Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Jun 2013, 19:16   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Hands-on with SilverStone's Tundra liquid coolers
SilverStone shows off its own liquid cooler, with an all-metal contact plate and mount and gorgeous radiator housing.
http://www.bit-tech.net/news/hardwar...ra-td02-td03/1
Meanmotion is offline   Reply With Quote
Old 8th Jun 2013, 20:58   #2
Noob?
Banned
Noob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming SaiyanNoob? is a Super Spamming Saiyan
Really looking forward to these, may swap out my H100 for one of these in the main build.
Got to say the finish does indeed look good on both the smaller and bigger version! Tempted, pricing and warranty will most likely be the decider on what I do.
*Awaits ETA!* Hint: Bit-Tech *Cough*
EDIT: Must say Guys/Girls you've done a great job of covering Computex! Thanks.
Noob? is offline   Reply With Quote
Old 8th Jun 2013, 21:18   #3
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Thanks! Honestly, you have no idea how much this means. Really appreciate it.
Baz is offline   Reply With Quote
Old 8th Jun 2013, 22:17   #4
thom804
Banned
thom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on youthom804 - may the hammer of Bindi be bestowed on you
Off topic, but just went to check the FT-04 after you mentioned it. Really not a fan of doors on cases and the trend continues. And they're orientated the mobo into a regular position, eurgh!
Still happy with my FT-02.
thom804 is offline   Reply With Quote
Old 8th Jun 2013, 23:27   #5
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
I should be getting one or more of these in for review asap
Dogbert666 is offline   Reply With Quote
Old 9th Jun 2013, 02:28   #6
SpAceman
Supermodder
SpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpit
Well not the regular position. They flipped it over 180 degrees.
Better than stock but not as good as the 90 degree orientation of the older Ravens and Fortresses.
__________________
i7 4770K | Asus Z87-Pro | 16GB Gskill DDR3-1866 | EVGA GTX 760
Silverstone Raven RV02 | Coolermaster V8 | Crucial M4 256GB | Corsair TX750
Dell U2412M | LG W2253TQ | Ducky DK9008 Pro PBT MX Cherry Greens | Naos 7000 | Logitech X-540 5.1 | Logitech G930
SpAceman is offline   Reply With Quote
Old 9th Jun 2013, 02:34   #7
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan.//TuNdRa is a Super Spamming Saiyan
I should get one of these. TuNdRa with a Tundra. But seriously; I hope these are good. If they prove to be; I'll be recommending these instead of the H80i/100i (Due to the backplate issue.)
Any news on when the new Silverstone Case designs are going to hit the market, anyhow?
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Strix Soar | 2X SLI Gigabyte Windforce 670 | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | 2x Hynix SL301 250GB RAID0 | 2x WD 3TB RED RAID0 | Lite-on Blu-ray ROM
Dell U2913WM | Sennheiser HD 518s | Microlab Solo8C Speakers | Logitech G13 | Ducky Legend (MX Blues) | Func MS-3
.//TuNdRa is offline   Reply With Quote
Old 9th Jun 2013, 20:41   #8
Noob?
Banned
As I've said, and I'll say it again, thanks!
Hint: I'll take the review samples if you need to clear some space, I'll store them in my rigs.
Old 9th Jun 2013, 21:01   #9
AverageNinja
Almost an EpicNinja
AverageNinja's Avatar
AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.
I like those AIOs! They look the part!
AverageNinja is offline   Reply With Quote
Old 9th Jun 2013, 21:11   #10
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
Oh my. Those are seriously sexy. I hope Silverstone also market the radiator individually, I'd love to have one in my loop.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 9th Jun 2013, 23:18   #11
Noob?
Banned
You've got a point there my friend!
Old 10th Jun 2013, 02:26   #12
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
I saw these mentioned somewhere else recently, possibly on Toms, and instantly they got my attention looks wise. I was already considering an AIO cooler for my future build and these look amazing, as does almost everything Silverstone makes. The thing I wish to bring up though is that on the other article, a few people mentioned that the type of tubing used is that of much older models from other manufacturers and isn't anywhere near as good as the tubing now used on almost all models. I'll look forward to a future review to see what you guys actually think of it when you get your hands on them.
Any idea of when we might possibly get a review?
__________________
SchizoFrog is offline   Reply With Quote
Old 10th Jun 2013, 10:51   #13
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
About time someone started doing some AIO coolers with a decent sized radiator, but it looks like Nanoxia are really going to turn the screw on Corsair etc.
Saw a video for a new case I think it was, and in it they had a 360mm AIO cooler which looks quite decent but they didn't comment on it and moved along very quickly.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
