Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 1st Aug 2013, 09:17   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Lian Li PC-Q28 Review
We take a look at Lian Li's tiny mini-ITX case that can house an ATX PSU, dual-slot 29cm graphics card and 5.25in drive.
http://www.bit-tech.net/hardware/cas...c-q28-review/1
Meanmotion is offline   Reply With Quote
Old 1st Aug 2013, 09:58   #2
koaschten
Minimodder
koaschten has yet to learn the way of the Dremel
http://images.bit-tech.net/content_i...-1280x1024.jpg
Why didn't you properly seat the PSU?
koaschten is offline   Reply With Quote
Old 1st Aug 2013, 10:27   #3
phinix
RIP Waynio...
phinix's Avatar
phinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyanphinix is a Super Spamming Saiyan
I like it. VERY nice case. Lots of potential for modding. Watercooling too. Imagine it with small ST45 PSU.... nice....
__________________
7500|1080Ti|2x 500GB SSD|2TB HDD|Z270 ITX|16GB RAM|SFX 600W|Philips 40" 4K BDM4065UC
2x Novatouch|Varmilo VA69M greens|Zowie EC2 Evo|X52 PRO|DK2
::: Phinix Cube ::: Phinix Nano Tower ::: Phinix Aurora ::: Phinix Chimera ::: Phinix Retro :::
star citizen ::: CMDR Phinix 325A LTI
phinix is offline   Reply With Quote
Old 1st Aug 2013, 11:04   #4
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
So in short it is PC-Q08 with a different front (PC-Q28 covered the front fan, the fan has to draw the air from the bottom instead; the ports got relocated to the side), board mount holes are on two aluminum bars instead of the side panel and they added the bottom HDD mount thingy, which gets thrown out on at first build anyway . And they didn't fixed the biggest issue with these cases - 8 of those damn small screws per panel .
faugusztin is offline   Reply With Quote
Old 1st Aug 2013, 13:53   #5
Floyd
Wire Twister
Floyd's Avatar
Floyd has yet to learn the way of the Dremel
This one only has 6 retarded screws on the side panel!
Its one thing I hate about my only Lian Li case.
Floyd is offline   Reply With Quote
Old 1st Aug 2013, 15:53   #6
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Unfortunately one of the threads stripped on the PSU which meant the vertical mount (and gravity) were enough to make it droop ever so slightly. We only noticed it was slightly out of alignment afterwards. Sorry about that! Should not have impacted on the cooling results at all though.
As for screws - it's just one guys - the others hold the mounting pins in place
4th para -
Thankfully it's just a single cross-head screw you have to contend with...
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 1st Aug 2013, 16:07   #7
Meanmotion
bleh
Meanmotion's Avatar
4th para -
Apologies all round. I mistakenly changed this during subbing.
Old 1st Aug 2013, 17:40   #8
abezors
Lurking since '08
abezors's Avatar
abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.abezors is definitely a rep cheat.
You're aware the case is "a fingerprint magnet" but didn't think to wipe them off for the photos! Looks like someone's been eating Doritos before the shoot...
abezors is offline   Reply With Quote
Old 1st Aug 2013, 19:28   #9
SuicideNeil
Banned
SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.
Last paragraph:
the cooling on offer isn't really up to scratch and you're system will be hotter...
Your*
SuicideNeil is offline   Reply With Quote
Old 1st Aug 2013, 23:02   #10
wafflesomd
I *am* a Dremel
wafflesomd's Avatar
wafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysiswafflesomd can run Crysis
As far as cooling design goes that case looks awful. They should have flipped the psu and added air intake on the side panel.
wafflesomd is offline   Reply With Quote
Old 2nd Aug 2013, 09:40   #11
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
If I were building a low- to medium-end build, why the hell would I splash out on a Lian-Li case?
fluxtatic is offline   Reply With Quote
Old 2nd Aug 2013, 09:58   #12
faugusztin
That case exists. It is called PC-Q08 :
http://www.lian-li.com/en/dt_portfolio/pc-q08/
http://www.bit-tech.net/hardware/cas...pc-q08-review/ (not sure why was the side panel turned around in that review)
Old 2nd Aug 2013, 19:51   #13
wafflesomd
I *am* a Dremel
wafflesomd's Avatar
Awesome. Way to go bit-tech mounting that panel wrong lol.
Old 2nd Aug 2013, 21:27   #14
wolfticket
Downwind from the bloodhounds
wolfticket's Avatar
wolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyan
Low to medium end performance wise doesn't necessarily mean low to medium end in other respects.
You may want a small system that, while not requiring a high performance, is in a prominent place. So you want it to look good and fit in with it's environment, which might mean spending an above average proportion of the overall budget on a high quality case.
__________________
Wolfticket: Ambitious but rubbish
"A facility for quotation covers the absence of original thought."
Dorothy L. Sayers (1893 - 1957)
wolfticket is offline   Reply With Quote
Old 3rd Aug 2013, 17:35   #15
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Pretty much what wolf says is correct.
Ive built htpc builds with much more expensive cases than the components in them in the main of things.
rollo is offline   Reply With Quote
Old 4th Aug 2013, 05:01   #16
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Hmmm... While I can see the points of both Rollo and Wolf I don't agree with them. Even if I was only going to use low to mid range components for the build if I was spending that much on a case I would want it to still be able to handle high end components for a potential upgrade at a later date. I would want my case to handle anything I may throw at it while it is sat there looking nice as I would hope my case would out live several rebuilds, with maybe the exception of the PSU and possibly storage components.
There are plenty of perfectly good and well built cases out there for a lot less that look just a nice as the Lian-Li that are sufficient if you are only using low to mid range components.
__________________
SchizoFrog is offline   Reply With Quote
Old 5th Aug 2013, 07:08   #17
Xir
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
I wonder why all the companies are concentrating on mini-ITX and letting out Micro-ATX which is just a smidge bigger but you actually get gamer and enthusiast boards for it.
This one maybe isn't but most mini-ITX cases would be big enough anyway.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
