Reply
Thread Tools View Mode
Old 9th Sep 2013, 16:27   #1
Egami
Why is the dremel on fire?
Egami's Avatar
Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.Egami is definitely a rep cheat.
Silen Flux
Right. Iím only going to go gushy on you guys this once so here goes.
You know those little lists of things-to-do-before-you-die that people keep? I donít have one. But if I did, having a project log here on Bit tech would be one of those things.
I canít draw, sing or dance to save my life. I can however build things. I also happen to love computers. They make sense to me. I understand them. And I think when built right they can be incredibly beautiful; real pieces of art.
As this is my first major mod, posting it here will be as much about sharing it with you guys (and enlisting your help ) as it will be about learning and recording my development as I go. I have no set time limit for finishing but neither am I planning on making this an eternity project. Since the case I will be working on carries unique design and meaning I want to take my time and make it perfect.
This is my art.
The Plan
Like the banner above hints, the victim will be the NZXTís Phantom with which I couldnít help but fall in love with the moment I saw it, err, two years ago. Despite having been described as looking like the 70ís idea of todayís pc, I found it beautiful with its for an atx case spacious size and unusual design.
The name Flux got chosen for two reasons; firstly because my plans kept, and still keep, changing no matter how many times I tried to set them in stone, and secondly because I wanted to create a case that was a keeper in the world of nearly yearly changing hardware.
The fact is that mobos and colour schemes come and go - what many modded cases donít do, is change (easily) with the hardware. I therefore wanted Flux to be something that you could to toss in a new mobo, change the sleeving a bit and flush the loop with a different coolant - and be as fresh as ever. Or should I say, thatís what I want Flux to be. For now I think Iíll just worry about the journey there.
The ever evolving plans and renders scribbled unintelligibly on random bits of paper, the colour scheme of the planned eye candy will be white, white and more white, laced with black, red and silver/chrome. Iím also planning on reproducing some of the Phantomís edgy designs on the cover plates in order to make the build more interesting and keep it from turning into a miniature hospital operating theatre (though I do find myself somehow strangely fascinated by the Umbrella corp-like youíre-all-going-to-die-down-here laboratory freakiness...)
The plan is to produce cover plates for the psu, radiator and the motherboard tray, but with a twist: Behind the white cover plates Iím planning on crafting separate acrylic, led lighted ďlight stripesĒ that will echo the Phantom and the motherboardís design. Furthermore the light stripes will not be limited to white but will have a selection of colours to choose from, adding to the caseís versatility of theming. All three (psu/rad/mobo) plates will have independently controllable lights, so that should one wish, one stripe could be set red, another white and the third missing entirely. The idea behind this is the ever playful now-you-see-it-now-you-donít.
In the mean while ambient lighting will be provided by two top fans. At the moment it looks like the fans will be two NZXT FS 200s. There however are no white led versions so I will be creating my own.
The radiator will be mounted on the front using a specifically crafted mounting plate. Iím still working on dealing with the warm exhaust air dumping issues that this will be resulting in.
Tubing? Mandatory, they say. Weíll be using hard acrylic routed sneakily through the luminous stripes on the cover plates.
The cables will also get played with, but Iím not only meaning sleeving them silly colours now. I actually want to do something a little different with their routing. The anal army two rowed 24 / 8 / 3+4 are nice but... boring. The lighting stripes will feature heavily here as well.
Externally only little will change: The power indicator and fan control leds will be changed, most likely to white (or possibly red). Also the mesh covered areas, mainly the top and bottom front will see some black added to the case structure to stop the now white parts from glowing like beacons through the mesh. Iím also thinking about adding some semi-hidden surprises to these areas but weíll keep the details a secret for now.
The side panels will see some tidying up but thatís all.
What you wonít find here is cnc milled or laser cut go(o)dness; just plain old time and effort. The hardware will be what I have running now, while the tools will be limited to my hands, the old trusty dremel, an ancient power drill, some files and an iron saw thatís probably twice my age.
Ok, the sandpaper can come too.
Hardware
Motherboard: ASUS Maximus V Gene
CPU: Intel 2500K
GPU: EVGA 760 SLI
RAM: Corsair XMS3 4x4GB DDR3 1600MHz
Cooling
CPU: EK-Supremacy - Nickel
GPU: EK-FC670 GTX - Nickel
Pump: Swiftech MCP35X
Radiator: Alphacool NexXxoS XT45 Full Copper 360
Reservoir: Alphacool HF 38 Cape Cyclone 150 v.2
Updates Index
Let's get the party started!
Party on
Striking the pose
Sideshow 3AM
Staples & Snakes
Janus smiles upon us
Jailbreaking the rad
Testing 1 2 3
Jimm's sugary goodness
You're all going to die down here
EK, you sexy thing!
