Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Aug 2013, 11:04   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
IBM announces neurosynaptic software system
Promises a new class of computing device.
http://www.bit-tech.net/news/hardwar...ibm-synaptic/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 8th Aug 2013, 11:14   #2
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
Sounds like one of Thinking Machines 'Connection Machine' supercomputers compressed down to a chip. I wonder if their chip has any significant advantage to simulating a SLNN using RAM and a modern fast sequential processor iterating over the net (other than the operations happening truly in parallel, which is irrelevant unless the entire system is asynchronous).
edzieba is offline   Reply With Quote
Old 8th Aug 2013, 11:15   #3
dogknees
Multimodder
dogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremel
Does no one remember Turing? The structure doesn't matter, it still can't do anything that a "normal" computer can't. Though it could be faster at some things.
dogknees is offline   Reply With Quote
Old 8th Aug 2013, 14:32   #4
dogknees
Multimodder
I think they're using a LOT more very simple cores/cells that the Connection Machine. Still, the connections become the biggest part of the chip when the number of cells goes up, particularly with a lot of connections between cells. Guessing they would be using some sort of multiplexing buses with local, on-chip and between-chip sets.
Old 8th Aug 2013, 22:35   #5
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
They keep saying it "mimics the brain" and stuff like that, but in reality the nature did a way such it will never be possible!
Gradius is offline   Reply With Quote
Old 9th Aug 2013, 01:39   #6
edzieba
Virtual Realist
Nonsense! Brute force method: molecular simulation of the volume of neural tissue you want. More elegant solution: parametric neurons with diffuse neurotransmitter simulation. Most SLNNs for the last few decades are just parametric models.
That is, unless you subscribe to Dualism and think the brain has some sort of magic intangible goop that lets you think.
Old 11th Aug 2013, 04:40   #7
desertstalker
Multimodder
desertstalker has yet to learn the way of the Dremel
[QUOTE=edzieba]
Or that rubbish about the brain being a quantum computer of some sort.
desertstalker is offline   Reply With Quote
Old 11th Aug 2013, 12:27   #8
dogknees
Multimodder
[QUOTE=desertstalker]
Even if it is quantum, it's not "magic", just a different, harder kind of system to replicate.
Reply
Tags
architecture, harvard, ibm, neural networks, neurosynaptic, semiconductor, synaptic, truenorth, von neumann
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
