Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Jun 2013, 08:55   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
AMD A10-6800K and A10-6700 (Richland) Reviews
We take a look at AMD's new Richland range of desktop APUs. Perfect for budget builders?
http://www.bit-tech.net/hardware/cpu...hland-review/1
Meanmotion is offline   Reply With Quote
Old 5th Jun 2013, 09:31   #2
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
wtb crossfire results with a 6670
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Old 5th Jun 2013, 09:35   #3
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
Very nice results for the 6800K. Although performance wise for general computing tasks arent the best, it does give us confidence that it has a well balanced system and lower costs if you want to do light casual gaming [minecraft, Left4Dead, Elder Scrolls, WoW] and internet related tasks. Ideal for cheap gaming rig for a younger person if they dont play demanding titles.
Its stepping in the right way for GPU/CPU sandwich which saves on time money and space.
LightningPete is offline   Reply With Quote
Old 5th Jun 2013, 09:36   #4
atc95
I have the upgrade bug!
atc95's Avatar
atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.atc95 is definitely a rep cheat.
is it still a 6670 required for dual graphics or have they updated it to the 7XXX cards?
__________________
PC: It's a work in progress, but isn't it always...
Check us out on twitch at https://www.twitch.tv/digitalbacongaming
atc95 is offline   Reply With Quote
Old 5th Jun 2013, 09:48   #5
law99
Custom User Title
law99's Avatar
law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.
Cool. I'd love to see total system power consumption for the dual core Richland. Are you going to be looking at it at all?
It is impressive that you can do some light gaming on these chips even if the res is down to what console gamers have been experiencing till now... i.e. 720p
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | soaking 1070 gtx | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | BenQ bl3200pt 2560x1440p
law99 is offline   Reply With Quote
Old 5th Jun 2013, 09:48   #6
Harlequin
Harlequin's Avatar
the only card it could go with would be an OEM only 76xx card
__________________
Old 5th Jun 2013, 10:46   #7
mystvearn
any-may
mystvearn's Avatar
mystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremelmystvearn has yet to learn the way of the Dremel
Will you get much performance by adding a discrete GPU with crossfire?
Was hoping this would be a an all in one solution for HTPC/Steam PC build at 1080p. Looks like I have to wait for the FM2+ CPU's or go with intel CPU's.
mystvearn is offline   Reply With Quote
Old 5th Jun 2013, 10:48   #8
murraynt
murraynt's Avatar
murraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for president
It would be nice to see a low end card in the graphs just as a reference.
__________________
l I5 4690k l MSI Z78I l 8GB corsair 1600mhz l Asus 5870 v2 l Fractal Node 304 l 60GB Crucial M4 l F3 1TB Spinner l 700Watt Thermaltake l Samsung IPS231 l
Steam: murraynt
murraynt is offline   Reply With Quote
Old 5th Jun 2013, 10:50   #9
mystvearn
any-may
mystvearn's Avatar
BTW, why is the year on the CPU "2011"?
Old 5th Jun 2013, 10:54   #10
Harlequin
Harlequin's Avatar
the AMD apu solutions are better all round chips than than the intel ones (ofc unless you start adding a discrete card in there) - but even so - I would like to see som crossfire numbers with this apu and a 6670
__________________
Old 5th Jun 2013, 10:55   #11
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
Why are they so poor in Cinebench?
Even my old 720 3 core Phenom 2 @3.8Ghz was faster.....
Hustler is offline   Reply With Quote
Old 5th Jun 2013, 10:58   #12
runadumb
Supermodder
runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.runadumb is a hoopy frood who really knows where their towel is.
Well thats a bit disappointing. No point in replacing my HTPC's A10 5800K with a 6800K.
Not that the performance was ever going to be a big leap but I had heard the iGPU was 30%+ faster and selling the 5800k would have made it a reasonably priced easy upgrade..
The 5800K does fine for 80% of what I want it to do so no big deal.
runadumb is offline   Reply With Quote
Old 5th Jun 2013, 11:03   #13
Harlequin
Harlequin's Avatar
im interested in which version of handbrake BT still use - its been updated a lot over the years and the latest version AMD do very well in.
