Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Nov 2013, 09:59   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Valve unveils its Steam Machine prototype
Surprise, surprise: it's a small PC.
http://www.bit-tech.net/news/gaming/...ne-prototype/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 5th Nov 2013, 10:22   #2
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
Looks more and more like they're just trying to set themselves up as another 'Alienware' type branding exercise, although with control of the OS and software delivery system, it has the potential to be a lot bigger.
Hustler is offline   Reply With Quote
Old 5th Nov 2013, 10:36   #3
Bungletron
Ultramodder
Bungletron's Avatar
Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.Bungletron is definitely a rep cheat.
the graphics card itself - claimed to be an Nvidia GeForce GTX Titan
The thing is going to be a monster!
__________________
Main rig: i7 2600K + Corsair H75 | P8Z77-M Pro | 8GB DDR3 | MSI GTX 970 4G + NXZT G10 + Corsair H75 | Xonar DX | 840 EVO + 850 EVO RAID0 1TB stripe | F4 2TB | NXZT Hale 650W | Carbide 240 Air | U2713HM
HTPC: A10 5800K | GA-F2A75M | 8GB DDR3 | EVGA GTX 950 SuperClock+ | Be Quiet! TopFlow | M4 512GB | F4 2TB | Lian Li PC-V355B
Server: Xeon E3-1240L v3 | ASRock E3C226D2I | 16GB ECC DDR3 | Fujitsu D2616 RAID | Seagate XT 500GB | MX100 256GB | 5 x 4TB HDD (RAID 5) | SilverStone DS380
Bungletron is offline   Reply With Quote
Old 5th Nov 2013, 10:38   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
Read on before you get too excited: some prototypes get a Titan, other prototypes get lower-end Nvidia boards. The majority of retail models - i.e. the only ones you're ever likely to see in the flesh, unless you're going to CES next year - will likely use on-board graphics or mini-PCIe laptop-style GPUs.
__________________
Old 5th Nov 2013, 10:41   #5
SAimNE
Multimodder
SAimNE has yet to learn the way of the Dremel
idk why people freak about the titan.... it isnt really all that great when you consider what you have to pay for it. sure if i was in the giveaway i'd hope for the titan, but if i have to actually pay for it i'm hoping for a 290/x or 780/ti
SAimNE is offline   Reply With Quote
Old 5th Nov 2013, 10:56   #6
Hustler
Hypermodder
Hustler's Avatar
Which begs the question..what on earth is the point in sending out such high spec prototypes in the first place?
This is Valve, I fail to see what they could learn from people using it, that they don't know already via their Steam hardware surveys.
Old 5th Nov 2013, 10:58   #7
teppic
Ultramodder
teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.
The final models will come with a wide range of options and there will be different sizes. Plus if you get a larger model like this you will be able to replace the graphics card.
__________________
i7 4770K | Gigabyte Z87X-UD4H | 16gb Corsair Vengeance | Samsung 830 256gb
Asus DirectCU II GTX 670 OC | Be Quiet! Dark Rock Pro 2 | Seasonic 760w | Fractal Design Define R3
teppic is offline   Reply With Quote
Old 5th Nov 2013, 10:59   #8
Gareth Halfacree
WIIGII!
bit-tech Staff
That's not what that means. Sorry, pet peeve.
what on earth is the point in sending out such high spec prototypes in the first place? This is Valve, I fail to see what they could learn from people using it, that they don't know already via their Steam hardware surveys.
Who knows. Newell already said that Steam Boxes will come in three distinct flavours: Good, Better and Best. From the sound of it, Valve's prototypes are Best while the retail models from licensed OEMs will be Good. That doesn't mean that one or more OEM won't release a Best similar to Valve's prototypes, mind - nor that Valve itself won't enter the hardware market fully and release an 'official' Steam Machine with high-end hardware like its prototypes. After all, it seems odd to spend so much effort engineering a fully-functional prototype then just leave production up to third parties...
__________________
Old 5th Nov 2013, 11:02   #9
teppic
Ultramodder
In related news, Metro Last Light was released for Linux via Steam yesterday.
