Reply
Thread Tools View Mode
Old 6th Jun 2013, 15:01   #1
Zesti
Aluminium + file
Zesti's Avatar
Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.Zesti is a hoopy frood who really knows where their towel is.
Project Espada
Project Index
000 - Start of project
001 - More chassis parts cut + finished motherboard tray
002 - Micro-update: Black RAM
003 - Sanded chassis components + chassis test fit
004 - More chassis photos + thoughts about the theme and other things
Hi everyone!
After a long pause, I'm back with new worklog. This time it's going to be HTPC/Steambox, but I wanted something more original than your usual HTPC case. Hence I'm going to build it completely from scratch using only hand tools - Jigsaw will be the highest tech tool for this build. Material is mainly 3mm aluminium, but there might be some acrylic too for light effects.
Components are pretty basic for this project - Mini-itx board with some fast memory and an APU. Plus Noctua cooler and Intel SSD. Oh, and 150W PicoPSU too.
I gathered these parts over a long period of time so photos are a bit random.. But let's start with the APU:
If someone is wondering why I'm using 5800K and not the newer 6800K, it's because I bought this CPU several months ago. In fact the system has been in use for a while, but just without the case..
Here's the CPU cooler I'm using. I think it's not recommended for 100W TDP processors, but seems to work just fine since I've disabled turbo and undervolted 5800K quite bit.
And by the way, this is my first Noctua cooler ever! Pretty cool packaging too, huh?
It's a bit hard to see, but this cooler does have a couple heatpipes:
Rest of the components:
Components installed:
And yeah, I removed heatspreaders from the memory.. Orange color doesn't fit to this project and it was rather tight fit between the cooler and the PicoPSU.
Random beauty shot..
And system running:
Everything is working just fine.. Surprisingly fluid too, seems like APU+SSD+W8 is pretty nice combo.
And now onto the good part!
I started building with this easy part. Bending it was the hardest thing to do.. I don't have any fancy metal bending machine so I used a couple aluminium plates and hands instead.
Luckily this is the only part that needs bending in this project..
Next I started to cut sidepanels. Drawing is printed on paper which is then glued to the aluminium.
Looks pretty good..
After a while I had another sidepanel too and I couldn't help myself.. I just had to make a quick test fit to see how it looks.
And yes, it should become a computer case and not a spaceship.
More soon..
__________________
My projects: Z01 Vanilla | Z02 Embolado | Z03 ZOE | Z04 Eterne | Z05 Espada
Zesti is offline   Reply With Quote
Old 6th Jun 2013, 15:21   #2
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
This will be awesome project. I can allready see that.
And yes, it looks like Normandy. :P
Pranja is offline   Reply With Quote
Old 6th Jun 2013, 15:33   #3
Azariel
Multimodder
Azariel's Avatar
Azariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for president
Very nice start! Looking forward to see how this will unfold!
Azariel is offline   Reply With Quote
Old 6th Jun 2013, 23:04   #4
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on you
Looks very interesting. I´ll be watching
__________________
Tempel / Revelation / The Shrine / REDELUX / 4M
Follow me on facebook or Instagram
https://www.facebook.com/lovehultenau
@lovehulten
quizz_kid is offline   Reply With Quote
Old 8th Jun 2013, 03:53   #5
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Quoted for bad pun. Fantastic start.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 14th Jun 2013, 16:25   #6
Zesti
Aluminium + file
Zesti's Avatar
Thanks guys!
Just some misc photos of the progress.
Printed drawings:
Rough cut parts:
Motherboard tray sanded and ready to be painted. Now I just need to sand rest of the parts..
__________________
Old 14th Jun 2013, 17:12   #7
sixfootsideburns
modeteer
sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.
thats shweet.
sixfootsideburns is offline   Reply With Quote
Old 14th Jun 2013, 17:31   #8
Trance
Two steps forward, one step back
Trance's Avatar
Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.Trance is definitely a rep cheat.
Originally Posted by Zesti View Post
What is this witchcraft! Wish I could run fans with magic too! would save on electricity.
