Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 1st Oct 2013, 09:48   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Zyxel PLA5215 600Mbps Powerline Adaptor Review
Zyxel has released a pass-through version of its speedy 600Mbps adaptors. We put them to the test.
http://www.bit-tech.net/hardware/net...e-adaptor-re/1
Meanmotion is offline   Reply With Quote
Old 1st Oct 2013, 11:31   #2
do_it_anyway
Supermodder
do_it_anyway's Avatar
do_it_anyway has yet to learn the way of the Dremeldo_it_anyway has yet to learn the way of the Dremel
These look good.
BUT, my experience of Zyxel is they seem really good, but become buggy within a few weeks of use. I'm on my 3rd set of 500mbps powline adapters and they are just starting to lose connection for roughly 5-6 minutes, twice a day. They just drop out. You have two choices: unplug and replug and they will re-establish, or wait 5 minutes and they will reset.
Very annoying.
I was thinking of changing them, even though they are still in warranty, I'm bored of sending them back and getting anew set that do the same. So, I'm a bit hesitant to use zyxel.
Secondly, a question.
You say that they fall short of decent dual band wireless? Is this true? I thought powerline adapters were way ahead of wireless. Dual band "n" for example has a theoretical 300mbps, but is likely to be far below this, (I thought people were getting close to 130mbps top speed).
Am I better looking at a decent bit of wireless kit than powerline adapters? :s
do_it_anyway is offline   Reply With Quote
Old 1st Oct 2013, 14:18   #3
John_T
Supermodder
John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.John_T is the Cheesecake. Relix smiles down upon them.
Originally Posted by do_it_anyway
I thought powerline adapters were way ahead of wireless. Dual band "n" for example has a theoretical 300mbps, but is likely to be far below this, (I thought people were getting close to 130mbps top speed). Am I better looking at a decent bit of wireless kit than powerline adapters?
I would imagine that there's no definitive answer to that without actually physically testing it in your location, as what would work best in one situation / location would be the worst in another, simply because there are so many variables: ie the distance from point to point, whether it's a clear or obstructed line of sight, what type of obstruction/s they are, (ie wall material / thickness) external interference to the WiFi signal, quality of the electric wiring in your house, route of the wiring, etc, etc...
John_T is offline   Reply With Quote
Old 1st Oct 2013, 17:32   #4
sotu1
Ex-Modder
sotu1's Avatar
sotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on yousotu1 - may the hammer of Bindi be bestowed on you
There are 5-10 options?! Where?! Which ones?!
__________________
Still alive
sotu1 is offline   Reply With Quote
Old 1st Oct 2013, 19:50   #5
maverik-sg1
Supermodder
maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.maverik-sg1 is a hoopy frood who really knows where their towel is.
From a console gaming perspective, I always found the latency of a power line kit was lower to that of a wireless gaming set-up.
So, assuming your hardware is close enough to a power socket for cables not to be the issue, power line kits with decent speed set-up that's fast enough for HD streaming was a better choice for me... I hooked up a cheap wireless N router for the family wireless needs
maverik-sg1 is offline   Reply With Quote
Old 1st Oct 2013, 23:51   #6
John_T
Supermodder
I presume you're referring to this?
Originally Posted by The Article, page 3, last paragraph
Devolo's adaptors might have come down in price but even though they now retail for 5-10 less than the new PLA5205's, the latter are still your best option.
I think that was a bit of a misread there! (It'd be great if they were just 5-10 though!)
Old 2nd Oct 2013, 10:42   #7
PingCrosby
Supermodder
PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.PingCrosby is a hoopy frood who really knows where their towel is.
Electrickery
PingCrosby is offline   Reply With Quote
Old 2nd Oct 2013, 10:50   #8
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
Originally Posted by do_it_anyway View Post
These look good.
Very annoying.
I have the Zyxel 500s the 4205/4215, 4 of them in fact, issue free, I can't recommend them enough, bit of a shame BT hasn't reviewed these and these are the 500 Zyxel variant that should be used in a comparison with the 600mb as unlike the 42x1 devices they have 1Gb ports rather than 100mb ports so you get better performance, it's hard for me to see here if the 600s are an upgrade or not as I get comparable speeds at home on my 500s to what is in this review for 600s.
