Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Jul 2013, 10:06   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Asus responds to AiCloud security criticisms
Claims it reacted as quickly as possible.
http://www.bit-tech.net/news/hardwar...-aicloud-fix/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 30th Jul 2013, 10:16   #2
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
we have an upgrade notification on the firmware page to inform our users to upgrade their firmware immediately
To be honest, this doesn't work for me. I had RT-N66U on 3.0.0.4.260 firmware, did press Check to check for newer firmware, says "it's on the latest version". Checking download page, and i see that the current non-beta firmware version is 3.0.0.4.372.1393. So the notification doesn't really work .
faugusztin is offline   Reply With Quote
Old 30th Jul 2013, 11:18   #3
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
Exactly the opposite for me, I had an update ready for my RT-AC66U very soon after this story broke. Asus tend to be quite regular with firmware updates, and Merlin's customisations means that I have no need to switch to DD-WRT.
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 30th Jul 2013, 22:07   #4
ffjason
Multimodder
ffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysisffjason can run Crysis
That would be because ASUS work closely with DD-WRT & OpenWRT to create their firmware from what I hear. In fact the original ASUS router shipped with DD-WRT firmware included
ffjason is offline   Reply With Quote
Old 1st Aug 2013, 09:37   #5
r3loaded
Ultramodder
r3loaded's Avatar
Ah that would explain a lot! Tbh, I think these open source router firmwares are so good that others should just follow Asus's lead and build off them too.
__________________
Reply
Tags
aicloud, asus, kyle lovett, network, networking, router, security, sonam lama, upnp, vulnerability
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
