Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 31st Oct 2013, 10:54   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
AMD Radeon R9 290 boards hit by last-minute delay
Non-X model launch shifted by a week.
http://www.bit-tech.net/news/hardwar...r9-290-delay/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 31st Oct 2013, 13:15   #2
fingerbob69
Hypermodder
fingerbob69's Avatar
fingerbob69 has yet to learn the way of the Dremelfingerbob69 has yet to learn the way of the Dremel
"Press who have already tested the card under the old drivers and planned to publish their reviews today are, naturally, now likely to release updated reviews using the new drivers on the 5th of November instead - although, as said press are held under NDA, nobody will be saying that out-loud just yet."
Although, of course, you kinda just have. lol
__________________
Antec 902, Asus P6T se, i7-920 D0 oc@3.6ghz, Asaka Nero S, 6gb Corsair, Thermaltake 750w Evo Blue, MSI R9-280 OC @1065/1315, Asus Xonar DS, 2x 500gb Seagate HDD, Win7 hp, NEC ea231wmi, MS X4, Roccat Kova+
Cordless Mouseman optical ...deceased
XFX 4890 + Artic Twin Turbo Pro ...retired 26.10.2014
fingerbob69 is offline   Reply With Quote
Old 31st Oct 2013, 14:43   #3
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
I'm surprised this card would encounter driver issues at all. Isn't it basically just a slightly weaker version of the 290X?
Due to temperature moderation, it wouldn't surprise me if the 290X actually down-clocks itself to the about same speed as the 290, so unless you have a reliable cooling system, I'm sure the 290 would be the better value.
schmidtbag is offline   Reply With Quote
Old 31st Oct 2013, 17:18   #4
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
This is probably to try and throttle the card back a bit to improve temps after the reaction they got from the 290X. Would be really interesting to see benchmarks comparing the 2 drivers to see what's been tweaked.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 31st Oct 2013, 18:17   #5
somidiot
Multimodder
somidiot has yet to learn the way of the Dremel
Well the problem I see is that newegg has no stock of the 290X. Are there any places that have stock? I will say that It's nice to see the Nvidia price drop happen, those cards are still in stock at least. I'll still probably wait for the next gen though.
somidiot is offline   Reply With Quote
Old 31st Oct 2013, 18:24   #6
schmidtbag
Ultramodder
ebay has a few in stock, though the only ones that aren't ridiculously priced are bids.
Reply
Tags
amd, amd radeon, catalyst, delay, r9 290, r9 290x, radeon r9, radeon r9 290, radeon r9 290x
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
