Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 14th Aug 2013, 12:04   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Akasa Galileo Review
We take a look at Akasa's new fanless mini-ITX case.
http://www.bit-tech.net/hardware/cas...lileo-review/1
Meanmotion is offline   Reply With Quote
Old 14th Aug 2013, 13:16   #2
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
'The second is a new fanless mini-ITX case, designed for slim-type mini-ITX motherboards, called the Galileo. Then, following on from the Euler, the Galileo is a slightly longer, more expensive case, which is designed from the ground up to be as skinny as possible.'
This doesn't make sense, did you mean to end the first sentence with 'Euler'?
__________________
SchizoFrog is offline   Reply With Quote
Old 14th Aug 2013, 15:46   #3
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
We've tweaked this now so it makes more sense
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 14th Aug 2013, 20:53   #4
SchizoFrog
I *am* a Dremel
A, yes indeed it does. Thanks.
__________________
Old 14th Aug 2013, 22:24   #5
bawjaws
I *am* a Dremel
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
I'm sure that one day, an article will be posted on this site that doesn't contain a single typo or error. It'll be awesome because we'll then have discussions about the stuff being reviewed rather than proof reading the articles
I think this case is a nice idea but looks really dull: even though the build quality seems top-notch, it just isn't very stylish, imo. Also, I'd like to see some front USB ports hidden behind a cover or something, so that they don't stick out like a sore thumb but are still available if required.
bawjaws is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
