Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 17th Oct 2013, 09:50   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Lian Li announces PC-V358 cube chassis
Compact box with surprising capacity.
http://www.bit-tech.net/news/hardwar...n-li-pc-v358/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 17th Oct 2013, 16:37   #2
Xploitedtitan
Minimodder
Xploitedtitan has yet to learn the way of the Dremel
OMGAWD, I'm sold...
Xploitedtitan is offline   Reply With Quote
Old 3rd Jan 2014, 16:41   #3
soopahfly
Multimodder
soopahfly's Avatar
soopahfly can run Crysissoopahfly can run Crysissoopahfly can run Crysissoopahfly can run Crysissoopahfly can run Crysissoopahfly can run Crysissoopahfly can run Crysissoopahfly can run Crysissoopahfly can run Crysis
If that's MATX, How small is that bloke?
__________________
XBL Gamertag : Soopahfly82 :: PSN : Soopahfly82
Steam
:: Intel i5 4570 :: Gigabyte GA-H87M-HD3 :: 16Gb Corsair Venegance :: Radeon R9 290 :: Samsung EVO 250GB SSD :: 2x 2TB WD Black :: Corsair CX750M :: Coolermaster HAF XB ::
soopahfly is offline   Reply With Quote
Old 3rd Jan 2014, 16:55   #4
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
@soopahfly: Pretty much same as every previous PC-V35x series case :
(W) 324mm
(H) 286mm
(D) 390mm
And too bad they make PC-V35x uglier by every iteration.
PC-V350 had a nice front : http://www.lian-li.com/en/dt_portfolio/pc-v350/
PC-V351 added a small vent opening on front, making it a bit uglier : http://www.lian-li.com/en/dt_portfolio/pc-v351/
PC-V352 removed the signature "line" and instead added a square shaped line and made it even uglier : http://www.lian-li.com/en/dt_portfolio/pc-v352/
PC-V353 went totally nuts and made the front full mesh : http://www.lian-li.com/en/dt_portfolio/pc-v353/
PC-V354 doesn't belong to the case line.
PC-V355 went back to PC-V352 design without the square, and moved the ports on front, which killed the clean front design http://www.lian-li.com/en/dt_portfolio/pc-v355/
And now in PC-V358 it is even worse : http://www.lian-li.com/en/dt_portfolio/pc-v358/ - they added a big mesh, front mounted slim optical drive without a hiding cover (so if you will mount a dvd drive there, it will stick out visually).
While internally improved, externally it degraded.
faugusztin is offline   Reply With Quote
Reply
Tags
240mm radiator, aluminium, brushed aluminium, case, chassis, cube, lian li, lian li pc-v358, matx, mitx, pc-v358, tool-free, water-cooling, watercooling
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
