Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 16th Sep 2013, 10:46   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Microsoft withdraws, re-releases 10 Patch Tuesday updates
Worst Patch Tuesday yet.
http://www.bit-tech.net/news/bits/20...pt-september/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 16th Sep 2013, 13:24   #2
Flibblebot
Smile with me
Flibblebot's Avatar
Flibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming SaiyanFlibblebot is a Super Spamming Saiyan
Is this just a side-effect on Microsoft's insistence on releasing patches on a particular day of the month? Is it just that patches written later in the monthly cycle have less time to be tested properly before release, and so are more likely to contain bugs?
Inquiring minds need to know!
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline   Reply With Quote
Old 16th Sep 2013, 14:36   #3
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
All those NSA/GCHQ backdoors causing problems perhaps ?
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 2Tb 2.5" Toshiba HDD, Cooler: Corsair H105, OS: Win 7 - 64
Dave Lister is offline   Reply With Quote
Old 16th Sep 2013, 16:33   #4
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Hmm... Not sure they have done it properly though. I was getting the three updates that continuously tried to install until sometime Saturday I think when after another check of WU the three updates disappeared and WU reported that there were no update to install. So I agree that they were withdrawn but after checking WU once again today after reading this article my WU has not found any further updates to download and install. So at least at my end I have not had the 'fix' yet. Are they 're-issued' to WU but haven't been released to the public yet?
__________________
SchizoFrog is offline   Reply With Quote
Old 16th Sep 2013, 16:46   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
They should be live on Windows Update now; if you're not being offered them, it's possible that they did actually install successfully at some point - one of the bugs was to fail the install constantly, the other was to actually install but act like it had failed the install constantly. Check your list of installed updates, see if they appear in there - if so, you're golden. Theoretically.
__________________
Old 16th Sep 2013, 20:55   #6
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
Blame all those to the NSA/GCHQ backdoors !
Gradius is offline   Reply With Quote
Old 16th Sep 2013, 20:58   #7
meandmymouth
I Mod, Therefore I Own
meandmymouth's Avatar
meandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyan
I think the QA department needs sacking.
__________________
Main - i7 3770K, Maximus V Gene, 32GB Crucial, 480 Sandisk Ultra II, 7TB HDD's, Fractal Arc Mini, CM 850W
meandmymouth is offline   Reply With Quote
Old 16th Sep 2013, 21:44   #8
SchizoFrog
I *am* a Dremel
Thanks Gareth... Do you happen to know if the reissued updates have the same KB numbers?
__________________
Old 16th Sep 2013, 21:52   #9
SchizoFrog
I *am* a Dremel
After checking I can confirm that the three updates in question were all installed.
__________________
Old 18th Sep 2013, 16:52   #10
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
I like patches, but that's probably because I was born in the 60's
PingCrosby is offline   Reply With Quote
Reply
Tags
insecurity, microsoft, patch tuesday, quality control, security, software, software updates, windows update
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
