Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 29th May 2013, 11:23   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
AMD targets Atom microservers with Opteron X-Series
Small-core Jaguar chips for the server crowd.
http://www.bit-tech.net/news/hardwar...ron-x-series/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 29th May 2013, 11:39   #2
rayson
Damn sure it was legal
rayson has yet to learn the way of the Dremel
YAY AMD show them
rayson is offline   Reply With Quote
Old 29th May 2013, 14:30   #3
Snips
I can do dat, giz a job
Snips's Avatar
Snips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming Saiyan
"and, if they perform as well as claimed, it could certainly have come up with something to wipe the smirk off rival Intel's corporate face,"
Don't we get the exact same line with every AMD marketed release?
And what tends to happen again? oh yeah, it's all BS!
Snips is offline   Reply With Quote
Old 29th May 2013, 15:42   #4
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Cooperations no longer bielieve in AMD so no longer buy from them, Theres a reason they are below 10% on the server market now behind ARM even.
It will also take alot more than 1 good product launch to correct AMDs issues in this market.
Packing them with Onboard GPU is smart as in the low end they maybe able to get there chips inside home servers and save people a gpu purchase as well assuming its good enough to handle the general needs of that user.
rollo is offline   Reply With Quote
Old 30th May 2013, 00:32   #5
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
If GPU processing can be used in more server market applications then this could be a winner in the microserver segment. However its their marketing department and actual test result/benchmarks using real world software that will see this go up or crash down
LightningPete is offline   Reply With Quote
Old 31st May 2013, 05:23   #6
Goty
Supermodder
Goty has yet to learn the way of the Dremel
While the peak TDP of AMD's Opteron X-Series doesn't come close to touching the 8.5W peak of Intel's S1260, it does include twice as many integer processors.
AMD's X-series processors also don't require an additional I/O chip, whereas the Atom chips do.
Goty is offline   Reply With Quote
Old 31st May 2013, 19:47   #7
Chicken76
Hypermodder
Chicken76's Avatar
Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by Article
...its four general-purpose processing cores which ... are split into two pairs each sharing a single floating-point unit and a chunk of the chip's 2MB L2 cache.
Where does it say that the FPU is shared a-la-bulldozer?
The L2 cache yes it is shared, but each core has it's own FPU I believe.
Chicken76 is offline   Reply With Quote
Old 31st May 2013, 20:26   #8
Gareth Halfacree
WIIGII!
bit-tech Staff
You're quite right - that was a misunderstanding on my part. I'll get that corrected, although as the CMS is still having a few hiccoughs it'll have to wait until the IT Elves have sorted things out I'm afraid - otherwise I risk making the whole darn article vanish!
EDIT: Phew: tested editing out on a never-published draft article, went fine, so I risked updating this article - and it's still there. Hoorah!
__________________
Reply
Tags
amd, apu, atom, atom s1260, data centre, datacentre, jaguar, kyoto, microserver, opteron x1150, opteron x2150, server, soc, system on chip
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
