Old 4th Sep 2013, 11:25   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
NZXT H230 Review
NZXT's latest H-series chassis has budget silence in its sights, but have too many corners been cut?
http://www.bit-tech.net/hardware/cas...-h230-review/1
Meanmotion is offline   Reply With Quote
Old 4th Sep 2013, 11:44   #2
Initialised
Multimodder
Initialised has yet to learn the way of the Dremel
When's the pink version out?
__________________
3.67GHz i7 920, 12GB GSkill Ripjaws, P6T Deluxe, and Gainward 4870x2 Goes Like Hell Golden Sample, Customised Watercooled Cosmos in Red, Black and White.
Initialised is offline   Reply With Quote
Old 6th Sep 2013, 18:58   #3
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for presidentMosquito should be considered for president
as soon as you grab a rattle can :-p The white version will be really easy to paint... the existing paint is really smooth.
I like the design of this case. The front door looks good in my opinion. Those drive trays are annoying, though.
Mosquito is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
