Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Nov 2013, 11:53   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Kingston launches 2800MHz HyperX memory
Premium memory at a premium price.
http://www.bit-tech.net/news/hardwar.../hyperx-2800/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 26th Nov 2013, 12:21   #2
Jimbob
Multimodder
Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.
Bought the 2400Mhz ones when they first came out and they have (typically Kingston) been flawless. However, I struggled to OC them much further than another 80Mhz or so but that may be a mobo problem more than the RAM.
Jimbob is offline   Reply With Quote
Old 26th Nov 2013, 12:24   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
I wouldn't be surprised if that wasn't a result of binning: I'm guessing that there's no physical difference between, for example, the 2,400MHz modules and the 2,666MHz modules other than the latter being stable at a higher speed. If the 2,400MHz modules could be overclocked to 2,666Mhz stably then the chances are Kingston would sell them as 2,666MHz modules - meaning that, for any given speed of Kingston RAM, you can expect very little overclocking headroom from the officially rated speed. Except, possibly, on the 2,800MHz modules - 'cos there's no bin above that for Kingston to assign the modules to.
That's just conjecture, though, and I'm happy for someone to prove me wrong.
__________________
Old 26th Nov 2013, 12:47   #4
digitaldunc
Hypermodder
digitaldunc's Avatar
digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.
Do they really need those ridiculously large heat spreaders?
__________________
Event-horizon: i7 2600K @ 4.5 @ ~1.3v | 16Gb Corsair Vengeance @ 1866 9-10-9-24-2T | 2 x 580 1.5Gb (SLI) 772/1002 | Asus P8P67 Deluxe | Crucial M4 256Gb | Spinpoint F3 1TB | Corsair HX1000 | ZM-MFC1 Fan controller | XSPC Dual res | 2 x DDC 18W | Black ice stealth 360 | ThermoChill PA120.4 | EK Supreme HF Nickel | 2 x EK 580 Plexi | 7 x Scythe Gentle Typhoon 1450RPM | Modded TJ07
digitaldunc is offline   Reply With Quote
Old 26th Nov 2013, 13:08   #5
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Its a shame that they probably wont bring much of a performance increase.
Or at least that's what i was led to believe when going from 1600Mhz to 2400Mhz
Corky42 is offline   Reply With Quote
Old 26th Nov 2013, 13:42   #6
Jimbob
Multimodder
"I wouldn't be surprised if that wasn't a result of binning:"
2400Mhz was the fastest they made at the time.
Old 26th Nov 2013, 13:52   #7
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
That's ultimately the truth about RAM, isn't it? Gaming wise, you'll probably get at most 1%* extra performance when the RAM speed goes beyond 1600MHz.
*Personal estimate.
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 26th Nov 2013, 15:50   #8
Gareth Halfacree
WIIGII!
bit-tech Staff
No: 2,400MHz was the fastest they sold at the time. Imagine you make memory modules: 60% of those modules run happily at 1,600MHz; 20% run at 1,866MHz; 10% run at 2,133MHz; 5% at 2,400MHz; 4% at 2,666Mhz; and 1% at 2,800MHz. Here's what you do: you sell your 60% immediately 'cos you've got loads of 'em; a while later, when you've built up inventory, you launch a faster 1,866MHz family; it then takes twice as long to build up 2,133MHz inventory - but this accelerates over time as the yields improve and the quality of your parts go up, meaning a larger percentage bins at the higher speed - but once you've got a warehouse-full you launch those too. Repeat until all modules are on the market.
Again, this is conjecture - but if you think Kingston had a bunch of chips that would happily do 2,800MHz but released them onto the market at 2,400MHz prices then I'd say you're mistaken; likewise the thought that these new 2,800MHz modules use chips that don't come from the same production line as the 2,400MHz modules.
__________________
Old 26th Nov 2013, 15:54   #9
azazel1024
Supermodder
azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.azazel1024 is the Cheesecake. Relix smiles down upon them.
*Personal estimate.
It seems to be a little more than that. Anandtech has done a few articles that have examined faster memory on Ivy and Haswell systems in the past. IIRC the general take away is that 1866mhz memory is the best bang for the buck.
In most things, the jump from 1333mhz to 1600mhz seemed to net 1-3% gains and roughly the same again jump from 1600-1866. After that, going up to 2666Mhz (I think that was the highest speed they had tested) gets around -1 to 2% in performance (not per tier, that is the difference between 1866 and 2666Mhz).
Memory bandwidth is a lot higher, there is just almost nothing that needs bandwidth that high.
I think the ONLY exception are some games using the iGPU on Ivy/Haswell. Even then, the gains were modest. I think 1333 to 1866 was around a 5-8% gain in frame rates and 1866 to 2666 was only 2-5%.
Its a lot of money to pay for very, very modest gains. Considering the excessively higher prices paid as you jump up in speed tiers, best bang for the buck is probably 1600 or 1866mhz memory. Even if ultimate performance is your goal, probably 2000 or 2333mhz is your best bet as some things showed decreased performance at higher speeds (maybe as a result of having to increase the CAS to meet those speeds, I don't really know). Anything over 2333mhz is DEFFINITELY just for bragging rights.
At least as it stands today. With DDR4 and a reworked memory controller, that might change things.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570
azazel1024 is offline   Reply With Quote
Old 26th Nov 2013, 19:01   #10
Pete J
RIP Teelzebub
Pete J's Avatar
Totally agree. Better to funnel the extra money into a better GPU/CPU!
__________________
Old 27th Nov 2013, 12:29   #11
Yslen
Lord of the Twenty-Seventh Circle
Yslen's Avatar
Yslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming SaiyanYslen is a Super Spamming Saiyan
I tried to buy 1600Mhz Corsair when I upgraded my PC, thinking I'd be sensible and go for the cheaper option that was more likely to work without issues. Went through three sets and none of them could hit 1600Mhz without crashing left right and centre.
Gave up, spent ~10 extra and got a G.Skill 2133MHz set (Ripjaws X). They've been happily chugging away at 2133MHz since I installed them, getting on 18 months ago now.
Based on that experience I'm inclined to spend a bit more on memory to avoid the faff of returning several sets to find a stable one. Could just be Corsair, I suppose...
__________________
Asrock Z77e-ITX - Intel i5 3570k - Corsair H100i - G.Skill Ripjaws X 2133MHz - MSI GTX 970 - Crucial M4 - 530W ThermalTake SS PSU - Corsair 250d - LG IPS231P - Logitech G302 - Many, many keyboards
Take a look at my Photography portfolio, here.
Yslen is offline   Reply With Quote
Reply
Tags
2800mhz, 4gb, 8gb, ddr3, dram, hyperx predator xmp, kingston, kingston hyperx, memory, ram, xmp
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
