Reply
Thread Tools View Mode
Old 13th Nov 2013, 14:24   #1
keenan
Supermodder
keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.keenan is definitely a rep cheat.
Project Marshlands: A Military Themed Build.. (Finished)
comptoir-hardware
ocaholic
custompcmax
Corsair
Guru3D
Hello everyone.
This is my first ever project, most from old and second hand stuff so it's not being build for top of the line performance.. It's already a finished project, but I thought I'll post it here for you guys aswell. All the photos needs to be re-sized so it might take a while to get it all posted..
Themed to be a military build it's build around the following..
ASUS Sabertooth 990FX
AMD FX8120
16GB Corsair Vengeance Memory
nVidia GTX470's
Corsair TX850
Corsair Vengeance C70 (Military Green)
Everything is watercooled apart from the Sabertooth to keep the color scheme..
Sponsors:
First off all I'd like to give a massive thanks for all my sponsors. Akasa for sponsoring the superb Akasa Apache fans, Corsair for sponsoring one of their awesome TX850 power supplies and MNPCTECH for providing the stunning replacement side window for the C70..
Fans sponsored by Akasa
Power supply sponsored by Corsair
Case mods sponsored by Mnpctech
First up is the cabling..
I got some 2.06mm 16awg Eco wire with a rating of 26/0.25..
Some molex crimps..
Some MDPC sleeve has got my name on it..
Started some of the cables and decided that it just doesn't "fit" the theme so new ones must be made..
keenan is offline   Reply With Quote
Old 13th Nov 2013, 18:53   #2
keenan
Supermodder
A quick look at the case..
Buttons are definitely growing on me..
Good cable management space..
Old 13th Nov 2013, 20:30   #3
keenan
Supermodder
Having a quick look at the memory..
Looks good, but not good enough..
Some naked pics..
Ooooooo..
Some dirty pics...
Got the memory sinks all cleaned up and ready. The adhesive was so hard to get off I had to soak them in hot water and rub it off with a cloth. Took me about an hours worth of rubbing!!
One last shot of the before..
To go with the military theme I ordered a couple of cans of "desert sand" from Army Issue, which turned out to be the easiest spray paint I have ever used. No runs or smudges :lovely:
Busy on my self fabricated spray surface!
And the end result
Old 14th Nov 2013, 13:53   #4
keenan
Supermodder
Some SATA sleeve, heatshrink and a lighter
..and I had to do the front IO cables of the case..
Got a few things in the post..
Thanks Akasa for making awesome fans ...
Also, something special from far far away..
And a few of these funny fittings!!
Old 14th Nov 2013, 13:59   #5
keenan
Supermodder
Got the 24pin and the fans sleeved using the new crimper ..!!
Thought to myself, "Damn this crimper makes me look like a crimping genius!!!"
Some beautiful Commando Green sleeve ready for action..
Fans done..
A much more military style 24pin!
12mm copper tubing seems to be the rarest thing in the UK..
All the cables done
Old 14th Nov 2013, 14:35   #6
keenan
Supermodder
A tiny little update..
Received some packages in the post..
What could it possibly be????
A couple of second hand GTX470's maybe??
Some "camo" wrap ...
.. and a tasty beveridge
Back to business...
Radiator mounts!!
Vinyl wrapped radiator mounts..
Back on the radiator..
..and with the fans..
Some camo wrap on the GPU's
Connected up to see the "bigger" picture ....
......and trying to fool myself into thinking a 60 camera can take cool pics...
Old 14th Nov 2013, 18:11   #7
keenan
Supermodder
Some mysterious boxes arrived in the post...
First one with some lovely super cool stuff from Akasa..
I'm gonna have to take a peek inside!!!!
All packed out..
But what does these boxes really say??
Inside the very informative boxes..
Also received this lovely box.. (Feels quite heavy, wonder what it could be..?)
Ooo look, it's something to power these power hungry GTX470's...
So many connectors...
I would like to thank Ivan and Alex at Akasa, for being an absolute pleasure to chat with and for sending me this amazing sponsors package!!
I also want to give a massive thank you to Paul at Corsair for supplying me with this lovely PSU, for being so supportive and for believing in me..
