Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Jun 2013, 13:18   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Corsair and Intel's Computex OC Main Event
At Computex 2013 Corsair and Intel hosted an LN2 overclocking OC event with a difference.
http://www.bit-tech.net/hardware/201...c-main-event/1
Meanmotion is offline   Reply With Quote
Old 4th Jun 2013, 13:42   #2
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
What's with the blowtorch? Doesn't that kind of defeat the purpose of using ln2???
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP³ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 4th Jun 2013, 13:49   #3
Gurdeep14
Hypermodder
Gurdeep14's Avatar
Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.Gurdeep14 is the Cheesecake. Relix smiles down upon them.
I think they use it to keep the cpu from cooling down too much and therefore failing to boot? But I'm not 100% sure.
A GTX Titan with 5 8 pin PCI-E connections? seriously?
__________________
Intel Core i7 4790K | EVGA 780 Classified Hydro Copper 3GB | ASUS Maximus VII Hero Z97 | 32GB (4x8GB) 2400Mhz Corsair Vengeance Pro Series Red | Corsair HX1200i | ASUS Xonar D2X | 256GB Samsung 950 Pro M.2 NVMe | 250GB Samsung Evo 840 | 256GB Samsung 830 | 512GB Crucial BX100 | Silverstone TJ-07 | Acer 27" XB271HU (2K 144Hz G-Sync) Here
Gurdeep14 is offline   Reply With Quote
Old 4th Jun 2013, 14:41   #4
Grimloon
Hypermodder
Grimloon's Avatar
Grimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpit
Originally Posted by article
while the highest CPU frequency of the day of 6,984GHz earned Lin222 and Mad222 a share of $3000
I promise I'm not nitpicking here, I just had to pick my jaw up off the desk after reading that figure. Are you sure you didn't mean MHz rather than GHz as otherwise that's the best part of a 200,000% overclock!
Grimloon is offline   Reply With Quote
Old 4th Jun 2013, 14:52   #5
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Blow torch is to (quickly) counter cold-bugging to heat up the CPU block.
5x PCIe power connectors: Yup. Andre says it will pull over 1.5KW on its own, hence the need for 2x 1200W PSUs.
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 4th Jun 2013, 14:56   #6
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Think that comma should be a point - you are definitely nit picking.
__________________
FT03 Mini - 4770S - Noctua NH-L9i - GTX 1060 - Maximus Impact VII - 16GB DDR3 - 1TB NVME - SF600 - 27" AOC Agon AG271QG - Xonar U7 - Bassshaker - RAT3 - Majestouch Minila - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 4th Jun 2013, 14:58   #7
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
Normally you'll get two potential issues with temperature. (ignoring stuff like condensation etc)
Cold bug and cold boot bug.
Cold bug is where the chip/board will just not work below a certain temperature, simple as.
Cold boot bug is where the chip/board won't boot below a certain temperature, simple as.
Obviously if you're unlucky and there's a big difference between the CB and CBB, (say the CB is -180 and the CBB is -100) it means that if it does crash you need to heat up the pot quite a bit before you can carry on benching, a blow torch is a good way to speed that process up
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Will
My Parvum Systems build log - My flickr - My blog it'sfilmnotmovie - hwbot
I identify as mayonnaise-kin, think of it as white without the privilege.
GeorgeStorm is offline   Reply With Quote
Old 4th Jun 2013, 18:13   #8
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Awesome trophies & prizes too for the madderclockers.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 4th Jun 2013, 18:25   #9
Meanmotion
bleh
Meanmotion's Avatar
Corrected the frequency typo. Cheers guys.
Old 5th Jun 2013, 11:49   #10
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
1.5kw for 1 gpu on its own wowzers lol.
rollo is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
