Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Sep 2013, 10:59   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Patch Tuesday brings critical IE, Windows, Office fixes
Hopefully no faulty ones, this time.
http://www.bit-tech.net/news/bits/20...s-patch-sept/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 9th Sep 2013, 21:32   #2
dr-strangelove
Multimodder
dr-strangelove has yet to learn the way of the Dremel
Originally Posted by The Article
...the third bulletin fixes a critical-rated remote code execution vulnerability in all Internet Explorer versions which, thanks to its heavy integration in the operating system itself, may even affect those who use an alternative browser.
I'm curious how an IE vulnerability could allow someone to do a remote code execution if IE is uninstalled/disabled?
dr-strangelove is offline   Reply With Quote
Old 9th Sep 2013, 22:06   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
Because, unfortunately, you can't uninstall IE from Windows - not fully. Large portions of it remain embedded within the OS.
__________________
Old 10th Sep 2013, 15:07   #4
NethLyn
Hypermodder
NethLyn's Avatar
NethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for presidentNethLyn should be considered for president
Just hoping that it's mass demand for the update that's causing only one PC to be updated on the day, it's been patch Wednesday for a few months now.
__________________
Intel=Fast, AMD=Cheap.
Member of Preys-World.com? Normal forum resumed, visit below:
forum.preys-world.com
NethLyn is offline   Reply With Quote
Old 12th Sep 2013, 00:09   #5
NethLyn
Hypermodder
NethLyn's Avatar
I've had the same set of three Office updates install themselves multiple times on different machines, so is Windows update screwed or have I been hacked and it's all the Zombies leeching off my connection that are updating at the same time?
__________________
Reply
Tags
insecurity, internet explorer, microsoft, patch tuesday, remote code execution, security, vulnerability, windows
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
