Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 24th Feb 2003, 18:16   #1
Plasma
Multimodder
Plasma's Avatar
Plasma has yet to learn the way of the Dremel
Substitutions for LM308 Op Amp IC ?
Hi,
Does anyone know of a IC which can substitute the LM308? Need this for a IR project I'm working on. Fast answers are greatly appreciated...
Plasma is offline   Reply With Quote
Old 24th Feb 2003, 20:32   #2
Plasma
Multimodder
Plasma's Avatar
Do you think the LM741 could work???
Old 24th Feb 2003, 20:52   #3
eaterofpies
I *am* a Dremel
eaterofpies has yet to learn the way of the Dremel
isnt the 308 a quad op amp? tho at college we used 741 and 108 without worrying which it was really (tho pinout might be different) *shrugs* we just looked up the pinout when we needed em
eaterofpies is offline   Reply With Quote
Old 24th Feb 2003, 20:57   #4
Plasma
Multimodder
Plasma's Avatar
Yep, an op amp. So you think I could use the 741, then? I have datasheets of both, so the pinouts aren't a problem.
Old 24th Feb 2003, 21:05   #5
eaterofpies
I *am* a Dremel
u may have to rearrange the pinouts and will definitelyu if u r moving from 308 to 741 because a 308 has 4 op amps in it and a 741 has 1 op amp in it ok?
and i think they actual specs of the op amps are similar but i cant remember too well
best look at the datasheets yerself and work it out
Old 24th Feb 2003, 21:11   #6
Plasma
Multimodder
Plasma's Avatar
Thx! I'll take a better look at the sheets tomorrow. I'm getting a bit tired now (it's 21:11 here)
Old 24th Feb 2003, 21:19   #7
eaterofpies
I *am* a Dremel
its 8 pm here and ive still got to write a lab report *grumbles*
ok so a bit off topic
oh and a lab report is pretty much an essay
/me hates essays
Old 24th Feb 2003, 21:20   #8
Plasma
Multimodder
Plasma's Avatar
lol At least I don't have to work on any lab report, but I have an essay to write... (whoops, bit off topic... )
Old 24th Feb 2003, 21:22   #9
cpemma
Ecky thump
cpemma's Avatar
cpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysis
It's a bit more upmarket than a 741, so tread wary.
The LM108 series are precision operational amplifiers having specifications a factor of ten better than FET amplifiers over a -55C to +125C temperature range.
The low current error of the LM108 series makes possible many designs that are not practical with conventional amplifiers. In fact, it operates from 10 M Ohm source resistances, introducing less error than devices like the 709 with 10 k Ohm sources. Integrators with drifts less than 500 V/sec and analog time delays in excess of one hour can be made using capacitors no larger than 1 F.
cpemma is offline   Reply With Quote
Old 24th Feb 2003, 21:24   #10
Plasma
Multimodder
Plasma's Avatar
Upmarket?
Old 24th Feb 2003, 21:41   #11
eaterofpies
I *am* a Dremel
the 108 is a better ic probably better response over different temps / frequencys
if your doing stuff that requires a high quality signal where the shape / amplification ammount matter a lot use 108. if on the other hand it dosent matter too much about the quality of the signal or accuracy (led temp sensors etc) then go cheep
hmmm sorry im not so good at explaining
Old 24th Feb 2003, 21:49   #12
Plasma
Multimodder
Plasma's Avatar
Not good at explaining? I understood pretyy clear what you meant. Could I substitute the 308 with a 108/208, then?
Old 24th Feb 2003, 22:04   #13
cpemma
Ecky thump
cpemma's Avatar
108, 208 and 308 are all about the same specs, just the first is single, second dual and third a quad package.
Full spec
Old 24th Feb 2003, 22:12   #14
Plasma
Multimodder
Plasma's Avatar
Ok, so I just went through Elfa's online catalog of op amps again. I turns out they have none of the LMx08's!?! I think that's too bad. Does anyone know of a place which sells these to Norway (online) with good prices, and not to high shipping?
Old 25th Feb 2003, 15:58   #15
Plasma
Multimodder
Plasma's Avatar
Ok, I think I've found a godd substition, the NTE938. And ELFA GOT IT!!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
