Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Jun 2013, 12:18   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
SilverStone demos pumpless watercooler
New closed-loop cooler requires no moving parts.
http://www.bit-tech.net/news/2013/06...-watercooler/1
Meanmotion is offline   Reply With Quote
Old 6th Jun 2013, 12:25   #2
themassau
Minimodder
themassau has yet to learn the way of the Dremel
couldn't this be used for small builds, or maybe servers whit lots of small lower power chips that are packed very dense.
themassau is offline   Reply With Quote
Old 6th Jun 2013, 12:32   #3
rpsgc
Multimodder
rpsgc's Avatar
rpsgc has yet to learn the way of the Dremel
I'm pretty sure a pump is much louder and obnoxious than a few low-RPM fans... Not everyone has deaf ears, some people actually enjoy silence.
So the idea has merit, provided it cools better than air cooling with similar low-RPM fans.
rpsgc is offline   Reply With Quote
Old 6th Jun 2013, 12:51   #4
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
Neat, even if it doesn't end up coming to market I'm liking the idea, one less part to fail if nothing else.
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Will
My Parvum Systems build log - My flickr - My blog it'sfilmnotmovie - hwbot
I identify as mayonnaise-kin, think of it as white without the privilege.
GeorgeStorm is offline   Reply With Quote
Old 6th Jun 2013, 12:57   #5
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Try looking for pump comparisons with indications of loudness.
I never found them, but then again I gave up on WC many years ago.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 6th Jun 2013, 13:16   #6
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
I was never entirely happy with the first H50's pump, it still has some noise. Glad to see Silverstone is innovating.
What I'd love is to see with this pumpless design is a flow sensor in the system, then have some fans spin up when water flow goes to certain level. Ta-dah! 100% automatic temperature sensing cooler.
To be honest, CPU idling up to 50c is nothing to worry about. Then under load, you can't really expect the 100w CPU to be cooled silently.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 6th Jun 2013, 17:59   #7
Alecto
Multimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
"Watercooler" without water that is in fact phase-change cooler, judging by the description provided.
Why not call it that ?
Alecto is offline   Reply With Quote
Old 6th Jun 2013, 18:45   #8
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
could they not use a thermoelectric heatpump to kickstart the cooling effect
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 6th Jun 2013, 20:55   #9
AiA
Multimodder
AiA has yet to learn the way of the Dremel
i don't think these type of devices are as good at cooling as devices with a pump
but might be good for systems that need some basic level of cooling, and needs quiet, reliable, and a compact solution
(maybe military applications, or TV solutions )
AiA is offline   Reply With Quote
Old 7th Jun 2013, 09:49   #10
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
So first you say it's a watercooler and then you explain it's just scaled up heat-pipe technology and doesn't use water. Big difference.
I seriously doubt this can be made any more efficient than a 'passive' heat-pipe based cooler. After all it's basically the same tech isn't it, maybe with different evaporation / dew points that's all.
Guinevere is offline   Reply With Quote
Old 7th Jun 2013, 12:32   #11
Stanley Tweedle
NO VR NO PLAY
Stanley Tweedle's Avatar
Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.
Heatpipes evaporate at much lower temps don't they?
__________________
One of us is dumb.
Stanley Tweedle is offline   Reply With Quote
Old 8th Jun 2013, 08:17   #12
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
Depends on several factors - diameter of the pipe, degree of the partial vacuum in the pipe, and the coolant used.
Given that they're showing clear, presumably plastic pipes of some sort, this isn't quite a heatpipe arrangement (which have a partial vacuum and some method of overcoming surface tension to allow the liquid to run back to the hot side).
Maybe, maybe not. It is somewhat like a scaled-up heatpipe arrangement like you find in a lot of laptops. Most of those use a radial fan to blow the hot air out. I think there would be a fairly healthy market for something that perform on par with high-end air cooling at least, and entirely passive and silent, which could turn out to be possible. I've recently had two PCs get a little flaky at work recently due to seized exhaust fans, and an entire office of PCs running 24/7 means there's no such thing as silence even after the HVAC system shuts down for the night.
I don't understand why everyone seems to be pissing on this - you think maybe companies shouldn't try to develop something new and different? Y'all should be grateful some smart nerd realized heatpipes would be good for PC applications or all our computers would sound like hairdryers. God forbid a company try to advance the tech for the good of us all.
fluxtatic is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