Old 14th Nov 2013, 18:24   #8
keenan
Supermodder
Now this is where the fun starts...
Got a roll of A-TACS hydrographic film this morning..
Nothing magical about this horrible looking over pan, but that's where the magic happens..
And the result... hydrodipped memory modules!!
Took the wrap off the gpu block and gave it an ATACS dip aswell
Old 15th Nov 2013, 00:13   #9
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysis
Awesome camo finish on those blocks and ram.
__________________
octTower
Electrocutous Orchid
craig - toyoracer is offline   Reply With Quote
Old 15th Nov 2013, 10:50   #10
keenan
Supermodder
Thank you Craig..
Some more hydrodipping on the CPU block and 60mm radiator, with some very illustrative photos
First I had to do some masking to make sure I dont get the base coat everywhere..
My very tidy working area ..
A massive roll of hydrographic film..
Tools of the trade..
Measured and framed..
Had to get a larger dipping tank so I borrowed my sons toy box..
Some aerosol activator..
Here you can see the film starting to dissolve from the activator..
The results!!
Old 15th Nov 2013, 11:31   #11
Sn00k3r
Modder
Sn00k3r's Avatar
Sn00k3r has yet to learn the way of the Dremel
Awesome case Dude, love this Project already
Go on, i'm wondering what's next
subbed
Sn00k3r is offline   Reply With Quote
Old 15th Nov 2013, 11:34   #12
biojellywobbles
Supermodder
biojellywobbles's Avatar
biojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyanbiojellywobbles is a Super Spamming Saiyan
This is looking like a great little project. Military themes aren't usually to my tastes but this one has some nice touches.
__________________
Main box: i5 4690K @4.5GHz, Corsair H80, 8GB Value RAM, Powercolor 280X with Kuhler 620 on G10 Bracket, OCZ ARC100 240GB, 2x500GB Seagate Barracuda, Silverstone PS07, Win7
biojellywobbles is offline   Reply With Quote
Old 15th Nov 2013, 12:01   #13
keenan
Supermodder
subbed
Thanks Sn00k3r, I really hope it keeps you entertained
Thanks biojellywobbles, I promise.. the best touches is yet to be seen
Another box from Corsair and this time I would like to thank Joseph (Greybeard) and Corsair for sending me this amazing little add-on..
The Corsair Vengeance M65 Gaming Mouse..
Looks wise this mouse is absolutely stunning and it feels very comfortable in the palm of your hand.. On the top it has the scroll wheel and a response time selector which lets you choose between 1ms, 2ms, 4ms or 8ms..
Not to mention it fits the case perfectly
On the side it has a "Sniper" button that when pressed slows the response of the mouse down to make precise movement easy as pie..
It also has removable weights on the bottom so you can select a weight that is most comfortable for you..
A little teaser
Old 15th Nov 2013, 12:14   #14
keenan
Supermodder
Small update..
Time to play with some plexiglas..
Chopped up bits..
Tools used: fretsaw, needle files and the coolest looking duct tape ever..
Some more chopped bits..
With a "sandy" base coat..
Dipped and weathered..
Quickly fitted, just for good measure..
Old 15th Nov 2013, 12:25   #15
keenan
Supermodder
Time to do some weathering on the case..
Here we go...
My little helper..
Weathering done..
Old 15th Nov 2013, 14:11   #16
craig - toyoracer
Supermodder
Sweet paint job on the case and a cute little helper.
Those back-plates look great Keenan.
__________________
octTower
Old 15th Nov 2013, 19:50   #17
keenan
Supermodder
Thank you Craig ..
I'll post some more tomorrow..
Old 15th Nov 2013, 20:13   #18
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Lidl bag FTW.
GJ mate, nice military project.
Pranja is offline   Reply With Quote
Old 15th Nov 2013, 20:18   #19
keenan
Supermodder
Originally Posted by Pranja View Post
Lidl bag FTW.
But... I thought we all went to Lidl sooner or later
Thank you Pranja..
Old 15th Nov 2013, 21:43   #20
matiss
Multimodder
matiss's Avatar
matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.
Great thing with the hydrographic film. Looks nice.
__________________
in planning for to long: Viole(n)t Raven
matiss is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
