
Smaller PC's will be the norm. Just look at the PC's on sale in Currys. Those Acer have small footprint. The only problem is I want to build a good gaming pc with a HTPC, in a case smaller than the BitFenix Prodigy, which seems impossible with off the shelf item. Something as big as the Alienware X51.
The only method I see is the use of AMD APU, A10 processor. Then you can sort of ditch the graphic card and put it in a very small case.
mystvearn is offline   Reply With Quote
Old 25th May 2013, 18:46   #7
Yslen
Lord of the Twenty-Seventh Circle
Yslen's Avatar
Yslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming Saiyan
I didn't realise they were quite that bad. I thought the i7 was still pretty nippy because it has hyperthreading, so performs well compared to desktop i3 and i5 parts. Apparently not!
Interesting, considering that geekbench shows i7 macs powering ahead of anything except i7 or above desktop machines. Then again, we've all known that's a totally inaccurate benchmark for a while...
__________________
Asrock Z77e-ITX - Intel i5 3570k - Corsair H100i - G.Skill Ripjaws X 2133MHz - MSI GTX 970 - Crucial M4 - 530W ThermalTake SS PSU - Corsair 250d - LG IPS231P - Logitech G302 - Many, many keyboards
Take a look at my Photography portfolio, here.
Yslen is offline   Reply With Quote
Old 25th May 2013, 18:48   #8
Yslen
Yslen's Avatar
It is the same benchmark suite used in 2007. It's a real-world benchmark though, so it's still perfectly valid. It's actually the most accurate set of benchmarks I've used, and I've tried most of them at one time or another.
Sorry for double post!
__________________
Old 25th May 2013, 18:51   #9
SchizoFrog
I *am* a Dremel
OK, cheers Yslen...
__________________
Old 25th May 2013, 19:01   #10
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
This also affects all-in-ones and some SFF PCs [also the non-'pro' Macs, though apple don't cut as many corners] as they use laptop and/or the ultra low-voltage parts to keep temperatures and the need for fans to a minimum...
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is online now   Reply With Quote
Old 25th May 2013, 20:06   #11
Star*Dagger
Banned
Star*Dagger has yet to learn the way of the Dremel
Any gamer could tell you this, NEVER EVER game on a laptop.
It will be a horrible experience, period.
Star*Dagger is offline   Reply With Quote
Old 25th May 2013, 20:12   #12
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
considering the performance you can get on a laptop these days if your willing to spend the cash its easily possible to get desktop level of performance.
sli 680m with top end intel cpu is faster than 90% of the people on here probably have.
rollo is offline   Reply With Quote
Old 25th May 2013, 20:15   #13
rollo
Also costs about £3000 but thats not the point you can get a good experience if you can afford it.
Old 25th May 2013, 20:16   #14
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
Lol @ FX8150
I know that wasn't the point of this article, but......
Hustler is offline   Reply With Quote
Old 25th May 2013, 20:39   #15
SchizoFrog
I *am* a Dremel
Rollo, I think you completely missed the point of this article. It wasn't comparing GPUs as it says CPU in the title and compares the difference between mobile and desktop products and how misleading they can be.
As for Star*Dagger, are you a dick on every article or just having a bad day?
__________________
Old 25th May 2013, 20:53   #16
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
If you don't need a laptop for mobile computing, then a mITX-system will allways be the better choice.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 25th May 2013, 21:05   #17
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.
Guy at work chucked £1500 at an i7 Medion Gaming laptop with a 670MX His intent was to use it at home for ReconstructME which uses a Kinekt type camera to map 3D objects in space:
http://reconstructme.net/
He was bitterly disappointed with the performance. I did tell him i could spec+ Build a comparable computer that would do a better job for 1/3rd of the price but he was seduced by the marketing : (
__________________
Main Phanteks Enthoo ITX Windowed - Pentium G3258 @ 4.5GHz - 8GB Samsung DDR3 @ 1600 MHz - Sandisk Ultra 240GB - EVGA 760 SC 2GB - Asrock Z97M-ITX/ac - Windows 10
HTPC Intel NUC (Celeron 847) - 30GB Samsung mSATA SSD - 2GB Crucial RAM 1333MHz - Windows 10
MrJay is offline   Reply With Quote
Old 25th May 2013, 21:08   #18
CowBlazed
Supermodder
CowBlazed has yet to learn the way of the Dremel
Laptops, especially the stuff coming out from Lenovo in the $800-$900 price range can make great mobile gaming rigs compared to a similar priced desktop. Sometimes you just need everything built in, but of course that will never get you the full computing experience as having a dedicated box with endless peripherals.
CowBlazed is offline   Reply With Quote
Old 25th May 2013, 21:23   #19
SchizoFrog
I *am* a Dremel
Even if laptops can provide a good gaming experience you still have the issue though that they are not comparable to desktop components. Unless you NEED mobility, a small PC is definitely the way to go. Not to mention the fact that I and many others HATE using a laptop's keyboard.
__________________
Old 25th May 2013, 21:52   #20
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Hi SchizoFrog. As Yslen mentioned, our benchmark is a few years old but still scales well with faster hardware and uses real-world image editing and video editing programs, not synthetic tests, so you can definitely trust it!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
