Reply
Thread Tools View Mode
Old 26th May 2013, 00:49   #1
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.coolamasta is definitely a rep cheat.
Coolamasta's Home NAS & VM host build
Hey All,
Thought I would put another thread together with the progress of my home NAS and VMware host builds, I have both currently built and running but am about to upgrade them both again.
The first batch of pics in post #2 are from the previous build of the NAS and the post #3 pics are from where I built the 16U MDF rack to hold the kit
Spec of the NAS currently is:
  • 4U Rack mount case
  • MSI H77MA-G43 s1155 Motherboard
  • Intel i3 2120 CPU @ stock 3.3ghz
  • 16GB Kingston Hyper DDR3 RAM (4 x 4gb) @ stock 1600mhz
  • Seasonic G series 360w '80 Plus Gold' PSU
  • LSi 8-port 9260i RAID Controller with 256mb Cache (Need a BBU!)
  • 4 x Western Digital 3TB "Red" (Raid Edition) Harddrives
  • Icy Box IB-545SSK Tray less 5 Bay HDD enclosure
  • Crucial M4 60GB SSD for OS & Plex server
  • WD Green 2TB HDD for general dumping group/PC backups/DL's etc
  • Intel Pro Dual 1000 PT PCIe Server NIC in 2GB Teamed Config
Spec of the VMware host currently is:
  • Intel i5 3570k Ivy CPU under-volted @ stock 3.4ghz
  • 16GB GeIL Black Dragon DDR3 RAM (2 x 8gb) @ stock 1600mhz
  • 8GB Kingston Hyper-X DDR3 RAM (2 x 4gb) @ stock 1600mhz
  • Antec Greenpower 350w '80 Plus Bronze' PSU
  • 2 x 120GB OCZ Vertex 2 SSD's
  • 2 x Western Digital 500GB "Black Edition" Harddrives in Raid 1 (On-board Raid)
  • Intel Quad Pro 1000 PCIe Server NIC
Currently the NAS is running a Raid-5 configuration and have 8.18TB of usable space from the 4 x 3TB Red's. I stuck with the default 64KB stripe size and had a play with the read-ahead, read through, write through and write back settings to see what I/O I can get
There is a 120mm inlet fan at low speed, the top panel expansion card arm holder I've modded to hold an 80mm fan to breeze air over the RAID controller heatsink as it gets pretty damned hot!
Below are the results of the array in a RAID 5 using the following config:
Stripe Size:- 64KB
Read Policy:- No Read Ahead
IO Policy:- Direct IO
Write Policy:- Write Through (was using 'Always Write Back' but need BBU)
Access Policy:- Read Write
I have 1 problem though and that is I don't have a BBU (Battery Backup Unit) installed which means that having the Write Policy set to 'Always Write Back' is dangerous because if there is a power failure then it will most likely cause data corruption and mess up the Raid array and make me a very unhappy chappy!
I currently have set the Write Policy set to 'Write Through' which will get rid of the risk but it has dropped my write speeds to less than a quarter of what they are above, crazy how much difference it makes! * Update - I now have a BBU which will be added on the upcoming upgrade
__________________
Main Rigs:~ i7 4790K @ 4.8 WC'd - 16GB @ 2400 - GTX 1080Ti | Alienware 13 Laptop, i7, M.2 SSD's, 16GB & Graphics Amp 980Ti
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 26th May 2013, 00:50   #2
coolamasta
coolamasta's Avatar
The current NAS build:
The current VMware build:
__________________
Old 26th May 2013, 00:51   #3
coolamasta
coolamasta's Avatar
The Rack Build:
__________________
Old 26th May 2013, 00:56   #4
coolamasta
coolamasta's Avatar
Some pics of how it currently stands before the servers get stripped down and rebuilt with the upgrades etc
__________________
Old 26th May 2013, 01:33   #5
shrop
El Jefe of Sleeving
shrop's Avatar
shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.shrop is definitely a rep cheat.
Wow, that looks epic mate! Nice job.
__________________
shrop is offline   Reply With Quote
Old 26th May 2013, 06:30   #6
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
Nice job very clean !
SilveR_172 is offline   Reply With Quote
Old 26th May 2013, 11:08   #7
Ocelot
Multimodder
Ocelot's Avatar
Ocelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming Saiyan
That looks really neat! good job.
Ocelot is offline   Reply With Quote
Old 27th May 2013, 02:21   #8
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
That's a pretty bitchin setup you got there and it's new home looks great. Those louvres looked pretty cool. Where'd you get them?
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 27th May 2013, 14:50   #9
coolamasta
coolamasta's Avatar
Thanks all, just getting all my new hardware up-together read for the upgrade at the moment
Cheers bud, the louvres were just from B&Q in the ventilation section, don't think they were very expensive to be honest
__________________
Old 27th May 2013, 15:11   #10
coolamasta
coolamasta's Avatar
Few pics of some of the new hardware for me new VMware host:
* HP P800 16-channel Raid-Controller, (8 Internal, 8 External) its a bit overkill for what im going to be using it for but as it didn't cost me anything I can live with it
* Icybox Trayless 3-bay Dual channel SAS harddrive enclosure
* 3 x Seagate Cheetah 15,000 RPM 300GB SAS Harddrives
* Intel i5 3570k Ivybride CPU
The current i3 CPU running as my VMhost has done very very well handling my 7 VM's but its not got quite enough puff which is why I'm going for the i5 Ivy, should run faster, cooler and still use little power, but then im sure the 15k SAS drives will help use the power haha.
