Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 1st Jun 2013, 11:47   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
PS4 games require Vita remote play compatibility
Sony has stated that all upcoming PS4 games should be compatible with Vita remote play.
http://www.bit-tech.net/news/gaming/...lay-compatib/1
Meanmotion is offline   Reply With Quote
Old 1st Jun 2013, 12:02   #2
enciem
Multimodder
enciem's Avatar
enciem has yet to learn the way of the Dremel
Well that makes sense, there's sod all else to with my vita. The games are still largely rubbish, and not to mention fugly, ports.
enciem is offline   Reply With Quote
Old 2nd Jun 2013, 02:17   #3
bagman
I Mod, Therefore I Own
bagman's Avatar
bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.bagman is the Cheesecake. Relix smiles down upon them.
Is this not much like the Wii U remote? If it is the case then good as it is a decent feature but is on a console which has games.
bagman is online now   Reply With Quote
Old 2nd Jun 2013, 03:01   #4
SAimNE
Multimodder
SAimNE has yet to learn the way of the Dremel
so they only way to get a decent game on the vita is to buy a ps4 and stream it from there....
ill admit it's a step forward, but it'd probably increase vita sales if they would actually make GAMES for the handheld GAMING device, not just allow i to stream them from another console.... just a tip.
SAimNE is offline   Reply With Quote
Old 2nd Jun 2013, 05:16   #5
Neogumbercules
Mod Master
Neogumbercules's Avatar
Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.Neogumbercules is the Cheesecake. Relix smiles down upon them.
My bathroom trips just got a lot more entertaining.
__________________
Corsair Obsidian 250D - Asus Maximus VI Impact - Intel Core i5 4670k - Radeon R9 290
Neogumbercules is offline   Reply With Quote
Old 2nd Jun 2013, 08:01   #6
Sub-particle 0.76
What's a Dremel?
Sub-particle 0.76 has yet to learn the way of the Dremel
Wouldn't be surprise if similar application will be available on smartphones bypassing vita altogether
Sub-particle 0.76 is offline   Reply With Quote
Old 2nd Jun 2013, 14:26   #7
sub routine
Archie Gemel
sub routine's Avatar
sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.sub routine is the Cheesecake. Relix smiles down upon them.
shouldn`t it read Vita requires PS4.......... URGENTLY, as the lack of decent games is driving me batty.
sub routine is offline   Reply With Quote
Old 2nd Jun 2013, 16:47   #8
Neogumbercules
Mod Master
Doubtful. Too many buttons, plus I'm sure Sony have thought of that and will make such a thing impossible. XB1 on the other hand will use "Smartglass" to do non-gaming BS on your mobile devices.
__________________
Old 3rd Jun 2013, 13:51   #9
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
I don't get it, if the PS4 game is basically just shrunken and transmitted wirelessly, what exactly is there for the devs to do?
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
