Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Jul 2013, 09:01   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
SilverStone Sugo SG10 Review
SilverStone's SG09 gets kitted out with a gorgeous aluminium front panel, and the SG10 is born.
http://www.bit-tech.net/hardware/cas...-sg10-review/1
Meanmotion is offline   Reply With Quote
Old 8th Jul 2013, 09:25   #2
Sim0n
rm -rf /
Sim0n's Avatar
Sim0n has yet to learn the way of the Dremel
Pic 16 on page 4 seems to link to a 404 ;
http://images.bit-tech.net/content_i...ew/sg10-16.jpg
Looks like the link should end sg-16b.jpg as that loads
Sim0n is offline   Reply With Quote
Old 8th Jul 2013, 09:38   #3
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
Cheers, fixed
Dogbert666 is offline   Reply With Quote
Old 8th Jul 2013, 09:39   #4
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Well, it's prettier that the SG09, but I don't think it's worth the extra money for just a bit of bent mesh.
Still amazed at the HDD mounts behind the CPU area, and lack of airflow back there.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is online now   Reply With Quote
Old 8th Jul 2013, 11:59   #5
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Yes, there's a lack of airflow, but SSDs need minimal, if any, cooling and HDDs are designed to run at reasonably high temps (40C-50C) without any serious increase in failure rates outside of 3-years.
Check out Google's nifty study. It's from way back in 2007, but still relevant. http://static.googleusercontent.com/...k_failures.pdf
Baz is offline   Reply With Quote
Old 8th Jul 2013, 12:05   #6
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Hey BT. I am really interested in this case. So thanks for the review. Just one thing, you say the optical drive is external in the feature list at the bottom of page 1. Surely it is an internal drive?
Also, is there any way to find out how the use of an AIO CPU cooler such as the H80i impacts on airflow and then cooling of the system as a whole? Does it restrict the airflow out of the rear fan and then cause the interior to heat up a little more or does it enable the top fan to cool more effectively as the heat from the CPU isn't transferred to the air inside the case? Or does it make no real difference?
__________________
SchizoFrog is offline   Reply With Quote
Old 8th Jul 2013, 12:26   #7
SchizoFrog
I *am* a Dremel
*cough, cough* 'inside' of 3 years Baz.
__________________
Old 8th Jul 2013, 12:31   #8
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Hi SchizoFrog. By external it only means that you can access the drive externally (i.e. by putting your discs in and out!), but yes the drive itself is still contained internally.
I'd love to help you out on the AIO thing with a proper confirmation, but I won't have time to rebuild everything with the H80i in place just to rerun the tests, sorry. That said, with an AIO cooler drawing heat away from the CPU, I can't see why there'd be an issue. The Air Penetrator fan really is quite good, and with the coverage it provides there should still be ample airflow for the VRMs and memory, and the limited airflow that does find its way to the HDDs and SSDs will be unaffected. The only issue could be the GPU, although the air from the top fan is directed at its backplate anyway - provided the front 120mm remains mostly unobstructed and you have even a half decent GPU cooler fitted, there shouldn't be any issues
Old 8th Jul 2013, 12:43   #9
SchizoFrog
I *am* a Dremel
Thanks Dogbert666. It seems rather counter intuitive to have an intake fan blowing downwards at the back of the system, directly in front the rear exhaust fan, surely most of the air would be sucked straight back out of the case?
That said, maybe I shouldn't worry about the seeming logic of it and just rely on the cooling figures.
__________________
Old 8th Jul 2013, 12:52   #10
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Does it allow triple slot GPU cooling?
AlienwareAndy is offline   Reply With Quote
Old 8th Jul 2013, 12:56   #11
Dogbert666
bit-tech Staff
Dogbert666's Avatar
No worries. I agree it does seem rather counter intuitive, but equally the main components the fan is designed to cool should still have plenty of concentrated airflow around them.
Naturally this is all speculation, but I personally can't see any glaring reasons why such a set-up wouldn't work out.
Old 8th Jul 2013, 12:57   #12
David
RIP Tel
David's Avatar
Yes, but a HDD behind the CPU area with no airflow can reach and exceed 50 degrees in minutes.
__________________
Old 8th Jul 2013, 13:01   #13
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Yep! Four expansion slots in total.
Old 8th Jul 2013, 13:58   #14
AlienwareAndy
Banned
Doh what a tremendous brain fart that was I thought it was ITX.
Derp de derp derp
Mind you, in defence of my derpness it is very small
Old 8th Jul 2013, 15:10   #15
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Derp de derp derp
Haha. When I first the SG09 before this one I thought it was an ITX case too!
Old 8th Jul 2013, 21:03   #16
Er-El
Supermodder
Er-El's Avatar
Er-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the DremelEr-El has yet to learn the way of the Dremel
The fact it has no usb 2.0 ports makes this very compelling.
Er-El is offline   Reply With Quote
Old 9th Jul 2013, 07:03   #17
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
It's also designed such that your PSU intake fan can face into or out of the case, but the latter is naturally the better choice
Yes, why use the PSU to remove warm air for free? Just because they're designed for it?
Pfwah, humbug.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 9th Jul 2013, 07:45   #18
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
Pfwah, humbug.
If you've got the option, though, there is something to be said for letting the PSU breathe fresh air. With as many fan mounts as this has, I think I'd just as soon let the PSU breathe free and let all the dedicated fans handle the hot air inside the case.
fluxtatic is offline   Reply With Quote
Old 9th Jul 2013, 17:15   #19
SchizoFrog
I *am* a Dremel
Pfwah, humbug.
Using the PSU to exhaust air from the case would affect airflow as the heat would be pulled in two directions, towards the front by the PSU and towards the rear by the rear fan while also being pushed back down in to the case by the large fan in the roof. This would surely cause dead air spots of whirling hot air and would suffocate components.
__________________
Old 10th Jul 2013, 08:11   #20
Xir
Xir's Avatar
Hmmm, the case has a lot of mesh on the lower side and botton, wouldn't fresh air draw in there if you have more exhaust?
__________________
SN25P
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
