Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 17th Jul 2013, 13:27   #1
Kronos
As simple as that,well I never
Kronos's Avatar
Kronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming Saiyan
Uninstalling the NVIDIA HD audio drivers
I am having a problem with my EVGA GTX 660 and it has been suggested I uninstall the Nvidia Audio driver but on restart it reinstalls. Can I stop this somehow. It might not be the cause of my problems but worth a try.
http://forums.bit-tech.net/showthread.php?t=261600
__________________
Carbide 240/Asus Z170M plus/I5 6600K /Avexir Core Blue Series 16GB /AXP 200 Muscle /Gigabyte FE 1080/256GB Crucial m4/1x1TB & 2TB HDD/ SST-ST60F-P PSU/Dell U3415/CM TK White (browns)/Logitech G400s/.
Silverstone GD05B/ MSI B751A-E33/G840/2x2GB Crucial Ballistix DDR3 Red LED/GT 260/Kingston 60GB/500GB WD/Corsair CX500/Dell U2711/ E Element Chroma KB /Logitech M518.
Kronos is offline   Reply With Quote
Old 17th Jul 2013, 14:12   #2
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
Driver sweeper?
The issue is that the audio controller is a hardware device that cannot be disabled. There might be the option to soft disable it in device manager but only if you can find it.
Right now the driver will stay on your PC until you forcibly remove it, so rebooting will only make it put the driver straight back on. IIRC Driver sweeper can take it out (in safe mode).
AlienwareAndy is offline   Reply With Quote
Old 17th Jul 2013, 14:22   #3
RedFlames
...is volatile under pressure.
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
Reinstall the nVidia driver, custom install -> untick 'HD Audio Driver' and tell it to do a Clean Install while you're there...
__________________
You wouldn't really die of anything, in the traditional sense. You would just stop being biology and start being physics.
RedFlames is offline   Reply With Quote
Old 17th Jul 2013, 14:33   #4
Kronos
Kronos's Avatar
Just to clarify, are you talking about the GPU driver and if so am I to remove said driver then reinstall the GPU driver without the audio part?
__________________
Old 17th Jul 2013, 14:39   #5
flame696
Terminating People Since 1980....
flame696's Avatar
flame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyan
thats correct Glenn remove the old driver and reinstall the driver but this time use custom install and untick Audio driver
__________________
flame696 is offline   Reply With Quote
Old 17th Jul 2013, 15:28   #6
Kronos
Kronos's Avatar
Cheers Shaid, no luck. Looks like an RMA is on the cards.
__________________
Old 17th Jul 2013, 15:40   #7
flame696
flame696's Avatar
Really sorry Glenn
__________________
Old 17th Jul 2013, 15:50   #8
Kronos
Kronos's Avatar
Really sorry Glenn
These thing happen. Shouldn't be a problem,just a nuisance.
__________________
Old 17th Jul 2013, 15:52   #9
AlienwareAndy
Banned
Another heat wave victim?
I feel your pain man, I lost my SSD last night
Old 17th Jul 2013, 16:04   #10
erratum1
Banned
erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.erratum1 is definitely a rep cheat.
Sure is hot in my spare room i've taken to pointing a desktop fan at it, too hot to sit and play games.
erratum1 is offline   Reply With Quote
Old 17th Jul 2013, 16:08   #11
Kronos
Kronos's Avatar
No heatwave in Edinburgh or my flat, because of it's position I don't see much of the sun in my flat.
__________________
Old 17th Jul 2013, 16:11   #12
RedFlames
RedFlames's Avatar
Originally Posted by KRONOS View Post
No heatwave in Edinburgh or my flat, because it's Scotland I don't see much of the sun.
FTFY
__________________
Old 17th Jul 2013, 16:43   #13
Kronos
Kronos's Avatar
FTFY
Most kind of you.LOL.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
