Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th Nov 2013, 11:21   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
AMD teases 12GB 'supercomputing' graphics card
FirePro S10000 gets double the RAM.
http://www.bit-tech.net/news/hardwar...repro-s10000/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 15th Nov 2013, 11:54   #2
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
For those getting exited about the 'passively cooled' variant: this is only passive in that there are no fans on the card. The box you put it in has to have some pretty hefty forced-air cooling.
edzieba is offline   Reply With Quote
Old 15th Nov 2013, 12:02   #3
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
So could one of these be used for gaming/everyday use ? if so would BT do some benchmarking with both the 6Gb and 12Gb models please ?
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 2Tb 2.5" Toshiba HDD, Cooler: Corsair H105, OS: Win 7 - 64
Dave Lister is offline   Reply With Quote
Old 15th Nov 2013, 12:14   #4
Mister_Tad
Moderator
Modaretor
Moderator
Mister_Tad's Avatar
Mister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming Saiyan
Could? Sure.
Would? Not so much.
Being that it's likely to cost 4000+ per card and will perform no better (and likely worse) than a top-end gaming card means that it just doesn't make sense to use one of these exclusively for gaming.
Mister_Tad is offline   Reply With Quote
Old 15th Nov 2013, 12:15   #5
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Gaming on those card makes no sense. They use the same GPU than gaming card. The main differences are :
- ECC memory (not on low end model)
- More memory (not always)
- Optimised drivers for viewport rendering
- Certified drivers for professionnal softwares
- Quad buffering on mid/high end card for stereoscopic display (only way to use 3D stereo under Linux)
- 30-bit pixel color pipeline
Except that, you won't get any benefits from them for gaming. You'll most likely have less FPS as the card runs at slower frequency (while the card costs a lot more).
GuilleAcoustic is offline   Reply With Quote
Old 15th Nov 2013, 12:27   #6
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
be priced similar to nvidias super high end tesla cards which in theory could be used for gaming if you were a bit nuts.
cost will be 4000 + for the 6gb and probably closer to 5500 for the top end one. See how it performs could be a useful investment.
rollo is offline   Reply With Quote
Old 15th Nov 2013, 13:24   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
You read the part of the article where it mentions that the S10000 6GB Edition launched last year, right? As in, we don't need to guess how much it costs, 'cos you can buy one right now? Spoiler: it's about 2,500.
__________________
Old 15th Nov 2013, 15:06   #8
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
BitCoin Miner? I wonder how long it would take to earn it's money back!
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is offline   Reply With Quote
Old 15th Nov 2013, 16:15   #9
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
Depending on what the core is based on, there's a possibility you could upload the firmware of it's gaming counterpart. I'm not sure if all the RAM will be detected, but then again, I don't think spending $10000 for gaming is a wise choice. Even if you have 4 monitors at 1080p, the core would likely be the bottleneck before the memory.
@Pookie
I figure this would be terrible for bitcoin. As far as I'm aware BC isn't memory intensive at all. What it wants are lots of high-frequency cores with short pipelines. It wouldn't surprise me if a 2GB GPU had equal performance to this 12GB.
schmidtbag is offline   Reply With Quote
Old 15th Nov 2013, 16:46   #10
rollo
Gpu mining in bit coin died along time ago. ASIC miners are taking over and once more get delivered the difficulty will sky rocket. Even the fastest Gpu out there was below 0.1 bit coins a day last I checked.
Old 15th Nov 2013, 19:31   #11
Star*Dagger
Banned
Star*Dagger has yet to learn the way of the Dremel
"Even if you have 4 monitors at 1080p" 1080 is very low resolution. Most gamers who are serious have 3 30 inchers.
In any case, I have no interest in this card since it is made for the fine ladies and gentlemen who author content, not those of us who consume it.
Yours in Ultra High Resolution Plasma,
Star*Dagger
P.S. 10,000$ (pounds for those who use boutique currencies) is not a lot to spend on a PC. You can spend that much on monitors, cards and the steel hardware to hold up the screens. Add in a decent PC that handles everything from folding to gaming and you are easily over 10k$
Star*Dagger is offline   Reply With Quote
Old 15th Nov 2013, 19:37   #12
GuilleAcoustic
Ook ? Ook !
didn't know that the resolution is what makes you a 'gamer'. Glad I'm using a 1280x1024 17" 4/3 screen to play, I wouldn't like to be called a gamer
Old 15th Nov 2013, 19:52   #13
raxonb
Multimodder
raxonb's Avatar
raxonb has yet to learn the way of the Dremel
But can it play Crisis?
