Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Jun 2013, 12:24   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Fractal announces Arc XL and Mini 2, with 3x120mm full-thickness rads
New cases both feature space for 3 x 120mm, full-thickness radiators.
http://www.bit-tech.net/news/hardwar...mm-radiators/1
Meanmotion is offline   Reply With Quote
Old 4th Jun 2013, 12:54   #2
GFC
Multimodder
GFC has yet to learn the way of the Dremel
Weird. On their official site they say only up to 240mm rads.
GFC is offline   Reply With Quote
Old 4th Jun 2013, 13:07   #3
MightyBenihana
Do or do not, there is no try
MightyBenihana's Avatar
MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.
Is that bottom picture labeled correctly?
__________________
4670k/Asus 280x TOP/Asus Maximus Gene VI/8GB Corsair Vengence/Fractal Design Define Mini/Asus Xonar D2X/Samsumg 128GB 840 Pro/Samsung 500GB 840 Evo/Corsair AX 860/Be Quiet! Dark Rock Advanced/Dell U2412HM
MightyBenihana is offline   Reply With Quote
Old 4th Jun 2013, 13:40   #4
bawjaws
Mod Master
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
Yeah, looks like the bottom pic is the Node 304
bawjaws is online now   Reply With Quote
Old 4th Jun 2013, 17:48   #5
Aracos
Ultramodder
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
Wow that Arc mini 2 makes trying out watercooling at uni far too much of a temptation. I think I'm too scared of it to actually do it though =\
__________________
Originally Posted by Ubisoft CEO
Our clear goal today is to come more regularly with our top brands
Ragnarok: i5 750 @ 3200MHz | Titan Fenrir | MSI P55-GD65 | 8GiB Vengence 1600MHz CAS 9 | 1GiB 6950 DirectCU II | 60GB Crucial M4 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win 7 Pro | openSUSE
Aracos is offline   Reply With Quote
Old 5th Jun 2013, 02:18   #6
bleurrrrgh
What's a Dremel?
bleurrrrgh has yet to learn the way of the Dremel
They don't list the case mentioned in this article yet. The case shown is the Arc XL, while I will guess that you looked up the details for the Arc Midi 2, which only accepts 240mm radiators.
__________________
Fractal Design Define Mini / ASUS F1A75-M PRO / AMD A6-3500 / ATi HD 6670 / 2x4GB Corsair Vengeance / 2x Seagate Barracuda 250GB HDD / 3x Seagate Barracuda Green 2TB HDD
bleurrrrgh is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
