Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 7th Nov 2013, 09:18   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
HGST ships first 6TB helium-filled hard drives
2012's promise is the product of today.
http://www.bit-tech.net/news/hardwar.../07/hgst-he6/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 7th Nov 2013, 10:24   #2
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
Atleast if the drive dies you suck in the helium and have a laugh :-)
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is offline   Reply With Quote
Old 7th Nov 2013, 10:58   #3
MrJay
You are always where you want to be
MrJay's Avatar
MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.MrJay is definitely a rep cheat.
Ib4 diminishing helium stocks...
__________________
Main Phanteks Enthoo ITX Windowed - Pentium G3258 @ 4.5GHz - 8GB Samsung DDR3 @ 1600 MHz - Sandisk Ultra 240GB - EVGA 760 SC 2GB - Asrock Z97M-ITX/ac - Windows 10
HTPC Intel NUC (Celeron 847) - 30GB Samsung mSATA SSD - 2GB Crucial RAM 1333MHz - Windows 10
MrJay is offline   Reply With Quote
Old 7th Nov 2013, 12:23   #4
Risky
I Mod, Therefore I Own
Risky's Avatar
Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.
I suspect the helium use for this product will be insignificant compares to others.
__________________
As a rule watercooling can be simple, affordable and effective... I guess I just like to break the rules.
Risky is online now   Reply With Quote
Old 7th Nov 2013, 12:45   #5
Almightyrastus
Rule #9
Almightyrastus's Avatar
Almightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming SaiyanAlmightyrastus is a Super Spamming Saiyan
At least it's a meaningful use of helium
__________________
Lo there do I see my Father. Lo there do I see my Mother, and my Sisters and my Brothers. Lo there do I see the line of my people, back to the beginning. Lo they do call to me. They bid me take my place among them, in the halls of Valhalla where the brave may live forever.
Almightyrastus is offline   Reply With Quote
Old 7th Nov 2013, 12:52   #6
Shirty
Time travelling rogue
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
QFT. Balloons are great fun for kids but an utter waste.
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 7th Nov 2013, 15:44   #7
PCBuilderSven
Multimodder
PCBuilderSven has yet to learn the way of the Dremel
Originally Posted by Article
although the drive itself is, oddly, some 50g lighter than the air-filled five-platter 4TB Ultrastar 7K4000 at 640g.
Seeing as the whole point is that helium is less dense than air, I don't see what's so odd about that, the reduction in density of the filling causes a greater reduction in mass than the increase caused by the additional two platters. That sounds quite plausible.
PCBuilderSven is offline   Reply With Quote
Old 7th Nov 2013, 16:13   #8
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Except the volume of gas in a typical HDD probably doesn't even account for 1g, my guess is it would be due to the reduction in the size of the motor along with the associated mechanics.
Corky42 is offline   Reply With Quote
Old 7th Nov 2013, 16:19   #9
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Except the maths doesn't work out at all for that. Given that 50g of air itself takes up 38l or so of space (at 0C and sea level), whereas an HDD's total volume (as in measured from the enclosure) is around 0.393l, replacing the air with helium wouldn't account for that. They simply made some weight saving changes elsewhere.
EDIT: In fact, to save 50g on switching air with helium, you would have to swap approximately 46l of air with the same volume of helium.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum, Tower Level 10
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 7th Nov 2013, 16:44   #10
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming Saiyan
If you can keep the helium in, why not just run it under vacuum?
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Old 7th Nov 2013, 16:48   #11
Maki role
Maki role's Avatar
I believe that's something to do with how the arm of the HDD itself rides on a small cushion of air so as not to scratch the platter.
__________________
Old 7th Nov 2013, 18:00   #12
Star*Dagger
Banned
Star*Dagger has yet to learn the way of the Dremel
8 of these in RAID is a start.
I'm ordering 20 of them as we speak.
Your in PvP video Plasma,
Star*Dagger
Star*Dagger is offline   Reply With Quote
Old 7th Nov 2013, 21:20   #13
Cthippo
Cthippo's Avatar
Star*Dagger
So what are you paying for them?
__________________
Reply
Tags
7stac, hamr, he6, helioseal, helium, hgst, mechanical hard drive, mechanical storage, sas, sata, western digital
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
