Old 9th Jul 2013, 13:39   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Fuse Review
EA's latest shooter provides little other than polish.
http://www.bit-tech.net/gaming/2013/07/09/fuse-review/1
Meanmotion is offline   Reply With Quote
Old 9th Jul 2013, 16:04   #2
tad2008
Supermodder
tad2008 has yet to learn the way of the Dremel
I get the feeling you are so unimpressed with Fuse, lol, now I could have misread things here and maybe I missed something... :P
tad2008 is offline   Reply With Quote
Old 9th Jul 2013, 17:18   #3
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
EA strikes again. EA is fast becoming a symbol of poor games and over-inflated rip off franchises.
__________________
SchizoFrog is offline   Reply With Quote
Old 9th Jul 2013, 17:39   #4
tad2008
Supermodder
Fast becoming? Sadly they have been on a downward spiral for years with only the odd title to brighten our lives.
Old 10th Jul 2013, 07:48   #5
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Bit like Activision then.
To be honest all the publishing companies are nearly as bad as EA, but you only ever hear EA being bashed.
I myself have never had any major issues with EA and when I did have a issue I just gave them a call, and had the issue resolved plus given some discount codes.
Now if I had a issue with something that Activision published I wouldn't be able to call them since it's nearly impossible to contact them to speak to someone, other than by email which they don't always deal with.
I am pretty sure the game would have been given the same score etc if it was Activision that published it.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 15th Jul 2013, 13:35   #6
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Into the mid-summer release dumping ground it goes. So long Fuse.
Baz is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