Open. Close.
Plumbing yoga
Mario ate my brain
Not very French balconies
Seriously...
And there goes the lid, the boilerplates, everything
Bridge to perfection
Dreamy creamy
Getting loopy
Time flies when you're having fun. Not.
Little things
EK-Supremacy EVO
Patronage & Sponsorship by
As a fledgling modder still finding my way around the tools and materials, any and all comments, questions and thoughts are warmly welcomed. Hope youíll enjoy the ride!
Egami is offline   Reply With Quote
Old 9th Sep 2013, 17:20   #2
Egami
Egami's Avatar
As Iím going to be using a single 360 rad instead of two 240s, the first thing I had to do was to modify the case into accepting one. Most people seem to have opted for the top fan slots placement but I didnít like the way this compromised the radiatorís fan setup and affected the aesthetics so I decided to go for an alternative solution by opening up the space originally occupied by the HDD slots and 5.25" drive bays and making a support plate for the radiator.
And here it is; the gorgeous Phantom pulled apart and everything refusing to pay rent tossed out.
Time for some quick 3D renders the good old 60ís style!
The third fan exists but it wasnít needed for the measurements exercise and hence got left in the box.
The truth is that I canít use 3D rendering programs to save my life.
...also the cardboard models are turning out perfect for weeding out initial design bads.
Time to cross the point of no return.
Front fan brackets gone.
Filing time. None of that will actually show from underneath the radiator support plate but thatís no excuse for shoddy work.
Rad support plate first cuts.
Not for eating.
It will be pretty, I promise.
The filing queue grows.
53cm is a long way for a small dremel disk to go. Didnít even notice how small the poor thing had shrunk until taking it off (and breaking it)
Note for the pending filing queue: Must invest in a larger file!
While waiting for the new files to arrive, I decided to have a go at sleeving as it seemed like an easy enough thing to try. Armed with Kamaster and Vestito's guides and the Sunbeam pin removal tools, success seemed inevitable. Except that the pins would not come off. They just would not, no matter what I did. The quick 15 minutes I thought Iíd spend with the pins and sleeve had turned into three hours and all I had to show were deep cuts on both my thumb and index finger as even the eight pin connector seemed to have turned on me. It was only when I was just about ready to scream like a girl and give up that one of the pins popped out!
Iíve never felt that victorious.
Victory!
The acrylic thankfully turned out much more placid than the sharp, pointy sleeving business and I managed to run some initial drilling and painting experiments. Cable management plans started taking shape too. Donít mind the four wobbly holes; thatís just a spare piece to test things on.
Some paint testing. First layerís looking promising.
The second however... Not.
The worst thing is that I have no idea what or why it happened.
While the paint dried the rad plate got its share of new, larger file powered love.
After filing it was time to jut down some helpful lines, which soon turned into a serious information overdose.
Thankfully there's always the dremel option to cut out the unnecessary information!
Looking neat.
Or what do you think?
Finally a sneak peek of the future plans. In short youíre looking at a rather thorough revamp of the famous murderMod luminous panel. Times three and with multiple lighting options.
Old 9th Sep 2013, 17:21   #3
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
Hello Egami,
Welcome to Bit-Tech
I have moved your post to the modding section as it still falls under conceptual - once there starts to be a concise build log with pictures of your build coming together I will move it back to Project Logs
Sounds like it's going to be a fun build though!
__________________
My Imgur
i7 6700k - 8GB - GTX 1070
keyboards.
Margo Baggins is offline   Reply With Quote
Old 9th Sep 2013, 18:06   #4
Egami
Egami's Avatar
When attempting to craft my megalomaniac plans into flesh it turned out that the actual light panel works like a dream, but the top white acrylic kept bouncing the light inside itself creating a halo. Thankfully it looks like the halo can be dealt with by reducing the opaque acrylic’s thickness.
Oh, and the lumistripe lights the case up like a Christmas tree. Great when viewed in full daylight as you get good clear, colour intense stripe but holy mother of a cow once the world goes dark. And there’s supposed to be three of them. An elegant solution is under intestimigation.
All in all there’s starting to be a bit of a work order queue as I’m having to wait for the white fan-to-be-leds to arrive. Before the fans there cannot be mobo panel and before mobo panel there really can’t be any of the other panels either.
At least I’ve managed to cook up some candy cane spaghetti.
8-pin route testing. It’s going to be tight up there once the fans are in place.
While waiting for the thinner acrylic to materialise I decided to spend some time with the freshly cooked candy cane spaghetti and see if I could find an interesting way to arrange the cables.
The experiment may have gotten slightly out of hand as I soon found myself thinking what if I redid the colours a little?
