Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Aug 2013, 15:15   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Transcend StoreJet 25M3 1TB Portable Hard Drive Review
The Transcend StoreJet 25M3 is drop resistant and features one-touch auto-backup.
http://www.bit-tech.net/hardware/sto...e-hard-drive/1
Meanmotion is offline   Reply With Quote
Old 14th Aug 2013, 09:03   #2
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Last paragraph, wrong "your".
Good to see a drive that's rugged but not at the expense of performance!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 14th Aug 2013, 09:19   #3
Meanmotion
bleh
Meanmotion's Avatar
Thanks, fixed.
Old 14th Aug 2013, 12:01   #4
Deders
I Mod, Therefore I Own
Deders's Avatar
Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.Deders is definitely a rep cheat.
What's the point in a USB3 drive that cant transfer files any faster than USB2?
__________________
i7 6700K @4.6GHz - Asus Z170 Deluxe - Noctua NH-D15 - Gainward Phoenix 1080 GLH 8GB @2050 & 11000 - 16GB Gskill RipjawsV DDR4 @3200 - Corsair HX850i - Nanoxia Deep Silence One - Samsung 950 Pro NVMe - Samsung Spinpoint F3 1TB - WD RE4 2TB - WD Caviar Blue 640 - Dell U2913WM Ultrawide - Logitech G19 - Corsair M65 - Sony STR-DN1050 Receiver - Q Acoustics 2000i 5.1 speakers.
Deders is offline   Reply With Quote
Old 28th Aug 2013, 08:54   #5
Rob™
What's a Dremel?
Rob™ has yet to learn the way of the Dremel
"...one small issue we do have is that the drive requires two ports to get enough power when connected over USB 2.0..."
I have a couple of these at work, and I have found that you don't need to plug in both USB cables into a USB 2.0 port, using the blue USB 3.0 connector on the cable the hard drive seems to receive enough power.
Rob™ is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
