Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Jun 2013, 06:05   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Thermalright AXP-100 Review
We take a look at Thermalright's deceptively small low-profile cooler, the AXP-100.
http://www.bit-tech.net/hardware/coo...p-100-review/1
Meanmotion is offline   Reply With Quote
Old 3rd Jun 2013, 09:23   #2
law99
Custom User Title
law99's Avatar
law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.
This is where your stand on AMD processors not being relevant really quite frankly falls flat on its face.
FM2 build is quite likely for an HTPC (I'm doing one right now for instance) and it would have been useful to see. Instead, I'm looking at something I'd never use it on.
Thanks though... ??? I'm aware of it and will be googling for more definitive testing. To be honest, I like to have an idea of decibel so I can compare it to other equipment I have for reference. And I'd be interested in how its FM2 mounting works.
EDIT: In your defence it took some scouring to find a decent review of this heatsink. There is a very lapse one for an A10-5800K APU. But there are some other places that have given some indication of sound levels.
It would have been nice to see whether fanless operation on a 65w part would be possible. Instead, I may have to find out myself.
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | soaking 1070 gtx | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | BenQ bl3200pt 2560x1440p
law99 is offline   Reply With Quote
Old 3rd Jun 2013, 09:44   #3
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
What we said was that the AMD AM3 socket we previously tested with was "becoming less relevant". With FM2 arguably being the most relevant AMD socket at the moment (someone made the good point that there are probably more users of said socket than LGA2011, for example) this is the platform we attempted to build our new AMD test system on, but after a lot of testing and trying to fix the issue, it became increasingly clear that the results were still inconsistent and thus unreliable. It's something we're still looking to bring back, but between other product reviews, multiple product launches, staff holidays, trade shows, server downtime etc., it's tricky to find the time to get it all up and running. Hopefully the summer will give us a little more breathing room to focus on improvements such as this
Sorry we couldn't give you all the information you wanted at the moment. As for noise testing, this is a separate issue we've addressed many times. Where our labs are situated and with the equipment we have, providing accurate dB readings just isn't too feasible at the moment.
Dogbert666 is offline   Reply With Quote
Old 3rd Jun 2013, 09:58   #4
law99
Custom User Title
law99's Avatar
Thanks for your response. TBH, I am(probably) aware of your noise issues. I believe I remember it coming up before.
Could you not give an indication of the background noise in your testing room? That way, along with various other sources, it would be possible to attain some sort of informed reasoning on subjective noise levels. Perhaps that could always be in the testing methodology section?
In the meantime, I hope you do find a way to test FM2. It is a real shame though that there isn't much of what I'd call a relevant review out there for this heatsink.
I'm currently of the mindset that I'll try the stock one, and if it is an issue, I'd try this with a fan. And if with a fan is more than reasonable, I'd try it without a fan... just out of curiosity.
__________________
Old 3rd Jun 2013, 10:14   #5
Dogbert666
bit-tech Staff
Dogbert666's Avatar
No worries. Yeah the noise issues are a pain. The problem with the background noise idea is that it just fluctuate too wildly and often for it to be of much benefit, as it depends on what other systems (and how many, how close and how loud they are) are running, the air conditioning levels, the inevitable noise from the two huge building sites right next door and so on.
I hope so too! Once Computex is out the way and everyone is back in one place, hopefully we'll be able to get something up and running.
Old 3rd Jun 2013, 10:23   #6
sakzzz
Multimodder
sakzzz has yet to learn the way of the Dremelsakzzz has yet to learn the way of the Dremel
Can someone suggest the correlation between the 2600K in your review with a 2500k @ 4.2 ? I am planning a custom compact case and this would be IDEAL, considering its not far away in terms of results from a gelid tranquilo. I average at ~60 on full load, room temp being ~20 currently.
__________________
Intel Core i5-2500K, MSI P67A-GD53,Corsair Vengeance 4GB, Gigabyte gtx 560Ti, BE quiet Pure power 560W, Samsung 256GB Pro SSD, Gelid Tranquilo, Antec 100
sakzzz is offline   Reply With Quote
Old 3rd Jun 2013, 11:47   #7
law99
Custom User Title
law99's Avatar
I think the nature of Hyperthreading would mean that the 2600k is the hotter running chip. But I'm sure someone out there would have a better response than me. I have no evidence other than a less than rudimentary understanding of how hyperthreading works.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
