Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 23rd Aug 2013, 11:44   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Lamptron FC5 V3 Fan Controller Review
Lamptron's FC5 V3 fan controller has a multi-colour display, six channels and temperature inputs.
http://www.bit-tech.net/hardware/coo...oller-review/1
Meanmotion is offline   Reply With Quote
Old 23rd Aug 2013, 13:10   #2
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
I prefer this to either the CW611 or the NZXT Sentry Mix 2. Best looking (IMO) and nice and simple.
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 23rd Aug 2013, 15:25   #3
ChaosDefinesOrder
Vapourmodder
ChaosDefinesOrder's Avatar
ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.
Did I miss it or does the review mention what it's like to actually use? Can you use the dials to select a temperature with fans controlled automatically or is just a rheostat/pot with results read-out?
ChaosDefinesOrder is offline   Reply With Quote
Old 23rd Aug 2013, 15:36   #4
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
It's a manual fan controller - did mention this - ie you need to use the dials to adjust fan voltages
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 23rd Aug 2013, 16:56   #5
ChaosDefinesOrder
Vapourmodder
thanks, seems it just didn't fully sink in!
Old 26th Aug 2013, 14:56   #6
Bokonist
Modder
Bokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for presidentBokonist should be considered for president
Love the look of this, shame it would be obscured by the fridge door on my Fractal Design R2. Has anyone here modded a window onto a Fractal door?
Bokonist is offline   Reply With Quote
Old 12th Sep 2013, 10:56   #7
himaro101
What's a Dremel?
himaro101 has yet to learn the way of the Dremel
are there any fan controllers for rotated ports (like the Corsair Carbide 540 for example) ?
I'd love to have a controller of this quality but rotated so i didn't have to rotate my head to read it.
himaro101 is offline   Reply With Quote
Old 10th Nov 2013, 00:13   #8
keir
S p i t F i r e
keir's Avatar
keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.keir is the Cheesecake. Relix smiles down upon them.
Might be stupid but can you use any fan with this? (correct pins of course)
__________________
Steam : Steam trade offers
Latest project Hidden living room gaming PC Awaiting time/space from kids
UV . Silent . waterCooled - Crucial BX100 250Gb . Crucial MX100 256Gb . i5 750 @ 3.2Ghz . 8GB DDR3 1600 . Gigabyte GA-P55M-UD4 . GTX 670 @ 1032 boost
keir is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