As mentioned by others it all depends on a mixture of things, I went out a few months back before upgrading to the Zyxel 500s and bought a load of N450 kit, it could not match the speed of even my old powerline gear over distance, 11ac gear will likely be another matter but that is a substantial price difference at the mo.
sandys is offline   Reply With Quote
Old 2nd Oct 2013, 11:25   #9
sotu1
Ex-Modder
sotu1's Avatar
Ah, yeah, quick skim read so I clearly missed half the sentence. Cheers though
__________________
Still alive
Old 3rd Oct 2013, 00:13   #10
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
sub 100Mbps? No way! I use 1Gbps for years now. And now I'm already going to 10Gbps (early 2014).
Gradius is offline   Reply With Quote
Old 3rd Oct 2013, 09:43   #11
Saivert
Supermodder
Saivert has yet to learn the way of the Dremel
Powerline is just no option when its theoretical speed isn't even on par with the best Wifi technology out there. I don't care about actual real world speeds and that powerline can be better than wireless if you have poor coverage. This is supposed to replace the need to install Ethernet cabling in your home and right now it is not going to happen. I'm glad I decided to install cables a long time ago. Sub-Gigabit in 2013? Hell no.
__________________
- I'm the troll who bumps page 2 topics -
Saivert is offline   Reply With Quote
Old 3rd Oct 2013, 09:50   #12
sandys
Mod Master
When all you need to do is stream video files from a server or give internet to TV, HTPC or console GbE is OTT, in these scenarios you only want a few reliable megabytes, powerline does this and will do so all over the house, into the back of the garden to the granny flat etc, very simple, plug and go, no need to worry about wifi holes, though actually I do use the PLA4321 (powerline wifi extender) to back up my home wifi that can't reach parts of my house.
Old 7th Oct 2013, 13:42   #13
Xye
Supermodder
Xye's Avatar
Xye has yet to learn the way of the DremelXye has yet to learn the way of the Dremel
I have questions about powerline adapters. Seemingly they can communicate across circuits within the house so theres a circuit for downstairs sockets and a circuit for upstairs... if it can cross circuits then does the signal not go out of the house also and possibly into your next door neighbours house? (I live in a terraced house) What if they have one in their house will it also communicate?
I am very tempted as My wireless signal is currently being drowned with all the other signals around me (10-11 different signals)
__________________
WoT's: Xye_Sol Playing: Panther II, SU-8, PzIV, M2, M4A3E8, M36, Tetrarch, T43, T20, T50, JgdPnth, AMX13 75, ARL44
Mech_Antec: Xeon 3450@3.809GHz | Asus P7P55D-Evo (1808 BIOS)|Asus 6950|Corsair C300 128Gb|RAID 0 WD Cav.
HTPC in Progress: E35M1-I DELUXE|Intel 320 Series 40Gb|2Tb Seagate Barracuda|The Dragon Reborn (Case)
CNC Controller: E8500@3.3GHz (unable to push further)| Asus P5N-D|8800GTS|Barracuda 250Gb| Condensation (Case)
Xye is offline   Reply With Quote
Old 7th Oct 2013, 13:48   #14
sandys
Mod Master
Yes It can connect to next door, so you still need to secure it, they have encryption.
Old 9th Oct 2013, 12:38   #15
MSHunter
Mod Master
MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.
Yeah the best solution for speed and reliability is of course a LAN connection. Sadly this is not always possible and in such situations Powerlan adapters are a much better choice then wifi.
At the very least from a support point of view, as there are fewer ways for it to not work.
still miffed that tablets do not have LAN ports. Guess I'll have to try USB to LAN. At least setting up some set IPS for your devices outside the DHCP range helps a bit and naturally buying Pro grade network hardware with a good track record.
__________________
Caved and bought a Gigabyte P35x V3 gaming laptop.
ex-PC: Silverstone TJ08B-E, 2500K, Corsair H80, 256 GB Samsung 830,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