__________________
Old 5th Nov 2013, 11:25   #10
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
Surely valve want to put their best foot forward when making their first revelation of the steambox. Lets not forget at the moment valves primary customers are pc gamers who likely drool over hardware specs like the prototype shown.
Also valve are a software company first and foremost. Their forray into hardware is a necessity however as they they need to get the ball rolling on good input methods for couch gaming and the steamboxes themselves. Going by newells move towards linux he's clearly not one to wait around and let other companies come up with the solutions he needs.
I would imagine that if the steam boxes become well established, valve will take a step back from the hardware and let their partners continue down that road. Perhaps producing only a premium model themselves.
theshadow2001 is offline   Reply With Quote
Old 5th Nov 2013, 11:27   #11
Bungletron
Ultramodder
Bungletron's Avatar
Hmm, not all titans eh? Well if they can put together a reasonable spec quiet box or a monster spec beast box then heavily discount/subsidise it (a la x-box/playstation) I would actually be interested either way.
__________________
Old 5th Nov 2013, 11:35   #12
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
I cant see them wanting to get into producing their own box, they say why they made the 300 prototypes in the Verge article linked by Gareth.
While the company's Xbox-sized gaming PC is only a model to inspire hardware partners
Corky42 is offline   Reply With Quote
Old 5th Nov 2013, 14:15   #13
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
I want to see how it all fits together ! It looks like a mini itx board with a riser for the gpu but the cooler is what is intriguing me at the moment.
Oh well fingers crossed they send me one then I can dismantle it and have a good nosy around
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 4Tb Toshiba X300, Cooler: Corsair H105, OS: Win 7 - 64, VR: Oculus with touch
Dave Lister is offline   Reply With Quote
Old 5th Nov 2013, 14:32   #14
Corky42
Is there any word on when they let the lucky 300 know ?
Old 5th Nov 2013, 14:37   #15
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
If they can fit a titan into that form factor and sell it onwards there will be plenty of lan enthusiasts who would jump at the chance to aquire it.
Even I would have to consider it for my own lan gaming if its portable enough and it looks like it is. This or ITX for Lan gaming what a choice to have in truth.
rollo is offline   Reply With Quote
Old 5th Nov 2013, 17:31   #16
magnetobob
Minimodder
magnetobob has yet to learn the way of the Dremel
slightly of topic has any one seen any itx cases in a similar style? where you can mount the graphics card horizontal in the the case via a pci riser or extensions?
magnetobob is offline   Reply With Quote
Old 5th Nov 2013, 17:38   #17
Star*Dagger
Banned
Star*Dagger has yet to learn the way of the Dremel
Not sure if this is tongue in cheek sarcasm or serious.
The difference between the Steam hardware survey data, which is a list of what people are using and the prototyping of the inter-operability of a new hardware (and software) is like the difference between those who know what they are talking about and those who spout off in online forums.
Yours in Elite Corrective Plasma,
Star*Dagger
Star*Dagger is offline   Reply With Quote
Old 5th Nov 2013, 17:50   #18
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.stonedsurd is the Cheesecake. Relix smiles down upon them.
Star*Dagger
Bingo.
PS: I've missed your "yours in <insert new phrase here> plasma" sign-offs lately, good to see them back
__________________
stonedsurd is offline   Reply With Quote
Old 5th Nov 2013, 17:59   #19
Corky42
I dont think its the case that allows this, its more a case of buying a PCI-E riser card like this..
http://www.logicsupply.com/products/pcie_101l_16
Or a flexible PCI-E riser card that lets you orientate your card any way you like.
http://www.made-in-china.com/showroo...-SLPS057-.html
The case they are using looks similar to this.
http://www.b2b-computer-case.com/mini-itx-case/04.htm
Old 5th Nov 2013, 18:58   #20
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Part of the company's push to become more self-reliant, itself a result of founder Gabe Newell's vocal distaste for recent Windows releases...
I have my doubts about that. I think it is more to do with Gabe seeing how Apple's App store and Google Play are doing very well, and wants to develop its own ecosystem independent of other platforms.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Reply
Tags
gabe is god, gabe newell, gaming pc, home theatre pc, htpc, king gabe, linux, linux gaming, mini-itx, pc, sff, small form factor, steam, steam box, steam machine, steamos, ubuntu, valve
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
