Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 29th Oct 2013, 11:23   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
AMD's desktop Kaveri chips rumoured for February
Paper launch due in December, leak claims.
http://www.bit-tech.net/news/hardwar...eri-february/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 29th Oct 2013, 13:55   #2
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
..., which will include univied CPU and GPU address spaces ...
Should be "unified".
Anyways. AMD better have a chip with Kaveri that improves heavily on the singlethreaded CPU-side of things. Otherwise these chips can't compete with the i3 Gen4 from intel.
An powerful iGPU is the last thing that's of any interest for the bulk of PC-software, and the majority of PCs sold isn't ment for gaming to begin with.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is online now   Reply With Quote
Old 29th Oct 2013, 14:23   #3
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
so the awaited "end of year launch" was in fact a "paper launch". I really hoped that kaveri would hit shelves in december :'(.
GuilleAcoustic is offline   Reply With Quote
Old 29th Oct 2013, 15:03   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
Yarp. Fixed, ta!
__________________
Old 29th Oct 2013, 15:08   #5
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
Estimate is a 10% improvement in IPC, so big improvement in single thread no.
Since it isn't going to be a new process either (as far as I know), no promises of improved power consumption (maybe worse, depending on what they did to get that 10% IPC improvement) and likely no higher clock speeds.
This is moving the markers a yard, not a whole knew down.
Granted, the last couple of releases Intel hasn't done much to improve their processors CPU performance much, other then some edge cases (TSX, some new instruction sets)...but I will grant that Intel has increased GPU performance on chip from Sandy to Haswell of roughly 200-500% depending on which version of the graphics you are comparing.
AMD in the same time period I think has increased graphical performance something like 30-50%. Sure, AMD had been way ahead to start with...but there are a large number of Intel GPU solutions that are FASTER than AMD in the same power envelope. About the only area AMD is still generally pretty far ahead is most desktop graphics (and then only if you are comparing against the "common" HD4600 in most socketed Intel solutions). Mobile, Intel seems to generally be ahead by a little to a lot in the same thermal envelope.
Things do not look good for AMD.
I do hope Intel improves on the CPU side of things a fair amount with Broadwell, even if it is ONLY higher turbocore speeds and base clocks and not much IPC improvements. With a supposed 30+% improvement in power consumption, they could use a bit more dynamic setup. It'd be a shame if they funneled all of that in to a lower TDP and nothing in to increased performance (Crap, Haswell laptops, if done right, can already get 8-10hrs of battery life, which should be good enough for most everyone. Instead of a lower TDP, how about improved graphics and maybe tweak the base and turbocore speeds 100/300Mhz respectively?)
AMD needs a new process and possibly a new design. Badly.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 29th Oct 2013, 15:56   #6
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
This a process shrink from AMD? If so could be intresting. If not how are they getting the figures?
rollo is offline   Reply With Quote
Old 29th Oct 2013, 16:34   #7
play_boy_2000
It was funny when I was 12
play_boy_2000's Avatar
play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.
Wikipedia says that steamroller min process size is 28nm. I've never seen a cpu manufactured on a half node, but it looks like that may be the route AMD takes from now on with Excavator supposidly a half node 20nm part too?
__________________
Intel Core i5 2500k @ 4.5Ghz
16GB @ 1600mhz CL9 1.5V
XFX 7950 3GB
Asus P8P67
Patriot Wildfire 120GB SSD
play_boy_2000 is offline   Reply With Quote
Old 29th Oct 2013, 20:24   #8
Locknload
Jolly Good Egg
Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.Locknload is the Cheesecake. Relix smiles down upon them.
Locknload is offline   Reply With Quote
Old 29th Oct 2013, 20:30   #9
Locknload
Jolly Good Egg
A powerful iGPU is the last thing that will be of any interest for the bulk of PC-software, and the majority of PC's sold are not meant for gaming to begin with.
Your welcome.
(Spell and Grammar check are your friends).
Pedantic-ism is no one's friend. LOL
Old 4th Nov 2013, 02:02   #10
campdude
What's a Dremel?
campdude has yet to learn the way of the Dremel
Would like an AM3+ steamroller.
campdude is offline   Reply With Quote
Reply
Tags
accelerated processing, amd, apu, arm, cortex-a5, cpu, desktop cpu, gcn, hsa, jaguar, kaveri, paper launch, playstation 4, steamroller, xbox one
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
