Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Jul 2013, 10:33   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Roccat launches Kone Pure Optical mouse
Swaps laser sensor for LED version.
http://www.bit-tech.net/news/hardwar...pure-optical/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 26th Jul 2013, 10:49   #2
Phil Rhodes
Hypernobber
Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.
I'd love to know why they think lasers help.
Phil Rhodes is offline   Reply With Quote
Old 26th Jul 2013, 11:08   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
Eh? The Roccat Kone Pure Optical doesn't use lasers; the entire point is that it uses an LED-based optical sensor instead. The Roccat Kone Pure uses a laser, as the article makes abundantly clear.
As for why lasers help (or hinder): a laser-based light source on an optical sensor allows for much finer-grained accuracy. Just look at the figures: the Roccat Kone Pure Optical, with its LED-based light source, tops out at 4,000dpi; the Roccat Kone Pure, which uses a laser-based light source, hits 8,200dpi. That's more than double the resolution.
Some don't like the 'feel' of a laser-based sensor, however, and would prefer the old-style LED light source. It's for these that Roccat has built the Kone Pure Optical.
__________________
Old 26th Jul 2013, 12:17   #4
Phil Rhodes
Hypernobber
Sure, absolutely, the question was more "why does it ever make a difference". I appreciate they have larger resolution figures, but it isn't clear to me why that's necessarily associated with the character of the illumination. Modern optical mice frequently use something like a 4x4 or 8x8 pixel "camera" looking down at the surface on which the mouse is running. I suppose you could take the position that the finer light source of a diode laser casts sharper shadows from the details on the desktop but the resolution of the thing is ordinarily more down to the detector than the emitter.
After all, a diode laser pretty much is an LED, just one about the size of a bacterium.
Old 26th Jul 2013, 12:45   #5
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
The reason the DPI is greater with LASER mice is because of the rectilinear quality of a LASER beam compared to the highly divergent nature of all other types of light sources, including non LASER LEDs.
Corky42 is online now   Reply With Quote
Old 27th Jul 2013, 11:48   #6
Xir
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Back to the roots.
Next year, a direct-kinetic-driven mouse for those hardcore gamers out there...you know, with a rubber ball in it ;-)
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 27th Jul 2013, 22:09   #7
lankymorley
What's a Dremel?
lankymorley has yet to learn the way of the Dremel
As a low sensitivity gamer, I've never been satisfied with the tracking of a mouse with a laser sensor. Optical all the way!
lankymorley is offline   Reply With Quote
Old 29th Jul 2013, 22:10   #8
jimmyjj
Hypermodder
jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.jimmyjj is the Cheesecake. Relix smiles down upon them.
Voice command is the way to go:
"Left a bit, right a bit - Fire!".
__________________
Asus P8P67, 2500k (stock), 8GB vengeance, GTX770 (EVGA AC SC), U2412M, Intel 330 180GB SSD
jimmyjj is offline   Reply With Quote
Reply
Tags
gaming mouse, kone pure, kone pure optical, mouse, optical mouse, roccat, roccat kone pure optical
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
