Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 22nd Oct 2013, 10:41   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Microsoft 'clarifies' Xbox One Windows app compatibility
Not everything will be compatible.
http://www.bit-tech.net/news/gaming/...box-one-apps/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 22nd Oct 2013, 12:32   #2
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Hasn't it been said the Xbox One will run three distinct operating systems ?
One for the games, the kernel of Windows 8 to power the apps, and another always-on to connect the two.
Corky42 is offline   Reply With Quote
Old 22nd Oct 2013, 15:26   #3
Bede
Ultramodder
Bede's Avatar
Bede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for presidentBede should be considered for president
It is not in Microsoft's interest to allow key PC applications to run on Xbox. If the Xbox could (for example) run Word and Internet Explorer there would be less need for households to maintain a traditional PC, leading to lower Windows license sales.
__________________
Coolermaster 690 II Advanced (white edition) | i5-2500K | MSI P67-GD53 | Asus 970 Strix OC | 16gb Corsair Vengeance LP | Gelid Tranquillo
Asus Xonar DS | 700W Coolermaster Silent Pro M | Crucial M4 128GB | SanDisk Ultra II 480GB | Samsung Spinpoint F3 1TB
Bede is offline   Reply With Quote
Old 22nd Oct 2013, 15:52   #4
Corky42
Well we know from pictures of the Xbox One's dashboard that it will run Skype and IE.
Maybe running Word would be a stretch without a keyboard
Old 23rd Oct 2013, 05:53   #5
AmEv
Meow meow. See yall in 2-ish years!
AmEv's Avatar
AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.
The Xbox One is the most PC-like console to come out of Microsoft's hardware division yet
*Ahem.*
The original Xbox uses a Pentium 3 processor. With a little modification, it can run Windows 98.
So..... :?
__________________
The Elder is away.
AmEv is offline   Reply With Quote
Old 23rd Oct 2013, 08:19   #6
Gareth Halfacree
WIIGII!
bit-tech Staff
I know. I've got one sat to my right as I type this. Which is why I said 'the most,' not 'the first.' The Xbox One is considerably more PC-like than the original Xbox: its processor instruction set is less customised, its graphics hardware more traditional, its USB ports are actually USB ports, and its operating system - from what has been revealed so far - is more heavily Windows-based and has PC-like features, including applications such as Internet Explorer and Skype, that did not appear on the original.
__________________
Old 28th Oct 2013, 13:16   #7
joplin66
What's a Dremel?
joplin66 has yet to learn the way of the Dremel
http://doddscientifics.com/2013/10/2...proach-launch/
joplin66 is offline   Reply With Quote
Reply
Tags
amd, apu, console gaming, dell, metro ui, modern ui, powerpc, windows 8, windows rt, xbox 360, xbox one
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
