Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 23rd Oct 2013, 12:23   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Impactics Haswell NUC cases teased
Passive cases for Intel's latest boards.
http://www.bit-tech.net/news/hardwar...-haswell-nuc/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 24th Oct 2013, 09:34   #2
MSHunter
Mod Master
MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.
I forgot does this NUC have Displayport? Could it run at 1440p? (27" resolution)
Must current HDMI inputs and outputs are limmited to 1080 even though 1.4 should be 4K if memory serves.
One mini DisplayPort* 1.2 with audio support
One mini HDMI* port 1.4a with audio support
Yes it does now to find out if it supports Higher then 1080 resolutions...
__________________
Caved and bought a Gigabyte P35x V3 gaming laptop.
ex-PC: Silverstone TJ08B-E, 2500K, Corsair H80, 256 GB Samsung 830,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Reply
Tags
core i5-4250u, d54250wyk, fanless cooling, fanlesstech, haswell, home theatre, htpc, intel, next unit of computing, nuc, passive cooling, sff, silent cooling, silent pc, small form factor
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
