Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 30th Oct 2013, 16:48   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
YoYoTech launches hand-crafted, engraved and water-cooled PCs
YoYoTech has entered the super-premium PC market with its highly modified XDNA Aurum 24K.
http://www.bit-tech.net/news/hardwar...engraved-and/1
Meanmotion is offline   Reply With Quote
Old 30th Oct 2013, 18:57   #2
Woodspoon
Supermodder
Woodspoon's Avatar
Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.
Somebody's having a laugh with that price.
I think most people who are going to spend that kind of money on a very high end system would want to build it themselves as well.
Woodspoon is offline   Reply With Quote
Old 30th Oct 2013, 19:19   #3
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
I see no fun on this one, but yep, what a waste. They are crazy.
Gradius is offline   Reply With Quote
Old 30th Oct 2013, 19:43   #4
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
Doubtful..I can see these sitting in those luxury apartments in Canary Wharf and the rest, where 8K is nothing, perhaps 1% of an annual bonus
Think of all those stressed out bankers, cash rich, time poor...this sort of pre built bling PC is just ideal for them...w8nkers.
Hustler is offline   Reply With Quote
Old 30th Oct 2013, 22:25   #5
Woodspoon
Supermodder
Woodspoon's Avatar
I see the point you're making but I seriously doubt that crowd would be aware of this sort of kit or where to get it and they're more likely to go to "generic well known high street store no1" and just buy the most expensive thing there they can see.
Old 30th Oct 2013, 22:26   #6
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
I dunno, clearly a lot of time and thought has gone into this build and the components themselves will take a good chunk of that. Just throwing it into PCPartpicker shows that a similar build, without cooling would set you back around 4200, I would expect the cooling to add another 5-600 to that, so you're likely looking at 4800. Add another 100 for extra materials (sleeving isn't cheap, neither is all the plastic), custom routing, milling and cutting work is not cheap either, although the scale is minimal here, so maybe 100. That leaves 2979, and if we decide that labour is 15/hr (although it could well be 20-30 given the nature of the build) and you're looking at between 100 and 200 man hours to complete this rig from concept to finish.
I'll admit that sounds a little on the high side (time wise), but it's clearly a show piece and not a staple product. If you want a glitzy product for the front page of the website, this does a pretty good job tbh. It's basically advertising.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is online now   Reply With Quote
Old 30th Oct 2013, 23:29   #7
AlexB
Web Nerd and WC Addict
AlexB's Avatar
AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.AlexB is definitely a rep cheat.
15 an hour? Crikey. I'd not get out of bed for that.
__________________
Whenever I smell asphalt, I think of Maureen. That's the last sensation I had before I blacked out; that thick smell of asphalt. She said she'd fix my bike. Free. No strings attached. I shoulda've known then that things were never that simple. Yeah, when I think of Maureen, I think of two things: Asphalt, and trouble.
1: Intel I7 2600k, ASUS P67 Pro, 8gb Corsair, Nvidia 970GTX, Corsair 256gb SSD
2: Intel I7 2600k, ASUS P67 Pro, 16gb Corsair, Nvidia 970GTX
AlexB is offline   Reply With Quote
Old 31st Oct 2013, 00:07   #8
Maki role
Maki role's Avatar
Well given that's pretty bang on for the UK average, I felt it was a realistic bottom-line figure.
__________________
Old 31st Oct 2013, 00:32   #9
andrew8200m
Mod Master
andrew8200m's Avatar
andrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyan
Slower, a Titan down, in a mainstream corsair case...
Yes it looks nice but 1k more buys you so much more with an 8pack build.
That's not me saying "I'm at OcUK so ours is better" that's me stating the obvious.. It's pretty but it's hardly groundbreaking.
__________________
Systems with parts from various manfacturers
andrew8200m is offline   Reply With Quote
Old 31st Oct 2013, 00:57   #10
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
Sorry to have a dig YoYo but I don't think I would throw that level of money at a company who had already folded, has only just come back from the dead and may not be around to offer support in 6 months time.
__________________
SchizoFrog is offline   Reply With Quote
Old 31st Oct 2013, 13:44   #11
Thermolance
Multimodder
Thermolance's Avatar
Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.Thermolance is definitely a rep cheat.
SchizoFrog. Yes that is true. however Centerprise International Ltd has bought the Yoyotech brand.
If you look up Centerprise International you will see that it is a very large company that sees the potential in Yoyotech. So with a company like Centerprise International backing up Yoyotech then there should be no reason to be concerned if you purchase anything from us.
Centerprise has been around for 30 years so they know how to stick around.
__________________
MSI GTX780 Lightening, AMD FX8350 4.5Ghz
Thermolance is offline   Reply With Quote
Old 2nd Nov 2013, 18:47   #12
the_kille4
Chaos will rule da world.eventually
the_kille4 has yet to learn the way of the Dremel
I still prefer MDPC's modded TJ07 which has the same black and gold theme.
__________________
Headphones: Grado SR325is | Oppo PM-3
Mic: Antlion ModMic 2.3 | Audio-Technica AT2020
Mixer: Alesis MultiMix 8 USB FX
Speakers: M-Audio Studiophile AV 40
the_kille4 is offline   Reply With Quote
Old 2nd Nov 2013, 22:55   #13
Cobalt
Supermodder
Cobalt's Avatar
Cobalt has yet to learn the way of the Dremel
Well lucky you. I guess I should just sleep in instead of going to my 11/hour job.
Cobalt is offline   Reply With Quote
Old 4th Nov 2013, 04:58   #14
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin has yet to learn the way of the Dremel
Everything looks amazing, except for the copper plates on the GPU blocks. C'mon guys.
Tulatin is offline   Reply With Quote
Old 4th Nov 2013, 13:21   #15
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
I wonder if all these builds are going to bring back the Custom PC's Dream PC Competition?
Either way it's a nice pc and with all the time and effort put in to it, I wouldn't say no to one if given it but I just couldn't justify buying one.
Good Job YoYoTech!
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 13th Dec 2013, 14:51   #16
seapanda
moobs r us
seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!seapanda - it's over 9000!!!!!!!!1!1!1!!!
What's the verdict on the less chi-chi versions, the XDNA's? I'm thinking about abandoning or sidelining my recently built DIY and going with a prebuilt watercooled.
seapanda is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
