Old 10th Jul 2013, 09:58   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
In-Win G7 Review
In-Win tones down the plastic for its latest budget chassis, but is it any good?
http://www.bit-tech.net/hardware/cas...in-g7-review/1
Meanmotion is offline   Reply With Quote
Old 10th Jul 2013, 10:14   #2
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
I don't understand case designers.
It comes with dust-filters, but at the same time half the side panel is open without a filter, letting in dust and letting noise out.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 10th Jul 2013, 10:22   #3
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
Yeah, it's crazy how often side panel fan mounts in particular are left without dust filters or even blanking plates.
Dogbert666 is offline   Reply With Quote
Old 10th Jul 2013, 10:40   #4
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Any case with a side window/fan is an immediate no for me personally.
Corky42 is offline   Reply With Quote
Old 10th Jul 2013, 11:17   #5
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
It's an In-WIn Mana 137 with a face lift and a 30% price hike.
+1 on the gaping side panel with no blanking plate or filters.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is offline   Reply With Quote
Old 10th Jul 2013, 11:54   #6
Dogbert666
bit-tech Staff
Dogbert666's Avatar
As a reviewer I have to acknowledge the benefits side fan mounts can bring to GPU cooling, for example, but personally I'd have to agree as well, although I'm not necessarily put off by windows. I'd rather cool my graphics card with slow spinning front and bottom fans, which target most cards' intake areas better anyway.
Old 10th Jul 2013, 12:15   #7
Meanmotion
bleh
Meanmotion's Avatar
Just to emphasise that point: http://www.bit-tech.net/hardware/201...nvestigation/1
Our tests comprehensively proved that the side fan was the single most effective for fan configurations of four or less.
Old 10th Jul 2013, 13:08   #8
Corky42
Yea i agree for a out of the box setup a side fan would be best, although sometimes with a little modding you can get better cooling, it all depends on the case and what your willing to change,
Old 10th Jul 2013, 16:03   #9
LordPyrinc
Legomaniac
LordPyrinc's Avatar
LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.
From personal experience, side panel fans definitely make a measurable difference in GPU cooling especially in an SLI configuration. While plexi-glass side panels show off the guts nicely, I prefer being able to mount a side panel fan.
A buddy of mine is going to replace the stock coolers on my old 550s soon and I'm curious to see what the temps are like on those once he's got it up and running. Seems like I've gone as far as I can with fan cooling without replacing the stock coolers on my 660s. I went from an Antec Three Hundred to a HAF 922 and it definitely made a big difference with the larger fans. I've got two 200mm fans pushing and a 120mm and a 200mm pulling air out right now.
__________________
Intel i7-920 @ 2.66GHz - Corsair Vengeance 16GB DDR3 @ 1600MHz - Windows7 64bit - Firestrike Ultra Score 6645
2 x 150GB WD VelociRaptor HDs (RAID 0) - 1TB WD 7200 rpm HD - 60GB OCZ SSD - 1TB WD External USB HD
2 x NVidia Founders Edition 1070 GTX 8GB (SLI HB Bridge) - Razer BlackWidow Ultimate - Logitech Proteus Spectrum G502
Corsair Polaris MM800 - Cooler Master HAF 922 - Thermaltake Smart M 850W - 40" Samsung UHD 640D LED Display (3840x2160)
LordPyrinc is offline   Reply With Quote
Old 11th Jul 2013, 07:59   #10
Xir
Xir's Avatar
Correct as that may be, an unfiltered side fan negates all other filters.
__________________
SN25P
Old 15th Jul 2013, 15:59   #11
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
I have 4 side fans, do I win a medal?
Coolermaster Stacker FTW
LightningPete is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
