Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Aug 2013, 09:24   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
BitFenix Ronin Review
BitFenix had aesthetics as priority with its new tower case, but can it walk the walk when it comes to cooling?
http://www.bit-tech.net/hardware/cas...ronin-review/1
Meanmotion is offline   Reply With Quote
Old 9th Aug 2013, 09:58   #2
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
I know the idea is to test an out of the box setup, but it would have been nice to see the case tested with a few more fans installed than the pre-installed two, maybe even just an extra intake fan fitted on the front
Corky42 is offline   Reply With Quote
Old 9th Aug 2013, 10:05   #3
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Comment Edited.
__________________
SchizoFrog is offline   Reply With Quote
Old 9th Aug 2013, 11:13   #4
t5kcannon
Multimodder
t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.t5kcannon is the Cheesecake. Relix smiles down upon them.
Yes I agree. Testing the out of box set up is important, as it gives us an idea of what exactly our money is buying, but when a case holds extra potential (as this one), it would be nice to get an indication of that potential. Adding a few more fans and scoring the temperatures would do that.
t5kcannon is offline   Reply With Quote
Old 9th Aug 2013, 17:41   #5
djzic
Bokehlicious!
djzic's Avatar
djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.djzic is the Cheesecake. Relix smiles down upon them.
btw it says 'it's' instead of 'its' on the last page
__________________
PC: i5 4670k | Gigabyte GA-Z87MX-D3H | 8GB Crucial Ballistix Tracer 1866 | EVGA GTX 770 ACX SC
Parvum S1.0 | Samsung Spinpoint 1TB | OCZ Agility 3 120gb
Asus MW221U | Razer BlackWidow | Spyder2Express
Cam: Canon 400D | 35mm f/2.8 | Helios 44-2
djzic is offline   Reply With Quote
Old 9th Aug 2013, 22:35   #6
ev1lm1nd666
Multimodder
ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!
Even if you guys remove the stock installed fans and use the same fans in all case tests (as well as the basic test with stock fans) the results will corelate with each other as the placement/number of fans will be the deciding factor with the temps...
__________________
AMD FX 4100 @ 4.6Ghz, ASUS M5A97 PRO, EVGA GTX 560 Ti @1Ghz 2200Mhz Mem, 8Gb Corsair Dominator DDR3 1600, Corsair CX600 PSU, Antec 300 Case, Samsung Multyi DVD Drive
ev1lm1nd666 is offline   Reply With Quote
Old 14th Aug 2013, 14:58   #7
badgerz
Minimodder
badgerz has yet to learn the way of the Dremel
Prodigy M is out guys. Wakey Wakey, people might actually buy that.
badgerz is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