__________________
Old 5th Jun 2013, 11:25   #14
rollo
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Are we likely to see a onboard Gpu battle with intels 5200hd iris vs this 6800 chip would be a fun battle and let us see how its going in onboard land.
rollo is offline   Reply With Quote
Old 5th Jun 2013, 11:42   #15
law99
Custom User Title
law99's Avatar
Does anyone else think they should abandon their old benchmark suite??? And focus on some newer ones. Performing edits with GIMP???? Not really fussed. Photoshop, more relevant.
And parroting what Harlequin is saying: is it all running latest versions? I mean, I'm not going to download an old handbrake am I really?
__________________
Old 5th Jun 2013, 11:58   #16
Harlequin
Harlequin's Avatar
have you seen the chip size for the iris pro ? its bigger than a gtx 680! honestly don't think we`ll see it in consumer anything.
__________________
Old 5th Jun 2013, 12:08   #17
rollo
Em anandtech has a review harle and its the chip going into the MacBook, so its def going to see a consumer launch.
Old 5th Jun 2013, 13:12   #18
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
it's here for the trinity vs iris pro : http://www.anandtech.com/show/6993/i...74950hq-tested
GuilleAcoustic is offline   Reply With Quote
Old 5th Jun 2013, 13:19   #19
CAT-THE-FIFTH
Modder
CAT-THE-FIFTH has yet to learn the way of the Dremel
Plus it is priced at $600+ and TR tested and it bumped power consumption of the CPU section(when idle) to desktop Core i7 4770K levels too,which is quite high for a desktop chip:
http://techreport.com/review/24879/i...ssors-reviewed
It is also a soldered on CPU too. There is also the Core i7 4770R which is also soldered on and looks to be very expensive.
Considering,the price disparity alone,it is a pointless test. Nvidia will sell you a GTX650 for around 100,but would they sell a GTX780 for that price...NO! They were made to hit those price points.
You might as well take the PS4 SOC and test it against it,and the former is still likely to cost less,ie,the whole system.
The CPUs the A10 should be compared to should be similar in price or at most slightly more expensive,so that means Core i3 CPUs and possible a very low end Core i5.
AMD has made them to hit that price point,and there are design considerations so they can hit that price.
The GT3e die is 350MM2 in size including 84MM2 of L4 cache,and the latter is produced on a more expensive low power version of the Intel 22NM process. The GT3 GPU section is estimated by Anandtech at 165MM2,which is larger than the GPU found in either the 28NM GTX650 or HD7700(around 120MM2) and this is on a 22NM process. Hence the GT3 is a massive GPU for an IGP in terms of transistors too,especially including the L4 cache,and probably costs a lot to make.
We also do not know how good the yields for the eDRAM are or even for the massive IGP section.
If you look at production IB Core i5 and Core i7 CPUs,the IGP actually increased in sized over prototypes:
http://www.chip-architect.com/news/2...es_Sandys.html
It seems to improve yields they started fusing off parts for the HD4000.
CAT-THE-FIFTH is offline   Reply With Quote
Old 5th Jun 2013, 13:34   #20
rollo
Wow at the AMD defend, the fact Intel a CPU company has made a Gpu that beats AMDs onboard stuff is crazy. Does not make alot of dif about its size we can't buy it its bga only, power consumption is less than the CPU + Gpu combo that's in the current MacBook Pro despite offering better performance if those graphs are accurate.
Never said it was an every day chip but looking at what apple and asus could do with it for ultra thin laptops is much more fun. Haswell equipped MacBook Pro retina with the battery life to boot to actually maybe game on the go.
Intel are probably making it in spare fabspace and selling them to Apple / Asus who have pushed this to begin with.
When I saw the benches on anandtech I thought it was a mistake but the other bench kinda confirmed it. AMDs 6800k has also struggled to improve on its 5800k igpu performance rumours of a 30% boost have been very wrong.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
