Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd Jul 2013, 10:57   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Lamptron CW611 Review
We review Lamptron's new automatic digital fan and water-cooling pump controller
http://www.bit-tech.net/hardware/coo...cw611-review/1
Meanmotion is offline   Reply With Quote
Old 3rd Jul 2013, 11:24   #2
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Cant beat a nice fan controller for a bit of bling, using software can be a PITA.
Would love to see more good 3.5″ sized controllers, put those redundant floppy drive bays to good use. But i guess an extra 2 odd inches makes all the difference.
Corky42 is offline   Reply With Quote
Old 3rd Jul 2013, 11:54   #3
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Thats what she said.....
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 3rd Jul 2013, 12:55   #4
Corky42
And they say size doesn't matter, blooming lairs
Old 3rd Jul 2013, 13:04   #5
SXRguyinMA
Multimodder
SXRguyinMA has yet to learn the way of the Dremel
No info on the control board circuitry? No close-ups of the components? Review seems thoroughly unfinished. Couple that with all of the ridiculous ads and bit-tech is going downhill FAST.
SXRguyinMA is offline   Reply With Quote
Old 3rd Jul 2013, 13:14   #6
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Hmmm. Personally I'd rather go with the BigNG - software controlled and waaaay more in depth customization - not only that it costs a tenner less (though you don't get a screen)
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 3rd Jul 2013, 14:08   #7
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.gcwebbyuk is a hoopy frood who really knows where their towel is.
I've been having issues with recent fan controllers (Corsair Link, NZXT Sentry Mix) and older fans. The new type of controllers seem to use a version of PWM rather than resistence. This causes old fans to click or tick. It would have been nice for this review to state what type of control this uses - or did I miss it?
gcwebbyuk is offline   Reply With Quote
Old 3rd Jul 2013, 14:39   #8
Luciel
Lamptron Europe
Luciel's Avatar
Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!Luciel - it's over 9000!!!!!!!!1!1!1!!!
The CW611 is not PWM gcwebbyuk
Luciel is offline   Reply With Quote
Old 3rd Jul 2013, 15:07   #9
gcwebbyuk
Dib Dabbler
gcwebbyuk's Avatar
Can you confirm it works with all fans? I mainly use Scythe S-Flex E.
Old 3rd Jul 2013, 15:20   #10
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
The vast majority of our readers are only concerned with the product's features and how well it works when it comes to fan controllers and if you'd bother to click through to the larger image of the PCB you'd get a close up anyway. We haven't gone into specific circuitry details on any fan controller review that I can remember so there's no hill to go down tbh.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 3rd Jul 2013, 15:21   #11
Combatus
Moderator
Combatus's Avatar
It will work with any 3 or 4-pin fan so long as it doesn't have a 4-pin molex connector.
__________________
Old 3rd Jul 2013, 15:34   #12
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 3rd Jul 2013, 15:34   #13
MightyBenihana
Do or do not, there is no try
MightyBenihana's Avatar
MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.
I was looking on Lamptron's partner section on the forum and came across this. It is difficult to find a nice looking and functional fan controller for more than 5 fans so I was very interested in this. I'm glad it got a decent score, I think I have found the fan controller for my upcoming build.
However, I am also very interested in their FC Touch, any chance of a review of this too?
__________________
4670k/Asus 280x TOP/Asus Maximus Gene VI/8GB Corsair Vengence/Fractal Design Define Mini/Asus Xonar D2X/Samsumg 128GB 840 Pro/Samsung 500GB 840 Evo/Corsair AX 860/Be Quiet! Dark Rock Advanced/Dell U2412HM
MightyBenihana is offline   Reply With Quote
Old 3rd Jul 2013, 15:37   #14
siliconfanatic
Johny-come-Lately
Unfortunately I'm gonna need about twice the channels for what I've got in store. Still a good controller though.
__________________
Old 3rd Jul 2013, 15:48   #15
Luciel
Lamptron Europe
Luciel's Avatar
As long as the amount of fans you use per channel do not go over 36w/2.5A, yes.
This is correct, the fan connecters do not have surrounding plastic precisely so you can use 4pin (PWM) fans, you just leave the pwm pin out of the equation and let the CW611 do the controlling for you based on temps. While not the best solution remember that even with a 4-pin molex you can use a molex to 3pin adaptor to use the fan.
How many fans did you have in mind using and what fans? Remember you can use splitters as long as the combination of fans does not go over 36w/2.5A per channel
Old 3rd Jul 2013, 16:38   #16
siliconfanatic
Johny-come-Lately
Gentle typhoons for the most part. If that goes too far over budget I'll end up getting Sickleflows and removing the led's. And counting the radiators in push/pull, and the case fans, I'd say about 20 fans, Give or take two.
__________________
Old 3rd Jul 2013, 17:28   #17
Luciel
Lamptron Europe
Luciel's Avatar
Tell you what, tell me the specific model and Ill look in to it for you
Old 3rd Jul 2013, 17:32   #18
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
Ridiculous ads? Oh, you must be one of those weirdos who don't use an adblocker. How quaint
phuzz is offline   Reply With Quote
Old 3rd Jul 2013, 18:44   #19
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
Well for me I think the review is spot on. Its a fan controller, looks nice, customisable, very good load per channel.... Not sure that indepth ripping the PCB to bits and putting up pictures of the traces would help IMO SX'what ever your name is'.
Beautiful and well engineered. If I ever get back in to watercooling, will certainly consider one of these.
Blackshark is offline   Reply With Quote
Old 3rd Jul 2013, 19:44   #20
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
I look at the screen and I'm right back on my Atari playing Asteroids
AlienwareAndy is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
