Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 29th Aug 2013, 09:57   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Asus Z87i-Pro Review
We take a look at Asus' successor to the P8Z77-i Deluxe and the mini-ITX board to beat on LGA1150.
http://www.bit-tech.net/hardware/mot...i-pro-review/1
Meanmotion is offline   Reply With Quote
Old 29th Aug 2013, 11:11   #2
Platinum
Multimodder
Platinum has yet to learn the way of the Dremel
I wonder why no one has made a DTX board of late, will still fit in ITX cases but would give you a PCI-E 16x slot and a 1x slot for sound cards / nics ect, it would limit you to a single slot card but I am sure some watercooling magic could be done as well.
If I could get one I would, I would stick in a top end watercooled card and use the 1x slot for a decent sound card.
Platinum is offline   Reply With Quote
Old 29th Aug 2013, 11:12   #3
Meanmotion
bleh
Meanmotion's Avatar
QFT
Old 29th Aug 2013, 11:27   #4
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
DTX was DOA mate.
It won't fit in mini-ITX cases: 203 mm by 244 mm versus 170x170mm. Might as well go mATX 244 mm 244 mm
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 29th Aug 2013, 11:31   #5
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
I think he meant mini DTX, which is ITX + 1 slot (170x203mm).
faugusztin is online now   Reply With Quote
Old 29th Aug 2013, 12:20   #6
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Ah 203 mm by 170 mm.
Basically doesn't exist. The mini-ITX ecosystem took long enough to catch on.
__________________
Old 29th Aug 2013, 12:26   #7
faugusztin
Well yeah, boards do not exists. Cases do - pretty much any dual slot ITX case (which is majority of them) do support mDTX boards, as technically all those ITX cases are mini DTX cases. It's only the mDTX boards which are missing.
Old 29th Aug 2013, 12:48   #8
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
As long as my mATX board can take a dual slot GPU, a sound card as well as have space for another expansion slot or two for a TV card or something else, I am a happy boy.
__________________
SchizoFrog is offline   Reply With Quote
Old 29th Aug 2013, 13:10   #9
Fingers66
Kiwi in London
Fingers66's Avatar
Fingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming Saiyan
It looks like some of the specs at the bottom of page 1 refer to a different m/b?
Specifications
Chipset Intel Z87
CPU support LGA1150 compatible
Memory support 2 slots: max 16GB DDR3 (up to 3,000MHz)
Expansion slots SLI and Crossfire support, Two 16x PCI-E 3.0 slots (One at x16, two at x8,) One 1x PCI-E, three PCI
Sound Realtek ALC1150 8-Channel
Networking Intel Gigabit LAN, bluetooth V3.0 + V4.0, 802.11a/b/g/n dual band WiFi
Ports 6 x SATA 6Gbps via Intel Z87, 8 x USB 3 (2 x via headers), 6 x USB 2 ( 2 via headers), LAN, audio out, line in, mic, Optical S/PDIF out, HDMI, DisplayPort, DVI,
Dimensions (mm) 305 x 208 (ATX)
Extras none
__________________
Gaming: [Silverstone TJ08-E][Asus Z170M-PLUS ][i5-6600K][Tundra TD03][16GB 2666MHz][Asus 7970 DCUII TOP][Samsung 850 Evo 500GB][Corsair HX650][Dell U2412M][Corsair K60]
Main: [Lian Li PC-A04][Asus Z97M-Plus][i7-4770K][Corsair H55][16GB 1600MHz][iGPU][Samsung M.2 NVMe 256GB][Seasonic X-650 Gold]
Kids: [Silverstone SG05B][Asus H87I-Plus][i3-4330][8GB 1600MHz][Asus 6850 DirectCU][Crucial M4 256GB][ST45SF 450w][Dell E207WFP]
NAS 1:[Synology DS211j] NAS 2:[Homebrew OMV]
Fingers66 is offline   Reply With Quote
Old 29th Aug 2013, 13:13   #10
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
I thought that too, Ian - was just going to write a post to that effect but you got there before me...
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 29th Aug 2013, 17:00   #11
Xploitedtitan
Minimodder
Xploitedtitan has yet to learn the way of the Dremel
I noticed, through building the comp for my bro, that Hasswell motherboards seem unable to fit the NH-D14 cooler from Noctua anymore, unlike my Sabretooth 55i. In the normal direction (fans blowing horizontally), the heatpipes get too close to the first slot and the fins were covering the other slots, which prevented inserting RAM into the 3 other slots (those Corsair sticks get too high with that useless radiator on em).
Is it typical to Asus, or is this a problem with all Hasswell motherboard designs? Asking because I would like to reuse my cooler if I upgrade. :/
Xploitedtitan is offline   Reply With Quote
Old 29th Aug 2013, 21:02   #12
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Specifications
Chipset Intel Z87
Extras none
Hmm, brain fart moment clearly. Sorted!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 29th Aug 2013, 23:36   #13
Asouter
Asouter's Avatar
Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.
I have to agree about the colour, as much as I like Asus boards. There's just no nice way of saying the colour scheme is just not my cup of tea. I was sooo relieved when Asus announced the Maximus VI Impact.
__________________
Finished Projects : D33P THOUGHT : THING : Mini Moto Mayhem
Current Project : BITZA
Asouter is offline   Reply With Quote
Old 2nd Sep 2013, 20:48   #14
Glix
Left Thumb Stick in the mud.
Glix has yet to learn the way of the Dremel
Similiar issue with K2 Doom. Tis okay though, stuck a single tower Xigmatek turned sideway on to the rear and it's fine on a i5 4670k.
Glix is offline   Reply With Quote
Old 2nd Sep 2013, 20:50   #15
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Bwech, I'm starting to loose overview.
So I've got ATX, MATX, ATX and Mini-ITX in descending order?
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 2nd Sep 2013, 21:18   #16
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
MATX are ATX are the same thing but yep, pretty much
ITX [170x170mm, 1 slot]
M-ATX [244x244mm, 4 slots]
ATX [244x305mm, 7 slots]
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is online now   Reply With Quote
Old 2nd Sep 2013, 21:50   #17
faugusztin
http://en.wikipedia.org/wiki/Compute...physical_sizes
Old 3rd Sep 2013, 14:26   #18
Xir
Xir's Avatar
Mini-ATX (MATX) and Micro-ATX (ATX) are not the same, sorry.
ASUS offers both for instance.
But I see you understand my confusion
__________________
SN25P
Old 3rd Sep 2013, 14:27   #19
Xir
Xir's Avatar
sorry, please delete double post
__________________
SN25P
Old 3rd Sep 2013, 20:35   #20
RedFlames
RedFlames's Avatar
I know Mini-ATX and Micro-ATX aren't the same but uATX/ATX and m-atx in product listings typically both refer to the 244x244mm form factor.
And for the record, when I checked the ASUS a few minutes ago EATX, ATX, Micro-ATX [ATX] and Mini-ITX were the only options listed... The german site may be different though...
Anyway, you're right... it's bloody confusing...
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
