Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 22nd Nov 2013, 10:51   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Intel admits to Moore's Law hiccough
"It's just getting really hard."
http://www.bit-tech.net/news/hardwar...l-moores-law/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 22nd Nov 2013, 11:08   #2
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
Then make larger chips, problem solved.
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 22nd Nov 2013, 11:13   #3
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
Larger chip = less chip per slice of silicon = higher price per die.
GuilleAcoustic is offline   Reply With Quote
Old 22nd Nov 2013, 11:17   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
Doesn't scale. Intel's predicting that its 14nm chips will cost 27 per cent more to make - but the drop in node size means they're smaller, bringing the cost back down. If they weren't smaller, every processor generation would cost more and more - until they're entirely unaffordable. Let's say you can fit 100 Pentium 5 processors on a single wafer; the Pentium 6, as required by Moore's Law, has roughly double the transistors and so, by your plan, is double the size - meaning you can only fit 50 on the wafer. Whoops, your per-chip manufacturing costs just doubled. The Pentium 7? Doubled again. Pentium 8? That's another doubling.
If the entry-level Pentium 5 cost £50, you're looking at £100 for the entry-level Pentium 6, £200 for the Pentium 7, and £400 for the Pentium 8. Eventually, by the Pentium 11, you can only get one chip per wafer - and that's the end of that game, unless you're going to make the Pentium 12 span two wafers and glue 'em together. Which is fine, except you're looking at £6,400 (plus the cost of the interconnect) per chip at this point for the entry level model.
TL;DR: Shrink or get off the pot, to coin a phrase.
__________________
Old 22nd Nov 2013, 11:39   #5
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
Imagine the heatsink to cool that bugger though.
__________________
formaggio gāteau
kenco_uk is offline   Reply With Quote
Old 22nd Nov 2013, 12:00   #6
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
It had to come to an end one day, or at least slow down.
Physics starts getting in the way when things get small, the brains need to work their magic and come up with new ways to do things.
Corky42 is online now   Reply With Quote
Old 22nd Nov 2013, 12:03   #7
GuilleAcoustic
Ook ? Ook !
That's when it starts to become interesting . Return of the co-processors ? I see more and more co-processors being released / tested (Xeon PHY, Caustic R2500, etc.). It's probably time to offload some calculus to specialized chips / cards and let the CPU do the basic stuff (dispatch the workload, do the single threaded computing, etc.).
Old 22nd Nov 2013, 12:05   #8
benji2412
Has an Avatar avatar
benji2412's Avatar
benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.benji2412 is definitely a rep cheat.
Or perhaps pretty stagnant!
__________________
Compy Mark V
Intel Core i5 2500K // ASUS P8P67 Pro // 8GB DDR3 Cosair XMS // ASUS GTX580 DirectCU II // Antec 750W // Antec 1200
benji2412 is offline   Reply With Quote
Old 22nd Nov 2013, 12:10   #9
GuilleAcoustic
Ook ? Ook !
I mean't Interesting on the "chipset designer side". They have to find innovative stuff instead of just shrinking the size and throwing more transistors at it.
Old 22nd Nov 2013, 12:30   #10
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
Does Moore's Law really matter? As long as progress is still being made, who cares?
I'm sure quantum computing will blow Moore's Law out of the water when it's tamed.
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 22nd Nov 2013, 13:06   #11
Dave Lister
Hypermodder
Dave Lister's Avatar
Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!Dave Lister - it's over 9000!!!!!!!!1!1!1!!!
I don't believe MS for one minute that "it's getting really hard". The reason they are not pushing harder is that AMD IS finding it really hard and MS don't have to try anymore.
__________________
Main Rig:Case: BitFenix Prodigy, Motherboard: MSI Z97I Gaming, CPU: Intel i7 4790K, RAM: 16Gb 2400Mhz Kingston HyperX Beast GPU: MSI GTX 970 Gaming, Primary HDD: 256Gb Samsung 850 Pro, Games Drive: 4Tb Toshiba X300, Cooler: Corsair H105, OS: Win 7 - 64, VR: Oculus with touch
Dave Lister is offline   Reply With Quote
Old 22nd Nov 2013, 13:10   #12
Gareth Halfacree
WIIGII!
bit-tech Staff
s/MS/Intel/g (Also, Intel is a process node in front of everyone else - so they'll hit these problems first. They're not making it up, you know: at these sizes, every single node transition is like getting blood out of a stone.)
__________________
Old 22nd Nov 2013, 14:50   #13
Dave Lister
Hypermodder
I'm sure its difficult but I still feel intel are being lazy because they don't have any real competition anymore (not in the mid-high end x86 market anyway).
__________________
Old 22nd Nov 2013, 14:52   #14
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
By MS don't you mean Intel? MS don't make chips...
GeorgeK is offline   Reply With Quote
Old 22nd Nov 2013, 14:56   #15
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
That is a subjective feeling, not an informed opinion (unless you are a chip designer, in which case I take it all back).
There are other technologies coming our way: optical computing, quantum computing, new substrates. They'll find a way around it. But just as the leap from valve to transistor, and then transistor to silicon took time and effort, so will the leap to the next technology.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 22nd Nov 2013, 15:08   #16
Dave Lister
Hypermodder
lol well spotted, for some reason i get those two mixed up from time to time.
@ Nexxo, yes that it just my gut feeling. When intel first came out with core 2 I was reading stuff saying they were predicting they would have over 16 cores on a chip in the next few years - that must have been over five years ago now and I'm pretty sure they are still shoveling out dual core parts at the lower end and (I may be wrong) quad and hex core parts at the top end. So my gut feeling does have a reason for the mistrust.
__________________
Old 22nd Nov 2013, 15:13   #17
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
That must have been over five years ago now and I'm pretty sure they are still shoveling out dual core parts at the lower end and (I may be wrong) quad and hex core parts at the top end. So my gut feeling does have a reason for the mistrust.
8 core/16 thread xeons are out there.
__________________
My Imgur
i7 6700k - 8GB - GTX 1070
keyboards.
Margo Baggins is offline   Reply With Quote
Old 22nd Nov 2013, 15:17   #18
Gareth Halfacree
WIIGII!
bit-tech Staff
Never mind that: how about the 12-core, 24-thread Xeon that's going into the new Mac Pro? Plus, if core count is your thing, there's Xeon Phi: 50 Pentium-class cores on a single board, with Knights Landing bringing the same tech to dedicated CPUs in the near future.
__________________
Old 22nd Nov 2013, 15:21   #19
Dave Lister
Hypermodder
I stand corrected, but it's still nowhere near what they said to expect. I guess I just have a deep trust issues towards big corporations !
__________________
Old 22nd Nov 2013, 15:31   #20
Nexxo
Whatever's Geek.
Nexxo's Avatar
Intel may be doing well in the desktop/laptop market, but ARM is already encroaching on the server market and handing Intel its ass in the fast-growing mobile market. Intel rightly perceives that more powerful chips are not the priority --current products comfortably meet most people's needs. Low consumption chips is where it's at. Their focus lies there for the moment.
__________________
Reply
Tags
14nm, broadwell, broadwell-k, cpu, gordon moore, intel, microprocessor, moore's law, semiconductor, silicon, silicon semiconductor, william holt
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
