Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th Jun 2013, 14:17   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Lian Li shows off PC-TU100, one of its smallest Mini-ITX cases yet
At Computex 2013, Lian Li showed off a range of new cases, including the tiny PC-TU100
http://www.bit-tech.net/news/hardwar...mini-itx-cas/1
Meanmotion is offline   Reply With Quote
Old 10th Jun 2013, 15:32   #2
GFC
Multimodder
GFC has yet to learn the way of the Dremel
To be honest, out of all the cases shown at computex - lianli are the ugliest.
If I go for ITX I don't want it to be bigger than my mid tower, that doesn't make any sense.
Having a humongous mITX case defeats the purpose of going mITX.
GFC is offline   Reply With Quote
Old 10th Jun 2013, 15:48   #3
djzic
Bokehlicious!
djzic's Avatar
djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.
I don't think you realise just how small those cases (except the D600) are. The TU100 is barely bigger then the motherboard itself!
__________________
PC: i5 4670k | Gigabyte GA-Z87MX-D3H | 8GB Crucial Ballistix Tracer 1866 | EVGA GTX 770 ACX SC
Parvum S1.0 | Samsung Spinpoint 1TB | OCZ Agility 3 120gb
Asus MW221U | Razer BlackWidow | Spyder2Express
Cam: Canon 400D | 35mm f/2.8 | Helios 44-2
djzic is offline   Reply With Quote
Old 10th Jun 2013, 15:49   #4
Aracos
Ultramodder
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
The PC-TU100 just makes me think of a PC-GameCube case
__________________
Originally Posted by Ubisoft CEO
Our clear goal today is to come more regularly with our top brands
Ragnarok: i5 750 @ 3200MHz | Titan Fenrir | MSI P55-GD65 | 8GiB Vengence 1600MHz CAS 9 | 1GiB 6950 DirectCU II | 60GB Crucial M4 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win 7 Pro | openSUSE
Aracos is offline   Reply With Quote
Old 10th Jun 2013, 15:59   #5
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
This is the PC-TU100 with the Asus GTX670 mini .... pretty impressive
GuilleAcoustic is offline   Reply With Quote
Old 10th Jun 2013, 18:46   #6
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Erm, the photo at the top of the news story is of the exact same case....
Baz is offline   Reply With Quote
Old 10th Jun 2013, 18:58   #7
GuilleAcoustic
Ook ? Ook !
Omg, I didn't see it. My brain is at the verge of melting today (fever reaching 40℃)
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
