Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 11th Nov 2013, 13:08   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Sony releases bizarre PS4 unboxing video
Sony has done its own slightly peculiar take on a PS4 unboxing video.
http://www.bit-tech.net/news/gaming/...boxing-video/1
Meanmotion is offline   Reply With Quote
Old 11th Nov 2013, 13:19   #2
MrDomRocks
I Mod, Therefore I Own
MrDomRocks's Avatar
MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.MrDomRocks is definitely a rep cheat.
This one is better, even if Francis is intentionally being a douche in the video.
__________________
Kawaii on the streets Senpai in the sheets
MrDomRocks is offline   Reply With Quote
Old 11th Nov 2013, 13:23   #3
sandys
Mod Master
sandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpitsandys is almost as Godly as yodasarmpit
Wired had an excellent strip down of the internals of the PS4 done by Sony that is worth a look, can't find it on their site for some reason, looks like a superb bit of system design.
Found it.
http://www.wired.com/gamelife/2013/1...eardown-video/
Surprising how much of the system is the PSU, the PS4 could be tiny if they took Microsofts external PSU approach.
sandys is offline   Reply With Quote
Old 11th Nov 2013, 13:38   #4
proxess
Ultramodder
proxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for president
So they're following something along the lines of Daft Punk's Random Access Memories album unboxing.
__________________
Laptop: i7 4930MX 3.0GHz (~4.0GHz); 4x 8GB Kingston HyperX Impact 1600MHz; Nvidia 980M 8GB; Samsung 840 EVO mSATA 250GB; Ubuntu 16.04 x64 and Windows 10 Pro.
Linux #429448
proxess is offline   Reply With Quote
Old 11th Nov 2013, 14:44   #5
loftie
Mod Master
loftie's Avatar
loftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyan
MY GOD, CABLES! Yea, I don't like or see the point of that video.
__________________
Sent from my PC using a keyboard
loftie is offline   Reply With Quote
Old 11th Nov 2013, 14:57   #6
Corky42
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
And how much empty space there is on the main board, it seem you could almost fit the whole thing on a PCB the size of an average graphics card.
Corky42 is offline   Reply With Quote
Old 11th Nov 2013, 15:03   #7
sandys
Mod Master
Would make a lovely add-in card for my PC I'd give up a GPU for that.
Old 11th Nov 2013, 17:20   #8
Cerberus90
Cerberus90's Avatar
Cerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming Saiyan
For cooling perhaps?
__________________
Steam: Cerberus90
| i3-4160 3.6GHz | MSI Z97S SLI Krait | 16GiB HyperX Fury 1866 |256GB Samsung 830 |
| Strix GTX980 WC'd | Thermaltake Armor |
Cerberus90 is offline   Reply With Quote
Old 11th Nov 2013, 17:27   #9
sandys
Mod Master
Its the size it is because it houses all the ports and drive connectivity around all sides of the PS4 and antenna etc. probably minimal layers for cheapness too, pretty neat job for launch.
Old 11th Nov 2013, 17:38   #10
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
I see absolutely nothing bizarre here.
Gradius is offline   Reply With Quote
Old 11th Nov 2013, 18:58   #11
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
...Brown leather gloves...
-So OJ was innocent...
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 11th Nov 2013, 19:06   #12
pilsner72
Bodger
pilsner72's Avatar
pilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyanpilsner72 is a Super Spamming Saiyan
What will happen to the one in bits, i'll buy it for £50
__________________
Intel i5 3570K/Asus P8Z77-V LX/16GB DDR3/Asus STRIX 970 4GB/Windows 10 Pro
KidsPC:Intel i5 2500K/Asus P8H61-MX R2.0/8GB G-skill DDR3/Asus STRIX 950 2GB/Windows 10 Pro
Steam: [BC] holstenwolf
pilsner72 is offline   Reply With Quote
Old 12th Nov 2013, 00:28   #13
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
Every time I see this dude I think he's trying so hard to be uber cool and sees himself as the Japanese Steve Jobs or something.
But he's just a fail bucket full of fail.
Guinevere is offline   Reply With Quote
Old 12th Nov 2013, 14:15   #14
Eggy
Multimodder
Eggy has yet to learn the way of the Dremel
He's very approachable though. Very active on twitter. Responds to most questions without beating around the bush. very refreshing for a company president.
Eggy is offline   Reply With Quote
Old 12th Nov 2013, 15:45   #15
spyplane
Minimodder
spyplane's Avatar
spyplane has yet to learn the way of the Dremel
I wonder what the XBONE packaging includes. Maybe a diagram trying explaining why 720p at 30 fps is actually a good thing for $500?
spyplane is offline   Reply With Quote
Old 12th Nov 2013, 18:18   #16
SlowMotionSuicide
Come Hell or High Water
SlowMotionSuicide's Avatar
SlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for presidentSlowMotionSuicide should be considered for president
If you have ever wondered what kind of gloves a strangler rapist would wear, well now you know.
__________________
G3258 @ 4.3GHz | MSI Z97 Gaming 5 | 8Gb Dominators | GTX 660 | Crucial MX100 256GB | F1 Spinpoint 1TB | Seasonic P-760 (XP²) | NZXT H440W
SlowMotionSuicide is offline   Reply With Quote
Old 12th Nov 2013, 20:04   #17
stuartwood89
Please... Just call me Stu.
stuartwood89's Avatar
stuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpit
Japan
__________________
My new blog Stu-Topia.com: because stutopia.com was already taken
Project - Storm Scout Restoration
Originally Posted by Joey Propane View Post
I thought Dragonforce were like a joke/troll rock band? Ya'know, like Nickelback?
stuartwood89 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