Well, the colours and the routing. I think I need help.
What do you guys usually do when watching Futurama btw? I took the opportunity to bend over some hard tubing.
Thankfully the new, thinner acrylic took only a couple of days to materialise. I doubt the store has ever seen anything get picked up that fast. Gief! Now! Raa!
At this point I decided that fans or no top fans, I was going to attack the shiny new 2mm acrylic and make the mobo tray cover into flesh. It’ll get cropped down to size once the fans are available.
But what’s this? When taking measurements I discovered some strange bits for which I couldn’t identify any use for. So I cut them out.
The weird bits out of the way it was time to show the acrylic the saw.
Did I by the way mention the condition of the “shiny” when I went to pick it up from the local plastics shop?
Yeah... Enough said there was a hefty discount involved.
But the mobo tray cover is alive!!!
...man those half torn acrylic scratch cover plastics sure make for one ugly sight.
By the way, those thinking cardboard modelling as a cheap and inconvenient design method - I dare you to do this casually with your real mobo!
Ahem. The rad plate has also received some paint. It’s not quite prrfect though (nature attacked mid painting) so I’ll be sanding that and doing a fresh coat once I get the chance.
Had to try it on regardless.
Hmm. Now just need to decide which cable arrangement to run with.
Thanks for watching. Any comments and suggestions are warmly welcome!
Old 9th Sep 2013, 18:21   #5
mansueto
Too broke to mod
mansueto's Avatar
mansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyanmansueto is a Super Spamming Saiyan
Looks like you've got quite the plan already. Looking forward to seeing this develop!
__________________
Black Momba: i5 2500k @ 4.5ghz | Corsair H80 | MSI P67A-G43 | 16GB DDR3 1600 Ripjaws | 128GB Corsair M4, 1TB Barricuda | Gigabyte R9 380X | Asus PA248 IPS + Acer P243w | Asus Xonar D1 + Fio E07K Andes | Windows 7 Ultimate x64 | Seasonic X760 | Fractal R3 | Corsair Vengeance K70 w/ Browns | Razor Deathadder Chroma
Lenovo U410: i7 3517u | 8GB ram | 24GB + 750GB HDD | 14 inch ultrabook
mansueto is offline   Reply With Quote
Old 9th Sep 2013, 22:40   #6
Margo Baggins
Moderator
Moved back to Project Logs
I also added the "Case Mod" Prefix to your thread.
The build is looking nice!
I can't believe your post ninja'd my post about it not having pictures, and your post was full of pictures!
__________________
My Imgur
keyboards.
Old 9th Sep 2013, 23:04   #7
Egami
Egami's Avatar
Oh the plan is strong in this one. Just hoping I will live up to the conjured expectations!
Woop! Thank you.
I had actually prepped all the three posts for a rapid start before getting entangled in the admin red tape and realising that the initial post indeed only carried the Silen Flux banner. Oops.
Itís good to be among the Project Logs now. Hope youíll enjoy the ride!
Old 10th Sep 2013, 12:28   #8
Concept73
Wannabe modder.
Concept73's Avatar
Concept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming SaiyanConcept73 is a Super Spamming Saiyan
The time, effort and planning that has gone into this build is amazing, not going to lie i may pinch an idea or two from you
Concept73 is offline   Reply With Quote
Old 11th Sep 2013, 19:40   #9
Egami
Egami's Avatar
Righto. With the mobo tray cover finally finished weíve officially reached the first milestone. For once I can say that everything went roughly as planned and with the light channel done and the rad support plate painted, I feel happy. That said, a lot of work remains to be done and so far Iíve been advancing much slower than I initially hoped I would.
The next big thing will be lighting. I got my soldering station today and will be starting work tomorrow provided I can get my back sorted out. I can currently barely turn my head and even just being still hurts. But I have coke and a bottle of Mt. Gay rum so... weíll see.
But enough waffling, we all know what youíre here for.
The rad all tuxedoed up.
So far the case has indeed needed very little cutting up and modding in itself. Iím seriously starting to think if I got this modding thing all wrong Ė or if NZXT did a really good job with their Phantom.
One thing I did have to get my dremel out for was for the re-routing of the 8-pin power.
It indeed took a while, but what started as an eye sore...
...slowly turned into a practical plan...
...that made it to field testing. And more...
Preparing for the first outing.
24-pin set.
8-pin.
Add the sata cables...
...and zoom out.
Finally, striking the pose: Love me like a loaded gun!
With that, Iím off to fix myself a drink with some rum from Mt. Gay. Enjoy, please comment; all and any input will be highly appreciated!
Old 11th Sep 2013, 19:43   #10
Azariel
Multimodder
Azariel's Avatar
Azariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for president
Very nice! Love the offset holes for the different sleeve colors!
