Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th Jun 2013, 12:11   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Apple shows iOS 7 game controller plans
Devices to be made by Logitech and Moga, for both iPhone and iPad.
http://www.bit-tech.net/news/gaming/...roller-plans/1
Meanmotion is offline   Reply With Quote
Old 15th Jun 2013, 12:20   #2
dipzy
Supermodder
dipzy's Avatar
dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.
i hope these working with game like, GTA III and vice city as well as real racing and others.
dipzy is offline   Reply With Quote
Old 15th Jun 2013, 12:41   #3
Aracos
Ultramodder
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
I hope there's a way to charge the phone with the form fitting controller, if you're gaming for extended periods on a phone then you would probably like to play and charge at the same time.
__________________
Originally Posted by Ubisoft CEO
Our clear goal today is to come more regularly with our top brands
Ragnarok: i5 750 @ 3200MHz | Titan Fenrir | MSI P55-GD65 | 8GiB Vengence 1600MHz CAS 9 | 1GiB 6950 DirectCU II | 60GB Crucial M4 | Samsung F3 500GB | Samsung F3 1TB | Seasonic X-750 | X-Fi XtremeGamer | HAF932 | Win 7 Pro | openSUSE
Aracos is offline   Reply With Quote
Old 15th Jun 2013, 16:37   #4
XXAOSICXX
Hypermodder
XXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpit
You're gonna look like a proper tw@t when you're playing your game using the form-fitting version and you get a phone call :/
XXAOSICXX is offline   Reply With Quote
Old 15th Jun 2013, 16:52   #5
sotu1
Ex-Modder
sotu1's Avatar
sotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on you
That's a bit of a surprise...but welcome news. still, penetration and availability of these things is going to be low so not expecting any quality games to support this for a while.
__________________
Still alive
sotu1 is offline   Reply With Quote
Old 15th Jun 2013, 22:10   #6
knightyc
CPC refugee
knightyc's Avatar
knightyc has yet to learn the way of the Dremel
form fitting = psp
am I the only one sees that?
__________________
Intel Core i5 3350P - MSI B75IA-E3 - 16gb Corsair XMS3 1600mhz DDR3 - MSI Nvidia Gforce GTX660 oc 2gb - Cooler Master Elite 120 - OCZ Vertex Plus R2 60gb SSD Windows 7 Ultimate
knightyc is offline   Reply With Quote
Old 15th Jun 2013, 22:36   #7
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.
This could finally make FPS games playable on mobile devices. Sure controllers for ios have been out for a while, but if apple have a standard for them in app design, then I assume that it will make it easier for developers to use, and to reassure them that people will use it.
fdbh96 is offline   Reply With Quote
Old 16th Jun 2013, 01:52   #8
Aracos
Ultramodder
Aracos's Avatar
Originally Posted by knightyc
form fitting = psp
It's the PSVita not PSP.
__________________
Old 17th Jun 2013, 09:54   #9
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
They'll work with any game that is modified to use the new APIs Apple is adding to iOS 7. They will NOT work with any game that is not modified... not even a little bit.
No mention is made of the form-fitting controller offering extended battery life, suggesting this isn't something Apple will allow.
I disagree. Apple don't mention that adding battery extenders to form fitting controllers is disallowed and therefore it wrong to suggest that Apple will not pass controllers through the MFi scheme if they include an extended battery pack.
Guinevere is offline   Reply With Quote
Old 17th Jun 2013, 09:58   #10
Guinevere
Mega Mom
Guinevere's Avatar
Two types of controller will be available: one that wraps around iPhones and iPod touches and one that is a separate device for use with tablets.
It's actually three types of controller and Apple are not specific on what type of controller can be built for what type of device.
A standard form-fitting controller: An iOS device sits inside the controller and the player can access both the iOS device’s screen and the controller elements.
An extended form-fitting controller: An iOS device sits inside the controller and the player can access both the iOS device’s screen and the controller elements.
An extended wireless controller: A controller that wirelessly connects to an iOS device or Mac.
Source: Apple
So according to Apple you can even have a formfitting controller for an iPad not just smaller devices and such controllers can come in normal and extended flavours, differing by the shoulder buttons and analogue sticks.
As a game controller device I expect the 'extended' to be the norm but we may see cases with standard controllers built in too.
And you can use four external controllers with one device. Gaming through an Apple TV anyone?
Oh, you do all know these images are just illustrative of where the buttons should sit on a controller and are not blueprints on what these controllers will actually look like? Of course there will probably be controllers that mirror this layout but the exact config will be up those who build the controllers.
Old 17th Jun 2013, 10:01   #11
Paulg1971
Multimodder
Paulg1971's Avatar
Paulg1971 has yet to learn the way of the Dremel
I wonder if Sony will sue them because the buttons and sticks are the same layout, seems to work for apple.
Paulg1971 is offline   Reply With Quote
Old 17th Jun 2013, 12:19   #12
Stanley Tweedle
NO VR NO PLAY
Stanley Tweedle's Avatar
Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.Stanley Tweedle is definitely a rep cheat.
I envisage a future where corporations make profit solely on court battles over patents for non-existent hardware. They won't actually need to produce any hardware... just design something on paper then fight it out in court.
__________________
One of us is dumb.
Stanley Tweedle is offline   Reply With Quote
Old 17th Jun 2013, 20:47   #13
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
"Let's create a case with physical buttons on it to put the touchscreen device that fuelled the entire touchscreen device revolution of the past 6 years into"
Mmmmm, no. Not for me thanks.
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
