Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Jun 2013, 11:11   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Asus introduces G10 desktop PC with built-in UPS
New range will ensure data isn't lost when the power goes out.
http://www.bit-tech.net/news/hardwar...with-built-i/1
Meanmotion is offline   Reply With Quote
Old 3rd Jun 2013, 12:40   #2
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
I can't believe ASUS are the 1st company to introduce an inbuilt UPS into a PC, great idea, if only to conduct a managed shutdown in favour of total power loss when disks are still spinning.
__________________
Teh unofficial Bit-Tech proof reader and understander of all the necessary hashtags
B1GBUD is offline   Reply With Quote
Old 3rd Jun 2013, 12:43   #3
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Just hope they can get the software side right...
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 3rd Jun 2013, 15:43   #4
DaBigDog
Minimodder
DaBigDog has yet to learn the way of the Dremel
Come on guys - it's not really a UPS, it's 25 second back-up battery to allow for a quick emergency shut-down, calling it a UPS is really stretching the definition. If you want a UPS, find a specialist and talk to them...
I do work for a specialist - but I'd not be so crude as to advertise them....
DaBigDog is offline   Reply With Quote
Old 3rd Jun 2013, 16:07   #5
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
I remember a while ago there was a workstation laptop and in the marketing spiel the battery was described as a UPS because that's what it's intended purpose was [it wasn't intended to be used as a laptop... it only lasted about half an hour on battery iirc...]
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 3rd Jun 2013, 16:52   #6
ChaosDefinesOrder
Vapourmodder
ChaosDefinesOrder's Avatar
ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.
The laptop I use a work (Dell Precision M6500) is in the "mobile workstation" territory where the battery only last 1.5 hours so UPS is probably the best way of describing their batteries too!
Also wasn't there a motherboard released a while ago with a battery slice on the back-side?
ChaosDefinesOrder is offline   Reply With Quote
Old 3rd Jun 2013, 18:42   #7
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
This can't be really portable. What about the weight? Batteries can weights a TON !
Gradius is offline   Reply With Quote
Old 3rd Jun 2013, 19:30   #8
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
lithium batteries aren't that heavy, compared to NiCad or lead acid.
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 4th Jun 2013, 07:15   #9
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
Yeah, seems like more a gimmick than anything - as others have said, you'd be lucky to have time to get all your programs closed and shut down before the battery gave out, at least if you're running more than a single program.
The halfway decent UPSes I buy at work barely last long enough to do that, and the batteries are the size of bricks (granted, they're lead-acid), I can't imagine something 1/10th the size would be comparable.
fluxtatic is offline   Reply With Quote
Old 4th Jun 2013, 08:40   #10
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming Saiyan
If its inside though it'll be operating at much lower voltages, so is possible to do a couple of minutes I suppose.
also modern battery tech is a long way from NiCad of old, the current nanoLiPo are amazing...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Asus 780 Posiedon Platinium, 512GB Crucial Mx1000, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 4th Jun 2013, 09:43   #11
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
It's not hard, just tell Windows that it's a battery, and it'll work just like a laptop (clocking down on battery, and automatically shutting down on low battery). This is how APC UPS's work as long as you don't install their terrible software.
Windows has be fine with UPS's since at least XP.
phuzz is offline   Reply With Quote
Old 4th Jun 2013, 11:35   #12
Xlog
Supermodder
Xlog's Avatar
Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.Xlog is the Cheesecake. Relix smiles down upon them.
And what about monitor? You can't really save your work then you can't see anything.
"Modified" one UPS at work with 40AH SLA battery (battery is 4 times bigger than UPS ), lasts ~ 2H, although some cheaper UPS's have tendency to melt down (literally) during prolonged use.
__________________
http://x-log.deviantart.com/
Xlog is offline   Reply With Quote
Old 4th Jun 2013, 12:12   #13
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Why would a desktop pc need to be portable? What you gonna do move it desk to desk?
rollo is offline   Reply With Quote
Old 4th Jun 2013, 12:25   #14
Lance
Ender of discussions.
Lance's Avatar
Lance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming SaiyanLance is a Super Spamming Saiyan
This would be great at a LAN as well.
I was so embarrassed when my power supply blew at the I-series, taking out my GPU with it, and knocking out 10 desks connected to the fuse it was on. All their machines dropping like flies. If they'd had UPS's they at least could have said goodbye and shut down safely.
What was worse was that it was 2am and we didn't get running again till 9.
Also surely you'd need to power your monitor through the UPS as well for it to be any use?
__________________
Originally Posted by mrMonkeyChunks View Post
All hail lance, the lord of interior design.
Lance is offline   Reply With Quote
Old 7th Jun 2013, 11:29   #15
ferret141
Ultramodder
ferret141's Avatar
ferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyanferret141 is a Super Spamming Saiyan
Maybe it will come packaged like this
__________________
i5 2500K | Thermaltake Frio | 2x4GB Corsair Vengeance LP | ASUS P8P67 Pro | EVGA GTX680 2GB SC Signature 2 | Corsair AX1200 | 256GB OCZ Vertex 4 x2 R0 | 2TB WD Caviar Black | 3TB WD Red | SONY-NEC BD-5300S BD-RE | Silverstone Raven 2 Evolution (RV02E-BW USB3.0) | ASUS VG278H 3Dv2 | Win7 Ult. 64bit | Creative X-Fi Fatal1ty Platinum Champion Series | Speakers:Logitech G51 | Headset:Beyerdynamics DT770 Pro + ModMic 4.0 | Keyboard:Logitech G15 | Mouse:Logitech G9x
Plusnet | Loadout
ferret141 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