Azariel is offline   Reply With Quote
Old 11th Sep 2013, 20:10   #11
Phame
COOOOFFFFEEEEE
Phame's Avatar
Phame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpit
Perfect start dude!
Phame is offline   Reply With Quote
Old 12th Sep 2013, 10:02   #12
Egami
Egami's Avatar
Thanks! I was looking to make the cabling a little more interesting but yet discreet. Happy that you like it!
Originally Posted by Phame View Post
Perfect start dude!
Aw-shucks... Thanks! Means really a lot coming from you guys
Old 12th Sep 2013, 18:52   #13
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Bender Bending RodrŪguez FTW!
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 12th Sep 2013, 20:40   #14
Egami
Egami's Avatar
Cheesecake!? On the first page of my first build!?
I can die a happy man now.
Old 12th Sep 2013, 20:44   #15
Z0DIAX
bending alloys
Z0DIAX's Avatar
Z0DIAX has yet to learn the way of the Dremel
nice way you did the 24 pin through the motherboardtray, very promising.
Z0DIAX is offline   Reply With Quote
Old 14th Sep 2013, 10:30   #16
LegendaryScott
Trying to live up to the name
LegendaryScott's Avatar
LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.
Very clean man
offset holes are lovely.
and I love the sata cables, I stared at them for a good 5 mins. Awesomely done
Will be watching this:
__________________
PROJECT#001 - ON EXTENDED HIATUS DUE TO NEW BABY!!
LegendaryScott is offline   Reply With Quote
Old 14th Sep 2013, 15:10   #17
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
Woof. I'll bite! Really like the idea for the offset cables. Gives it a sort of "pop" that most cable routing is sorely lacking in.
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 14th Sep 2013, 16:06   #18
Asouter
Asouter's Avatar
Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.
Really like the cable management, Very clean. I have an obsession for cable management. Dunno why cos I'm pretty bad at it.
But man I really like that
__________________
Finished Projects : D33P THOUGHT : THING : Mini Moto Mayhem
Current Project : BITZA
Asouter is offline   Reply With Quote
Old 14th Sep 2013, 17:04   #19
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Looking super-clean. I like the layer of black on the motherboard tray.
__________________
The Iron TurnipBlooBallsHypnotoadPlankReservoir-ThingsNUC-TooobularC7WaterblocksCrusty McBeanbags IIIGlassGreen
Powered by: AMD∑Gigabyte∑Swiftech∑Hardware Labs∑Noctua∑DangerDen
Cheapskate is offline   Reply With Quote
Old 14th Sep 2013, 18:53   #20
Egami
Egami's Avatar
Makes me want to say “wait till you see what I have in mind for the tubing” but the truth is I’m struggling with the cpu routing. It. Just. Won’t. Turn. Out. Clean. Enough.
Originally Posted by LegendaryScott View Post
Very clean man
Thanks Scott! You have to thank Asus and blind luck for the sata cabling though; I had no idea the sata cables would be the gorgeous black and white they are when I bought the board.
Rauf! Glad to have you aboard! Is it a bad thing that I’m already thinking of changing the said cables to black and white (BBWWWBBWWWBB) to make the red sata ports pop instead? Good idea? Bad idea? Very bad idea? The offset would stay the same of course.
One takes a bow. I understand what it means to have an obsession. It doesn’t matter if you’re good at it, or like doing it, after that - you just do it.
The layer of black? If you mean the little pattern slithering up the tray past the sata ports and 24-pin, I’m afraid master Cheaps it’s not black at all. In fact, allow me to demonstrate…
But first, it’s back to technical stuff with this update. It was a beautiful day outside so I decided to have a go at tidying up the Phantom’s side panel.
Naturally I forgot to grab a photo pre-op so a picture from the Hardware Heaven’s review will have to do.
Not really what you’d expect after ogling at the marketing photos.
Some of you already know the exercise but before any cutting the mesh had to come off. Gently.
A gratuitous amount of masking tape, measuring and marking later it was the time to start cutting.
The operation yesterday must have left me with some sort of queer brain damage as, instead of changing the disk when it started shrinking, I decided to see just how small / far I could get.
Thankfully I ran out of guts before breaking the disk or causing something equally catastrophic to happen. What the fcuk was I thinking?
The patient post operation.
The dark reality of modding: Fine file and a pot of touch-up paint. Love it or hate it, you ain’t going anywhere without it.
It helps if you love it. I’m yet to get that far. Thankfully the results make it feel less... like torture.
Zooming in.
Finally, add the previously removed mesh and voilŗ, we have a nice clean side panel.
That’s all for this time folks! Thanks for watching; comments and proposals are always much appreciated!
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
