Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 2nd Aug 2013, 11:23   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Asrock Z87 Extreme3 Review
We check out Asrock's entry-level enthusiast Z87 motherboard, the Extreme3.
http://www.bit-tech.net/hardware/201...reme3-review/1
Meanmotion is offline   Reply With Quote
Old 2nd Aug 2013, 11:30   #2
do_it_anyway
Supermodder
do_it_anyway's Avatar
do_it_anyway has yet to learn the way of the Dremeldo_it_anyway has yet to learn the way of the Dremel
77% and a damning conclusion saying there is little to recommend it.
Then a nice big Bit-Tech APPROVED!! badge.
do_it_anyway is offline   Reply With Quote
Old 2nd Aug 2013, 17:17   #3
Somer_Himpson
Banned
Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.
Why not recommend it with the review wording and the score and then say it is approved?
Total contradiction.
Somer_Himpson is offline   Reply With Quote
Old 2nd Aug 2013, 20:13   #4
murraynt
I Mod, Therefore I Own
murraynt's Avatar
murraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for presidentmurraynt should be considered for president
These are much better value in the states. I got my extreme 4 for something like $120
__________________
l I5 4690k l MSI Z78I l 8GB corsair 1600mhz l Asus 5870 v2 l Fractal Node 304 l 60GB Crucial M4 l F3 1TB Spinner l 700Watt Thermaltake l Samsung IPS231 l
Steam: murraynt
murraynt is offline   Reply With Quote
Old 2nd Aug 2013, 20:34   #5
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
I think because the board isn't necessarily bad as it is just average. You can't really go wrong nowadays on Z87.
I somewhat miss the days of finicky NF4 and absurdly bad NF5 boards. And of course good old SiS and Via boards.
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 4th Aug 2013, 14:51   #6
S1W1
Multimodder
S1W1's Avatar
S1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpitS1W1 is almost as Godly as yodasarmpit
I presume the approved badge is a mistake?
__________________
AMD X6 1090T OC @ 3.75GHZ | Corsair H50 cooler | 8GB Corsair XMS3 @ 1600MHZ | Asus M4N98TD Evo Motherboard | Gigabyte GTX 670 2GB OC| XFX 750W Black Edition PSU | Samsung 1TB Spinpoint F3 HDD | 300GB WD Velociraptor | Samsung 840 250GB SSD | NZXT Hades mid tower with red LEDS and engraved side panels | Windows 7 Home Premium 64bit | Asus Xonar DX |
=== Alienware M11X R3 laptop ===
S1W1 is offline   Reply With Quote
Old 8th Aug 2013, 08:28   #7
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
I think if you read a little slower and carefully this is perhaps why
"itís important to remember that the margins between boards are incredibly slim. Even at stock the biggest difference between it and a board more than twice its price is just seven per cent, and when overclocked this dropped to no more than two per cent, even with the 100MHz peak-overclock handicap. "
The fact that it costs HALF as much and gets almost the same performance is a pretty good thing in most peoples books, given we want spanking new systems but MOST of us dont have the wallet to expand on this. The price and performance of ASROCKs have suddenly become something that we would ***** our ears upto where it used to be for really cheap end computing.
LightningPete is offline   Reply With Quote
Old 8th Aug 2013, 08:30   #8
LightningPete
prik our ears upto*
Old 8th Aug 2013, 12:26   #9
bawjaws
I *am* a Dremel
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
Perhaps someone from Bit would like to comment on the apparent disconnect between a score of 77% and the "Approved" award?
I get that most Z87 boards appear to be pretty much of a muchness when it comes to performance, so differentiation on performance isn't really an issue. However, this board doesn't score so well for features or value, so why is it "Approved"? Given that the MSI Z87-G45 Gaming outscores this board on performance, features and value (with an overall score of 85%), and is about 10% cheaper to boot, why does the Asrock get the same Approved award when it's an inferior product according to all of Bit-Tech's metrics?
bawjaws is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
