Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Jul 2013, 09:22   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Zyxel PLA 5205 600Mbps Powerline Adaptor Review
We check out Zyxel's latest powerline adaptors which are rated at a lofty 600Mbps.
http://www.bit-tech.net/hardware/net...line-adaptor/1
Meanmotion is offline   Reply With Quote
Old 30th Jul 2013, 11:52   #2
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
Internet speeds are done in Megabits per second. Ethernet switches are rated in mega/giga bits per second and the device being reviewed is rated in megabits per second. Surely you could follow suit and use bits instead of bytes.
theshadow2001 is offline   Reply With Quote
Old 30th Jul 2013, 12:05   #3
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
That is true but pretty much every networking product we've ever reviewed has been done so in bytes - it's just easier for people to understand for example how long it will take to transfer a 1GB file if you talk in bytes rather than bits. However, where it's relevant, such as dealing with super-fast broadband speeds and potential limitations with slow powerline adaptors, then we do talk in bits.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 30th Jul 2013, 18:17   #4
enciem
Multimodder
enciem's Avatar
enciem has yet to learn the way of the Dremel
I agree it's better t show in bytes. I also think trading standards should get them to rate the speeds more realistically.
enciem is offline   Reply With Quote
Old 6th Aug 2013, 09:32   #5
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
When you compare to the Zxyel 500Mb version you are comparing the ones you reviewed which were the low end 4211 with 100Mb ethernet which caps its full speed rather than the comparable 500Mbps Zyxel the 4205/4215 which has a 1Gb ethernet port and of course cost a bit more but performs better.
sandys is offline   Reply With Quote
Old 9th Aug 2013, 16:30   #6
ModSquid
Supermodder
ModSquid's Avatar
ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.ModSquid is definitely a rep cheat.
How do these guys manage to get even close to the 500Mbps they quote when testing shows real-life to produce a third of that? What on God's Green is their lab setup?
ModSquid is offline   Reply With Quote
Old 9th Aug 2013, 17:54   #7
sandys
Mod Master
Multiple streams gets you someway there.
Old 10th Aug 2013, 08:06   #8
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
Horrendous them quoting such speeds. Its worse than BT saying a few years ago, we'll give you 20mb broadband (but really give you 2). However these are still FAR better than wifi and much less hassle than routing Cat5 all around the side of your house walls under the carpet, especially if said PC or media box is opposite end of house.
I just dont see the need for 600mbps ones for the general user though, my 200 kit from belkin does all my internet needs including HD streaming / gaming / browsing, with all my rated broadband speed ( 72mb talktalk line )
LightningPete is offline   Reply With Quote
Old 13th Aug 2013, 00:18   #9
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
So, in good conditions this is just like 100Mbps, yet they still sell it labeled as "600Mbps".
What a bad joke!
Gradius is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