Also looking awesome, keep up the good work, love the efficient yet sleek design!
__________________
Coolermaster Cosmos 1000 :: Intel Core i7 4790K @ 4.6GHz :: Cooler Master Nepton 280L :: 16gb Kingston HyperX Fury DDR3 1866MHz :: Gigabyte Z97X-UD5H-BK :: Samsung 850 Evo 500GB :: Inno3D GTX770 2GB IChill HerculeZ X3 :: Superflower Leadex Gold 650W
Trance is online now   Reply With Quote
Old 14th Jun 2013, 18:48   #9
Evenge
Hypermodder
Evenge's Avatar
Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.
Oh yeah! Another one from you! Wish i could file as smooth edges as you do. Looks like I still have much to learn.
__________________
Projects: Discovery | Strobe
i5 2500K - 8GB - GTX570 - Win 7 - Ducky G2pro TKL Special Tactile Mix
Evenge is offline   Reply With Quote
Old 14th Jun 2013, 20:22   #10
sixfootsideburns
modeteer
If by magic you mean blowing into the fan to make it spin, then I'll bet your pretty damn magical too! Albeit pretty light headed if your trying to cool your PC that way
That was my first guess as to how he did it at least lol
Old 14th Jun 2013, 20:33   #11
Zesti
Aluminium + file
Zesti's Avatar
Thanks mate!
It's just Noctua's new wireless fan technology.. Cable in the photo is just optional for older systems.
__________________
Old 15th Jun 2013, 02:11   #12
lobster_johnson
Fear the Claw of Justice!
lobster_johnson's Avatar
lobster_johnson has yet to learn the way of the Dremel
This is fantastic so far! I love the shape of the motherboard tray.
Can't wait to see this come together!
lobster_johnson is offline   Reply With Quote
Old 18th Jun 2013, 15:57   #13
Zesti
Aluminium + file
Zesti's Avatar
Thanks!
Just some fine tuning of components.. After removing heatspreaders from the memory, brown sides of the PCB's really started to bother me. Little bit work with marker made them look much better:
__________________
Old 18th Jun 2013, 16:49   #14
sixfootsideburns
modeteer
its the small details that make or break it mate, nice touch with the black edges
Old 18th Jun 2013, 22:58   #15
Meelobee
Hypermodder
Meelobee's Avatar
Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.Meelobee is the Cheesecake. Relix smiles down upon them.
Buildlogs like this make me want to have 2 things. Crazy mod skills and a better cam..
Awesome work so far, the finish on the alu is amazing
Meelobee is offline   Reply With Quote
Old 1st Jul 2013, 17:18   #16
Zesti
Aluminium + file
Zesti's Avatar
sixfootsideburns, couldn't agree more.
Meelobee, thanks! Your modding skills seem fine to me and good cameras are cheaper than ever..
Sanding these parts took forever..
__________________
Old 3rd Jul 2013, 05:20   #17
Ozel
What's a Dremel?
Ozel's Avatar
Ozel has yet to learn the way of the Dremel
Looks really smooth so far..
Amazing work
Ozel is offline   Reply With Quote
Old 3rd Jul 2013, 09:21   #18
perplekks45
LIKE AN ANIMAL!
perplekks45's Avatar
perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.perplekks45 is the Cheesecake. Relix smiles down upon them.
A lot of talent, great ideas, and Cheaps' approval? I'm in.
__________________
The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far.
ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
Iä! Iä! Cthulhu fhtagn!
perplekks45 is offline   Reply With Quote
Old 3rd Jul 2013, 10:03   #19
Meelobee
Hypermodder
Meelobee's Avatar
lol @ 'No Step'
Amazing finish on the alu
Old 3rd Jul 2013, 10:22   #20
LegendaryScott
Trying to live up to the name
LegendaryScott's Avatar
LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.
Simply awesome.
Cant wait to see more
__________________
PROJECT#001 - ON EXTENDED HIATUS DUE TO NEW BABY!!
LegendaryScott is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