Just waiting on the new motherboard for the NAS, then the current NAS motherboard will be used with the i5 to become the VMhost as it has a H77 chipset so better for the Ivy.
__________________
Old 15th Jun 2013, 12:14   #11
coolamasta
coolamasta's Avatar
Change of plan with the 15k drives and HP P800 RAID controller, my entire goal with the NAS and VMware host was to keep the power consumption as low as possible, the P800 RAID card doesn't make a massive difference in power consumption but those 15k SAS drives eat far more power than I expected and the heat they produce outweighs how well the IcyBox can cool them, IE they cant haha so I had to ditch that idea in favour of some SSD's
I've added a BBU to the LSI Raid controller in my NAS and now getting the awesome I/O again without having to worry about corrupt data in event of a power outage, not a lot else change to it besides now its running a Dual Intel Pro1000 Server NIC which is Teamed to produce a single aggregated 2GB link to the switch
__________________
Old 15th Jun 2013, 12:50   #12
LegendaryScott
Trying to live up to the name
LegendaryScott's Avatar
LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.
Woh, setup is awesome dude
LegendaryScott is offline   Reply With Quote
Old 15th Jun 2013, 20:52   #13
matiss
Multimodder
matiss's Avatar
matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.
Some very sweet hardware you got there.
__________________
in planning for to long: Viole(n)t Raven
matiss is offline   Reply With Quote
Old 15th Jun 2013, 21:14   #14
GaryP
RIP Tel
GaryP's Avatar
GaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming Saiyan
Great set up. How insane is your electric bill !
__________________
Intel i7 5820k @ 4.3Ghz | Corsair H110i GT | 16GB G Skill Ripjaws 4 3200Mhz | MSI Titanium X99A | Corsair AX 760 PSU | GTX 970 AMP! Extreme Core| 240 GB Kingston HyperX SSD | 2 x 2TB Hitachi HDD | 2 x 2TB seagate HDD | Asus Xonar D2X Soundcard | NZXT 810 Case | Windows 7 Home Premium 64 bit | Dual 27" Monitors
Steam: HackneyHawks
GaryP is offline   Reply With Quote
Old 15th Jun 2013, 21:29   #15
dynamis_dk
Grr... Grumpy!!
dynamis_dk's Avatar
dynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyandynamis_dk is a Super Spamming Saiyan
Looks like an awesome build. I'd love to do something very similar myself so I could hide everything out of the way a little but unfortunately don't have the money to replace everything with rackable gear
__________________
-: MM UF0 Duality :- 2700K, 16GB Ballistix Tracer 1600, P67A-GD65, RAID0 2x250GB 840 Evo, GTX970, AX1200 :-
-: Dual Loop Watercooling :- 2x Laing D5, 2x PA120.3, EK 580GTX Fullcover, EK Supreme HF, EK TubeRes :-
dynamis_dk is offline   Reply With Quote
Old 17th Jun 2013, 18:28   #16
coolamasta
coolamasta's Avatar
Heres the new VMware host, its now been moved out the massive 4U rack mount case into a 2U instead, now that I have ditched the 15k drives I am running a pair of 120GB SSD's and also a pair of 500GB drives in a Raid-1 for now...
Some new hardware now being used to keep power consumption low namely an IvyBridge i5 undervolted, full spec is below:
  • 2U custom rack mount case from servercase.co.uk
  • Intel i5 3570k Ivybride CPU
  • 8GB Kingston HyperX DDR3 RAM (2 x 4gb) @ stock 1600mhz
  • Icybox Trayless 3-bay Dual channel SAS harddrive enclosure
  • 2 x OCZ 120GB SSD's
  • 2 x 500GB WD Black HDD's
  • Intel 4 port Pro1000 NIC card
__________________
Old 17th Jun 2013, 18:29   #17
coolamasta
coolamasta's Avatar
Thanks for the comments all
Its not toooo bad to be honest, everything you see in my rack is only pulling 180w at the wall!
__________________
Old 17th Jun 2013, 18:51   #18
flame696
Terminating People Since 1980....
flame696's Avatar
flame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyan
amazing i want that setup in my cellar but alas i dont know what i would use it for lol.
what do you do with all this hardware and this setup??
__________________
flame696 is offline   Reply With Quote
Old 17th Jun 2013, 18:56   #19
AverageNinja
Almost an EpicNinja
AverageNinja's Avatar
AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.
Amazingly clean job on the cabling, it's hard to do in a case like this
AverageNinja is offline   Reply With Quote
Old 18th Jun 2013, 03:20   #20
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming SaiyanMechh69 is a Super Spamming Saiyan
Very nice job with that build. I have a question for you, can you only get the Intel Pro NICs to work in Aggregate? Or is it possible with dual onboard NICs like the one on my EVGA board? I have searched for a way to use them in aggregate but I have not found a solution yet. My google FU may be off.
__________________
Deders - What if you touch yourself with kittens?
.//TuNdRa - Short of standing on a street corner (I'd make an ugly hooker, anyhow.)
i7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, MSI 660TI 3GB, BFG 260 GTX Core 216 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
