Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Nov 2013, 10:53   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Memory makers join forces on MRAM
Mass production by 2018 or bust.
http://www.bit-tech.net/news/hardwar...5/mram-plans/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 25th Nov 2013, 13:01   #2
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Isn't changing magnetic polarity to store data the same way a HDD works
So is the new MRam similar to a HDD platter without the spinning around part, if someone could explain where my understanding is undoubtedly wrong it would be appreciated.
Corky42 is offline   Reply With Quote
Old 25th Nov 2013, 17:41   #3
ChaosDefinesOrder
Vapourmodder
ChaosDefinesOrder's Avatar
ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.
Or, more importantly, does this mean that we are taking a HUGE step backwards in terms of memory that can again be wiped by external magnetic fields?
For example, the magnetic induction wireless charging base (oh, wait, fallen at that first hurdle) for the Nexus 5 and 7 (and Palm Touchstone) uses magnets to hold the device in place...
Granted that is for existing NAND flash devices and not future MRAM devices, but whatever you think about wireless charging, that's a bit of a setback, no?
Unless MRAM is not susceptible to external fields in which case ignore the above! ;-)
ChaosDefinesOrder is offline   Reply With Quote
Old 25th Nov 2013, 18:17   #4
Cobalt
Supermodder
Cobalt's Avatar
Cobalt has yet to learn the way of the Dremel
Magnetic storage isn't as sensitive as all that. Open up a hard drive and you'll find a big chunky neodymium magnet sitting right next to the platter. I have no idea how MRAM reacts to external fields but it can't be much of a problem or it wouldn't be considered a good contender.
Cobalt is offline   Reply With Quote
Reply
Tags
dram, hitachi, ibm, japan, magnetoresistive ram, micron, mram, non-volatile memory, refresh cycle, renesas, shin-etsu, stt-mram, tdk, tetsuo endoh, tohuko university, tokyo electron, volatile memory
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