I've always wanted to say that
__________________
If you recognise my avatar your childhood was awesome!
To Be This Good Takes AGES...
To Be This Good Takes SEGA
raxonb is offline   Reply With Quote
Old 15th Nov 2013, 19:54   #14
schmidtbag
Ultramodder
That comment right there completely voided your point on "1080p is a low resolution", because anyone who thinks 10k dollars/pounds, is "not a lot to spend" on a PC (key word here is PC, not workstation) has serious priority problems and is way too rich for their own good. Even on websites where people spend months working on custom PCs, they don't spend much more than $2500 on the actual hardware. The fact that you think $10k will get you a decent PC means you either live in Brazil or you must be doing something very wrong. Setting aside Nvidia Titans and monitors, if I were given $10k to build a gaming+folding PC, I don't see how I could even breach that price point. I hope you realize there is such thing as too much RAM, too many drives in RAID, too many GPUs, etc. Performance can and will drop once you get to a certain point, and you also waste an immense amount of power when idle.
Besides putting wealth into perspective, 1080p is, quite literally high definition. In fact it's officially defined as FHD, as in, full high definition. Anything higher than 1920x1200 is not "high" definition anymore, but SHD or UDH.
Good job looking ridiculously pretentious.
Old 15th Nov 2013, 21:07   #15
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
Whilst you'd be out of your mind to buy a card like this just for gaming, I remember reading a review on Tom's Hardware that showed AMD top end workstation class GPUs ran games just as well as their gaming orientated GPUs. On the other handNVidia top end workstation GPUs have noticeably worse performance. Basically, if your a super serious CAD (and well off) user who likes to play games as well, this card is perfect for you.
Oh, and always ignore Star*Dagger. He/she comes along once in a blue moon to make some asinine comment, then wonders off.
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 16th Nov 2013, 09:47   #16
XXAOSICXX
Hypermodder
XXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpit
*coughs* Crysis *coughs*
XXAOSICXX is offline   Reply With Quote
Old 16th Nov 2013, 22:23   #17
Star*Dagger
Banned
4:3 is a horrible thing to do to any game. 17 inches is a good size, for a tablet. and I am not sure that most games will ever work properly at ULD (Ultra Low Def) of 1280x1024.
If you can game in the top 10% with that rig you deserve a medal. Good job.
1920x1080 is classified by home entertainment clown companies as HD. Does that mean I will limit my Gaming Glory to such low resolution? Negative!
3 monitors at 1500$ is 4500$. 3 cards at 750$ each is 2250$ that is 6750$ already. Decent desk is 500$, steel rack to hold the 3 screens in place and installed is another 1000$. We are up to 8250 now, and havent even bought the case or hardware in it.
While you can get a decent rig for 2500$ your video subsystems (which are your primary window into the Gaming Realms) will suffer severely.
Enjoy the show!
Yours in Elite Corrective Plasma,
Star*Dagger
Old 16th Nov 2013, 22:52   #18
GuilleAcoustic
Ook ? Ook !
Enjoy the show!
Star*Dagger
Does your e-Peen feel good ? Maybe you're trying to compensate your lack of skill or retarded brain by growing your arrogance. I really pity you ...
EDIT: I really hope you're just trolling. If not .... you're the stupidest person I've ever met.
Old 16th Nov 2013, 22:54   #19
Gareth Halfacree
WIIGII!
bit-tech Staff
If it brings anything to the debate, my MONSTER GAMING RIG cost 500, plus another 100-ish for the single 1920x1200 monitor. Which has a broken power button now. It works, but sometimes spins off-axis, then you have to rotate it until the power symbol is the right way up before it'll actually switch it on or off. FEAR MY AWESOME HARDWARE!
__________________
Old 16th Nov 2013, 23:03   #20
GuilleAcoustic
Ook ? Ook !
lol Gareth ... for a second I imagined your screen with a car ignition start lock xD (insert the key and turn it to power on the screen)
Reply
Tags
amd, amd firepro, amd firepro s10000, co-processor, firepro, gpgpu, gpu, high-performance, hpc, intel, nvidia, opencl, s10000, supercomputer, supercomputing, tesla k20x, top500, workstation, xeon phi
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
